Afina vs the lich (Afina)
Obligatory Climb check, Smrgol.
Mei
HP: 135/295
Spells Active: Mind Blank (CL17), Fortunate Fate (CL15), Planar Tolerance(CL7), Greater Mage Armor(CL5), Haste(CL23)
Bonuses: +1 attack rolls, +1 attacks, haste movement speed, +1 ref.
Resources Used: Celestial resilience
Dana
HP: 135/313
Resources Used: 228/239 power points
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[18:23] <@Ebiris> roll 1d20+57 climb
[18:23] <Kobot> Ebiris rolled 1d20+57 climb --> [ 1d20=8 ]{65}
Smrgol climbs up the golem. It struggles a bit but offers no meaningful resistance, legs down. Ahead the pass narrows, still passable but rather tight.
Just going on ahead or...?
Yeah, we'll keep going while the elementals pound away on the golem. They'll be joined by 1d3 huge ones after ten minutes if there's anything left by then.
Your companion's wounds heal as you go down the pass. It winds on and on, tighter and tighter. And then, at last - a dead end. A smooth, steep cliff that rises hundreds of feet up, perfectly vertical. The cliffside glistens wetly.
Enough time for those with fast healing to reach max HP.
Mei
HP: 295/295
Dana
HP: 313/313
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
"Greased cliff, huh? Alright lets take a moment," Afina says, tapping both Mei and Dana as she casts resist energy on them to protect from flames, and then she casts planar bubble to surround herself with the traits of fire. She's curious if it cancels out the prime's ley-line traits and makes an experimental effort at flying but the main purpose comes as she stands next to the cliff, the bubble around her starting to boil away the grease... or just set it aflame depending on the type.
Resist Fire 30 for the NPCs, 3d10 fire damage to anything within 10 feet of me.
Afina: 247/277, heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), greater mage armour (CL 23), moment of prescience (CL 23), see invisibility (CL 23), haste (CL 23), planar bubble (CL 23)
AC 87, spell resistance 38, blindsense 30, immunity to fire, water, earth, cold, disease, poison, fear, 50% miss chance
Spell charges: 5/9/7/6/8/8/9/6/5/7
Smrgol: 459/459
AC 50, immunity to magic, fast healing 10
Flames happen. The wall in front of you bursts into flame, the material coating it clearly flammable. No luck on flying, though.
"Grease," Dana says, "Fucking greased wall because that lich isn't enough of a cunt."
Mei
HP: 295/295
Spells Active: Mind Blank (CL17), Fortunate Fate (CL15), Planar Tolerance(CL7), Greater Mage Armor(CL5), Resist Energy(Fire)(CL23)
Bonuses: Resist fire 30.
Dana
HP: 313/313
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
"Honestly this is better," Afina says, stepping back and watching the flames spread. "The grease will all burn up and we'll have an unimpeded path upwards."
Going to try to climb up then? Climb check.
[19:26] <@Ebiris> roll 1d20+57 climb
[19:26] <Kobot> Ebiris rolled 1d20+57 climb --> [ 1d20=10 ]{67}
It's tough going like this, but you climb, climb and climb some more. After about 400ft, it evens out into a path ahead.
Sensory abilities?
Afina has blindsense 30
Smrgol: 459/459
That's odd. Afina can sense wind a bit ahead and below where the path ahead is. Wind, blowing free.
edit: I also have see invis. Which direction is the wind blowing?
Upward, as if that stone wasn't there at all.
