Wrap up (Various)
The elemental stands aside, wordlessly.
"So is it a problem if my larger friends smash their way through your pillar setup here?"
It's not a problem for her, she can squeeze through just about anything. But the gaps ahead are nowhere near Hanna-compliant.
"Smash," The elemental says, "But beware dangers."
Jaela tries to see if she can squeeze past without getting stuck.
Afina goes to stand behind Hanna on that note.
Escape Artist check, Jaela.
[21:53] <Rin> roll 1d20+3+15
[21:53] <Serith> Rin roll for Serith < 36 > [d20=18]
Will recast Divine Insight at earliest opportunity.
It's a tough, tight squeeze, but Jaela just barely makes it through. A bit embarrassing since the two parts that were hard to get through were two salient things, but you pulled it off.
Beyond the pillars, you can see that the back sides of them are transparent. Within are dancing patterns of blue energy, weaving in...oh, is that...
K:A, Jaela.
Beyond that, there's a cleft in the wall with a passage leading further in, as well as a second one farther away that also leads deeper in.
They look like spell patterns, magic held within. All cold related magic - a polar ray in the firs tone you look at, the next a piercing cold, empowered cone of cold. So on and so forth.
"Beware dangers, alright," Jaela repeats loudly enough for the others to hear. "You break this, the stored ice spells break you."
"Well, we know this place isn't dimensionally blocked," Afina takes Hanna's and Mirajane's hands. "Be over in a second," she casts dimension door to take them as far as the distance she can hear Jaela's voice coming from.
Afina: 215+2/215, glaciante's spiteful ward (CL 24 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), planar tolerance (CL 7), epic mage armour (CL 24), moment of prescience (CL 24), fortunate fate (CL 24), control temperature (CL 24)
AC 69, spell resistance 39, blindsense 30, immunity to fire, water, earth, cold, disease, poison, fear, 50% miss chance, freedom of movement
Spell charges: 6/7/9/6/7/6/3/8/7/8/4/0
Init: +24
Attack: ice sword +39 (1d4+10 +5d6 skirmish +2d6 swift +1d6 sudden strike)
Saves: Fort: +17 (+21 vs poison), Ref: +29, Will: +25
The three of you are over in the blink of an eye. "Good work, Jaela," Hanna says, turning to look at the patterns. "Like scrolls or similar things, ready to activate when the spell's finished?"
"Something like it," Jaela agrees. "A shame we can't take it home."
"Put a proposal through and I can probably make something similar," Afina says, giving them a look over briefly before she continues down the path, pausing at the first cleft. "Any predictions for going this way, Mirajane?"
