Wrap up (Various)
[18:18] <@Ebiris> roll 2#1d20+11 fort I'll just roll now, they have plenty of hp
[18:18] <Kobot> Ebiris rolled 2#1d20+11 fort I'll just roll now, they have plenty of hp --> [ 1d20=3 ]{14}, [ 1d20=16 ]{27}
Afina: 215+2/215, glaciante's spiteful ward (CL 24 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), planar tolerance (CL 7), epic mage armour (CL 24), moment of prescience (CL 24), fortunate fate (CL 24), control temperature (CL 24), haste (CL 24), good hope (CL 24)
AC 69, spell resistance 39, blindsense 30, immunity to fire, water, earth, cold, disease, poison, fear, 50% miss chance, freedom of movement
Spell charges: 6/7/9/6/8/6/3/8/7/8/4/0
Init: +24
Attack: ice sword +42 (1d4+12 +5d6 skirmish +2d6 swift +1d6 sudden strike)
Saves: Fort: +19 (+23 vs poison), Ref: +32, Will: +27
Elemental 1: 47hp, fort +11, will +11, ref +5
Elemental 1: 74hp, fort +11, will +11, ref +5
Impaled, the elementals are coated in ice, unable to move. It makes the gasses in them more solid, binding them rather than letting them flow freely.
Storm elementals are covered in ice. Can't move or take normal actions, though they can take purely mental actions or try and break out of the ice.
Meanwhile, the icicle morphs into a hand - attached to a titanic arm, which rises up and tries to grab Hanna.
> roll 1d20+49 vs 51 (+10 freedom of movement)
<Kobot> Kotono rolled 1d20+49 vs 51 (+10 freedom of movement) --> [ 1d20=20 ]{69}
Hanna's grabbed, hand closing around her and entombing her entirely. You can hear her beating against the ice, muffled and far away as the creature's hand and arm begin to sink back down.
Jaela and Hanna, forgot to adjust init. Let me. Go Jaela.
Init is Afina (36) > ??? (23) > Jaela = Hanna (20) > Mirajane (16)
Jaela kicks off the frozen fragments of her wings and flies down at the massive arm trapping her mother spear first!
Charge, quickened true strike, divine might, k:devotion, 20pa
[20:42] <Rin> roll 1d20+36+1+2+5 20pa, true strike
[20:42] <Kobot> Rin rolled 1d20+36+1+2+5 20pa, true strike --> [ 1d20=17 ]{61}
[20:43] <Rin> roll 1d8+25+5+40
[20:43] <Kobot> Rin rolled 1d8+25+5+40 --> [ 1d8=1 ]{71}
Hit Dice 386/401hp [+24hp with Righteous Might, +48hp with Holy Transformation, +24temp hp with Divine Power]
Init: +7
Speed: 40ft (land)/120ft (flight, perfect maneuverability) [10ft enhancement from Longstrider]
Armor Class: 23 touch AC, 44 normal AC with no gear/19 normal AC under antimagic [12 from dex and cha/-12 when flat footed, 1 from natural armor, 20 force from epic mage armor, +5 sacred with Shield of Warding, +3 luck from Recitation, 1 from Haste]
BAB/CMB/CMD: +22/+27/49
Magical Ice Spear Attack: +36 = +22bab+5str+1weapon focus+2melee weapon mastery+5GMW+1haste
Magical Ice Spear Damage = +25 = +7strx1.5+2weapon specialization+2melee weapon mastery+9holy warrior+5GMW
Ray Attack: +26 = +22bab+3dex+1weapon focus
[Knowledge Devotion not counted]
Resistances and Immunities: Fire Resistance 10, Cold Resistance 10, Acid Resistance 20, Electricity Resistance 20, Sonic Resistance 10, Damage Reduction 20/Epic and Evil and Cold Iron, Spell Resistance 34 (43 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated.
Saves: Fort +36, Ref +28, Will +36 [Antimagic: -2 to each save, Conviction: +5 to each save]
Precast/Bead of Karma: Contingency/Righteous Might when Jaela casts Holy Transformation CL30, Energy Immunity/Cold CL30, Permanency/Greater Blindsight CL30 [Blindsight for 60ft], Permanency/Mantle of Good CL31, Permanency/Prestidigitation CL30, Celestial Brilliance CL30, Extended Lore of the Gods CL30 (10hr duration), Righteous Halo CL30, Longstrider CL25, Moment of Prescience CL25
Precast: Epic Mage Armor CL24, Fortunate Fate CL24, Conviction CL24, Sign CL24, Divine Insight CL24, Spell Turning CL24, Good Hope CL24, GMW CL24, Haste CL24, Heroes's Feast CL20, Mind Blank CL17, Planar Tolerance CL7
Favored Soul slots left, 01-11: 8/0/8/2/8/7/3/6/6/5/3
CL 24 Favored Soul, CL 18 Divine Crusader [CL boosters for War and Force active, for Abjuration and Protection gone]
Spell/SLA DC: 19 + spell level
-1 Turning
Jaela, just to be clear, you understand you're falling, right?
