Wrap up (Various)
Mirajane already has divine insight cast on herself, so no need, Jaela. She doesn't have a way around it being a personal/you spell anyway so she can only keep herself up to date with it, so save charges for the others.
"Go ahead, Mother," Mirajane says, "There's no sense in all of us going when only one needs to."
Temp: Celestial Valor (CL24): +8 sacred vs fear and emotion, +4 sacred to attack, weapon damage rolls, saving throws and armor class. Weapons count as holy weapons. Haste: +1 attack/ref/fa attacks/speed boost
Hanna http://www.soulriders.net/forum/index.php/topic,103876.msg1078446.html#msg1078446
HP: 285/285 regeneration 11
Spells Active: Mind Blank (CL15), Fortunate Fate (CL24), Planar Tolerance (CL7), Epic Mage Armor (CL24), Heroes Feast (CL20), Divine Insight (CL24), Freedom of Movement(CL24), Good Hope (CL24), Radiant Shield (CL23)
Bonuses: +20 armor bonus to armor class, +1 morale attack rolls and Will saves, immunity to fear and poison, +2 morale attack rolls, saving throws, ability checks, skill checks and weapon damage rolls.
Resources Used: 1 rage
Mirajane http://www.soulriders.net/forum/index.php/topic,103876.msg1078449.html#msg1078449
HP: 328/341
Spells Active: Mind Blank (CL15), Fortunate Fate (CL24), Planar Tolerance (CL7), Epic Mage Armor (CL24), Heroes Feast (CL20), Good Hope (CL24), Divine Insight (CL23), Visions (CL-)
Bonuses: +20 armor bonus to armor class, +1 morale attack rolls and Will saves, immunity to fear and poison, +2 morale attack rolls, saving throws, ability checks, skill checks and weapon damage rolls, +7 insight to AC/saves.
Resources Used: 1 rage, 1 turn, 1 9th level spell, 1 2nd level spell.
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
I already jumped to the next platform~
Are you flying at all or relying entirely on jumps?
Make a Jump check and a Balance check.
[19:25] <@Rin> roll 1d20+5+48+2 jump (speed, tumble synergy) I choose Rei
[19:25] <Rei-chan> Rin rolled : 1d20+5+48+2 jump (speed, tumble synergy) I choose Rei --> [ 1d20=4 ]{59}
[19:25] <@Rin> roll 1d20+3+2+15 balance (tumble synergy, divine insight)
[19:25] <Serith> Rin roll for Serith < 29 > [d20=9]
Forgot the +4 from Greater Heroism to each check, so 63 and 33.
Good catch, since the Balance DC was 30.
Jaela hops and leaps along, narrowly missing water several times and almost slipping more than once. Fortunately, after a few hundred feet she reaches the bottom. Here is a frozen lake, your feet numb the moment they touch it. The water hits it and goes right into the ice without melting.
It goes in all directions. Far ahead in each cardinal direction is a small shrine building, made of blue ice.
"I made it down!" Jaela calls over to the others. "Pretty slippery and lots of fun! Also, pretty sure that's where we're supposed to go!"
"Well, do you two want to follow Jaela's example, or take her advice and have me teleport us all down?" Afina asks the remaining two angels up at the lip of the pit.
"Teleport us, please," Mirajane sends, and then stops. "Except it's not going to work. I don't think we have a choice but to try now."
"That's that then," Afina says as the easy way is denied them. Now they have to do as Jaela does instead of as Jaela says! "I'll go next," she casts greater heroism on herself and then on both Hanna and Mirajane for an extra boost beyond Good Hope before hopping and skipping her way down the platforms!
