Lethe (Jaela, Surraruthru, Moore)
Started by Anastasia, August 05, 2016, 12:18:02 PM
Surraruthru takes a moment to survey the lines, trying to figure out a way to stabilize things and focus the units once more.
It's a mess. Parts have devils being held back or menacing, while others are clear. The vanguard's beginning to reach you and falling back, adding even more chaos. The soldiers are holding reasonably well, but it's up close combat with a fallback as well. Orderly and stabilizing isn't easy. Best as you can figure, eliminating devils will help, since they're the real problem.
How close is the biggest clump of fighting? Could I strafe the middle to back of the devils there without ripping apart friendlies?
30ft away. You'd hit at least a few friendlies - it's just getting too compacted with the vanguard falling back.
Surraruthru decides to follow suit with Moore and uses his ability to summon creatures to help provide a little on-the-spot healing.
Using Summon Nature's Ally IV to summon a Unicorn to do a little healing.
Okay, you have a unicorn. What spell or ability is it using?
A unicorn can use cure light wounds three times per day.
That for now, unless there's someone who's seriously hurt. Then it's got a 1/day cure moderate.
[10:57] <Nephrite> roll 3#1d8+5+27
[10:58] <Rei-chan> Nephrite rolled : 3#1d8+5+27 --> [ 1d8=7 ]{39}, [ 1d8=5 ]{37}, [ 1d8=3 ]{35}
Wounds are healed as you fall back. The vanguard arrives, Gisfal leading them as you sweep devils away. "Back, back, back," His commands echo as you all retreat. Everyone's falling back as the lillend and all of you are surrounded by allies, steadily falling back to Aurora.
Moving you all over to Jaela's thread.
