Pixie on the town (Moore)
Started by Anastasia, May 26, 2016, 03:54:18 PM
[14:54] <Nephrite> roll 1d20+12+11+12 Intimidate
[14:54] <Rei-chan> Nephrite rolled : 1d20+12+11+12 Intimidate --> [ 1d20=18 ]{53}
That seems to do. The last three slaad scream as one. Two flee, but the last keeps clapping while screaming. "Bravo! Bravo! Bravo!" Then it bows and sinks into the ground like water, gone.
"Split up or stay together to look?" Moore asks.
"Blue slaad aren't that tough," Moonlight says, "Unless there's a death slaad bossing them around, we should be fine to split up. What could possibly go wrong?" She says this with a big grin, "Nothing, that's what."
"Well, there's a good way to find out, I suppose." He fishes his coin out -- "Is there a death slaad here?" Then he throws it up! Considering they're in Limbo, he's really not so convinced it's actually going to work, but hey, it's no fun to never chance fate.
Amazingly, the coin that doesn't handle chaos well comes up on its side in the realm of absolute chaos, when asked about an exemplar of chaos. Who would ever guess that?
No one! So Moore looks around for any hallways or ways to go.
Ahead is the main monastery. The gate is open and somewhat damaged, so getting in won't be difficult. Alternately, you could explore the outer courtyard at your leisure.
"Let's just check inside for now." Moore suggests as he goes forward past the gate.
Within leads directly into a center room. A bell hangs in the center of the room, a big, full sized bell. Slain githzerai lay all about, some half eaten and some intact.
"If any of you are alive, please raise a hand! The slaad are gone!" Moore calls out. He doesn't have time to check them all, unfortunately, so he'll have to trust that they can hear him.
If there's no response, he'll simply look for another way to explore and listen for any calls from Moonlight or from deeper in.
Searching the place? Make a Search check.
You search around. You find a lot of dead githzerai, bedrooms, storage rooms for supplies, a meditation room, a small library and a locked door in the back. You can search any of these further if you want or do something about the door, if you wish.
Moore frowns. They were really thorough...
He'll search the rooms in order, presuming Moonlight doesn't call out for anything. So, bedrooms, then supplies, then meditation room, then library in that order. He's looking for anything that might indicate what this place was for (and why in the world it was in Limbo) and then possibly a key to that door. In the supplies room he'll look for anything of any note (read: magical).
