You land somewhere hard. It's pitch black, but your darkvision allows you to see. It's a 10ft by 10ft room, the walls solid stone. No doors, you seem to be trapped.
Surratuthru inspects the room, looking for any weakness in the walls and listening for an indication of which wall leads to a corridor or another room.
> roll 1d20+24 Search
<Serith> IronDragoon roll for Serith < 39 > [d20=15]
You check the roof and see faint lines that suggest that the ceiling can open up. You don't see anything on the smooth surface of the ceiling that looks like a way to open it, though. It's also quite warm to the touch, you find. Almost unpleasantly so.
Would Fire Immunity cover things like Magma and molten metals and such?
Yes. It won't stop drowning in them or being coated in cooling rock or metal, but it would stop the fire damage from them.
Surraruthru pulls on his magical reserves casting Energy Immunity (Fire) on himself. Once that settles over him, he focuses again, changint, and lets loose with a blast of Disintegrate, readying himself to leap and fly to the highest corner of the room before he's covered in whatever may come through.
Surraruthru
HP: 291/296
AC: 32+6
Init: +12, Touch Atk: 29
Active: Mindblank (CL25), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20)
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Moment of  Prescience, Energy Immunity (Fire)
Your spell is timely, for as you wrap fire warding around you, the door above opens. Lava begins to pour into the room, gushing in. It's hot and bright orange, lighting up the room as it begins to fill the room up.
That happened before the disintegrate, you chose your actions with great wisdom. Go, you can do the disintegrate or take a different tack.
Surraruthru maintains his hovering as close to the ceiling as he can, waiting for the room to fill until it's almost touching him, hoping the lava is released in a measured amount; exactly enough to fill the room. Once the room is almost filled, he fires off the Disintegrate spell, hoping to vaporize the last little bit and leaving the path through the trap door clear to fly through and leaving him from being covered in molten stone.
If not, he decides he'll just swim through it as best he can.
I never really defined, but since I have him as a large-ish shoulder pet, I'd say about he has the body size of a large cat, with a longer tail/neck that drapes down about the length of a scarf.
Surraruthru waits until the last minute, casting disintegrate. The lava in the room is disintegrated, gone, though more continues to pour in from above. No sign of it stopping, unfortunately.
10ft cube in a 10ft room basically clears it.
#508
Surraruthru calls on his innate magical ability and summons creatures to assist him!
Using my 1/day Summon Nature's Ally IV to summon 1d3 Summon Nature's Ally III to summon Thoqqua
> roll 1d3 Summon Nature's Ally III
<Serith> IronDragoon roll for Serith < 2 > [d3=2]
"Thoqqua, work together and burrow up through the lava to the surface!"
Surraruthru
HP: 291/296
AC: 32+6
Okay, first of all. Can you breathe in liquids in any form, or are you able to stop breathing? Lava's closer to a semi-solid, but whatever.
