It went through the wall like it wasn't there, so the wall is intact. The wall doesn't seem like an illusion, anyway.
Surraruthru cautiously pokes the wall with the tip of his tail, ready to dodge back if it goes wrong.
It's a solid wall. There's mold growing on it and it's damp. Cold too.
Surraruthru turns away from it, inspecting the rest of the area, looking for hidden doors and where the other end of the hallway leads.
It's a bland square of dungeon, no doors.
Search check.
> roll 1d20+24 Search
<Serith> Iddy roll for Serith < 27 > [d20=3]
No hidden doors or passages that you can find.
Surraruthru decides to try and will another portal open, trying to get to any of his allies that came with him.
Once again make an Intelligence check. +1 circumstance bonus.
> roll 1d20+8+1 Int
<Serith> Iddy roll for Serith < 22 > [d20=13]
Another swirling black portal appears before you.
Surraruthru dives back in, hoping to find the others.
You appear in a large chamber. Here six brains the size of Hanna hang from chains. Long needles are stuck into the bottom of the brains, causing green fluid to slowly leak out of them and into a vat beneath them. Three on your left and three on your right, a path to walk between them. The room itself is made of cold steel, a rough square with a door on the right side of the wall straight ahead, past the brains.
Surraruthru eyes the brains and the set up, suspecting a trap. Thinking the steel floor may have something to do with it, he takes to the air as he inspects the area.