CL 24 greater heroism, +20 temp hp and +4 morale to attack/saves/skills
[17:55] <@Ebiris> roll 1d20+29 jump
[17:55] <Kobot> Ebiris rolled 1d20+29 jump --> [ 1d20=5 ]{34}
[17:55] <@Ebiris> roll 1d20+15+15 balance divine insight
[17:55] <Kobot> Ebiris rolled 1d20+15+15 balance divine insight --> [ 1d20=1 ]{31}[/i]
Afina: 215+20/215, glaciante's spiteful ward (CL 24 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), planar tolerance (CL 7), epic mage armour (CL 24), moment of prescience (CL 24), fortunate fate (CL 24), control temperature (CL 24), good hope (CL 24), haste (CL 24), greater heroism (CL 24)
AC 69, spell resistance 39, blindsense 30, immunity to fire, water, earth, cold, disease, poison, fear, 50% miss chance, freedom of movement
Spell charges: 6/7/8/5/6/6/0/5/7/8/3/0
Init: +24
Attack: unarmed +368(1d4+7 +5d6 skirmish +2d6 swift +1d6 sudden strike)
Saves: Fort: +21 (+25 vs poison), Ref: +34, Will: +29
Woah! It's harder than Afina thinks, needing to balance carefully and nearly falling or plunging into a stream of water several times. Close calls are only close calls, and Afina eventually reaches the bottom safely, her stomach in her throat from the near misses.
Next is Mirajane, who follows after a short consultation with Hanna.
> roll 1d20+23 (+12 movement speed, +4 greater heroism) Mirajane Jump
<Kobot> Kotono rolled 1d20+23 (+12 movement speed, +4 greater heroism) Mirajane Jump --> [ 1d20=11 ]{34}
> roll 1d20+26 (+4 greater heroism, +15 divine insight) Mirajane Balance
<Kobot> Kotono rolled 1d20+26 (+4 greater heroism, +15 divine insight) Mirajane Balance --> [ 1d20=7 ]{33}
Mirajane lands safely as well, as Afina feels her feet go numb, the frozen water here so cold as to do it instantly. Finally, Hanna steps back and then leaps in, following.
> roll 1d20+16 (+4 greater heroism, +4 movement) Hanna Jump
<Kobot> Kotono rolled 1d20+16 (+4 greater heroism, +4 movement) Hanna Jump --> [ 1d20=20 ]{36}
> roll 1d20+24 (+4 greater heroism, +15 divine insight) Hanna Balance
<Kobot> Kotono rolled 1d20+24 (+4 greater heroism, +15 divine insight) Hanna Balance --> [ 1d20=2 ]{26}
> roll 1d20+32 Ref save
<Kobot> Kotono rolled 1d20+32 Ref save --> [ 1d20=20 ]{52}
> roll 1d6
<Kobot> Kotono rolled 1d6 --> [ 1d6=3 ]{3}
Hanna passed the save, but it's relative here.
Hanna lands with a shout - her right arm nothing but ice, frozen through and transparent. She winces visibly as it starts to crumble, "Misjudged my balance," she remarks, as Mirajane comes over.
"I'll fix it, Grandmother." she says, wincing in understanding.
HP: 285+20/285 regeneration 11
Spells Active: Mind Blank (CL15), Fortunate Fate (CL24), Planar Tolerance (CL7), Epic Mage Armor (CL24), Heroes Feast (CL20), Freedom of Movement(CL24), Good Hope (CL24), Greater Heroism (CL24)
Bonuses: +20 armor bonus to armor class, +1 morale attack rolls and Will saves, immunity to fear and poison, +2 morale attack rolls, saving throws, ability checks, skill checks and weapon damage rolls, +4 morale attack/saves/skills.
HP: 341+20/341
Spells Active: Mind Blank (CL15), Fortunate Fate (CL24), Planar Tolerance (CL7), Epic Mage Armor (CL24), Heroes Feast (CL20), Good Hope (CL24), Greater Heroism (CL24)
Resources Used: 1 rage, 1 turn, 1 9th level spell, 1 2nd level spell, visions (1 hour recovery time)
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
"It's easily done, I nearly fell over a few times," Afina commiserates with Hanna.
There was supposed to be HP damage with that, let me fix that.
> roll 8d10 Hanna
<Kobot> Kotono rolled 8d10 Hanna --> [ 8d10=48 ]{48}
"No need," Hanna holds up her stump - one that's growing before your eyes. "Give it a minute and it'll be fine. That route is treacherous and that water's a marvel. I wonder if we could get a sample of it? It would be useful."
Hanna has regeneration, so her arm's just a matter of time.