I'm falling down, the arm is below. If this requires some sort of tumble check or whichever for the acrobatics I'll do that.
Okay. I'm just saying that it may not do much for you not splashing down in the water or landing on the elemental's head. Wanted to make sure you understood that.
Jaela plunges spear first, falling and using the last of her wings to stab into the icy arm. She drags down it a few feet, opening up a rend in it. The hand flexes open, releasing Hanna. She immediately flies down to you, grabbing you as you hold onto your spear, "Getting out of here about now," she stays, starting to ascend.
Mirajane's up.
"Retreat! We can't win like this!" Mirajane calls, flying straight up as fast as she can and out of sight, into the mists above.
Mirajane's flying up as far as she can.
Afina, go. Your ice-wrapped elementals are also up.
With Mirajane already fleeing and Hanna having a solid hold on Jaela, Afina is fine with this state of affairs and hastens to follow their seer's advice! "I'm right behind you!"
Casting a prismatic wall horizontally below so as to block any projectiles sent upwards after them, she flies right up after the three angels! The storm elementals sadly are unable to do much of anything, left either to wait out the duration of their summons or suffer whatever the ice elemental has in store for them.
Init: +24
Everyone flies up fast, the four retreating - but the hand follows. It just begins to reach the end of its tether as it catches up with Jaela and Hanna again, trying to grab them both.
CMB vs Hanna. Jaela, you can't do much here since you can't fly, though I'll give Hanna a +2 circumstance bonus for miscellaneous aid you'd offer here.
> roll 1d20+49 vs 58 (+15 freedom of movement, +2 Jaela)
<Kobot> Kotono rolled 1d20+49 vs 58 (+15 freedom of movement, +2 Jaela) --> [ 1d20=14 ]{63}
The icy hand closes over both of them, pinning mother and daughter together tightly as it closes around them.
Jaela and Hanna, go. It's dark here since the hand blocks all the light and you're grappled. Also smooshed into Hanna, which doesn't help.
But before that, what's your CL check vs SR, Afina?
[19:22] <@Ebiris> roll 1d20+24 SR
[19:22] <Kobot> Ebiris rolled 1d20+24 SR --> [ 1d20=3 ]{27}
[19:23] <@Ebiris> that was for red, since each colour is rolled individually
[19:23] <@Ebiris> roll 1d20+24 SR orange
[19:23] <Kobot> Ebiris rolled 1d20+24 SR orange --> [ 1d20=15 ]{39}
[19:23] <@Ebiris> roll 1d20+24 SR yellow
[19:23] <Kobot> Ebiris rolled 1d20+24 SR yellow --> [ 1d20=1 ]{25}
[19:23] <@Ebiris> roll 1d20+24 SR green
[19:23] <Kobot> Ebiris rolled 1d20+24 SR green --> [ 1d20=18 ]{42}
[19:23] <@Ebiris> roll 1d20+24 SR blue
[19:23] <Kobot> Ebiris rolled 1d20+24 SR blue --> [ 1d20=14 ]{38}
[19:23] <@Ebiris> roll 1d20+24 SR indigo
[19:23] <Kobot> Ebiris rolled 1d20+24 SR indigo --> [ 1d20=16 ]{40}
[19:23] <@Ebiris> roll 1d20+24 SR violet
[19:23] <Kobot> Ebiris rolled 1d20+24 SR violet --> [ 1d20=18 ]{42}
DC 30 for any effects suffered
Shrugs it off with high SR, so go, Jaela and Hanna.
"Go!" Jaela yells to Afina and Mirajane. "We'll be fine!"
And they will be, because she relies on the contact with her mother to teleport the two of them up over a thousand feet!
Dimension Door.
You auto pass the Concentration check and DD qualifies to be cast while grappled, so you're good.
Jaela and Hanna teleport up, Hanna holding Jaela tightly, "Good work," she says, "I'll handle the flying and you take care of the fighting." Meanwhile Afina and Mirajane begin to catch up, banishing the fog.
Free act for now. Close call, y'all.
"It'd be good to stop and regenerate a bit," Jaela hints, keeping an eye out for attacks coming at them from a radius of 60ft.
