> roll 1d20+31 Listen
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 32 > [d20=1]
You can't quite tell. The voices continue as you try - Ebony screaming in agony all the while.
> roll 1d100
<Kobot> Kotono rolled 1d100 --> [ 1d100=84 ]{84}
You can try again, continue on or do something else, as you please.
Surraruthru figures this is an illusion, but decides to check out the books while trying to get a better handle on Ebony's location... Perhaps the illusion is a hint itself... Pain in knowledge? Perhaps something he knows, but doesn't have a handle on will allow him to punch though... Hm... The portals operate off of force of will and intelligence.. Maybe the library does too..
Surraruthru focuses his will and tries to force the reality of the library to change and provide him with what he needs.
> roll 1d20+31 Listen
<Kobot> Iddy rolled 1d20+31 Listen --> [ 1d20=8 ]{39}
Intelligence check, +3 circumstance bonus.
> roll 1d20+8+3 Int
<Kobot> Iddy rolled 1d20+8+3 Int --> [ 1d20=17 ]{28}
> roll 1d20+31 Listen
Modify message
You can't quite make something out with the voice. Something is...wrong somehow, but you can't tell what.
Meanwhile, you focus your mind. A book seems to leap out to your eyes when you do, full of color despite the gloom of the library.
Surraruthru pulls the book out, inspecting it for traps before he opens it, while trying to identify what's wrong with the sound...
> roll 1d20+31 Listen
<Kobot> Iddy rolled 1d20+31 Listen --> [ 1d20=6 ]{37}
Ebony screams so loud it hurts your ears. "MOTHER!" she sobs, "MOTHERRRRR!"
> roll 1d100
<Kobot> Kotono rolled 1d100 --> [ 1d100=55 ]{55}
You check the book for traps and...
Search for traps real quick. Do you have trapfinding?
Nope.
> roll 1d20+24 Search
<Kobot> Iddy rolled 1d20+24 Search --> [ 1d20=19 ]{43}
Surrarutrhu opens the book, while still trying to identify what's wrong with the screams and voices.
> roll 1d20+31 Listen
<Kobot> Iddy rolled 1d20+31 Listen --> [ 1d20=3 ]{34}
Surraruthru
HP: 189/296
AC: 32+6
Init: +12, Touch Atk: 29
Active: Mindblank (CL25), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), 50% Spell Failure
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Moment of  Prescience, Energy Immunity (Fire)
The voice degenerates to pained sobbing. As Ebony cries and cries, you read the book.
It reads: Myr's Sword was the sort of a sentinel who defended a prophesied savior against the daemons. The blade reveals the truth of everything it strikes and banishes illusions and darkness. It was lost after Myr ventured in Hades to stop the fiends at their source. It is said he succeeded, but never returned from his mission. Since then, you recall it's been rumored to appear every so often across the planes, but usually briefly and without verification.
You recognize these words - your very own thoughts on the Sword of Myr, when you first recalled the lore you read about it.
Surraruthru considers... A catalog of his own knowledge, on this specific subject... Could this illusion be constructed of his own mind, and these books represent his own knowledge? If so, then it's possible he could directly manipulate the place... But if it's true, then whatever forms of his allies he finds would be simply representations... Unless they could serve as links to the minds of the others...
Surrauthru tries to will Ebony to appear before him, instead of searching for them, on a long shot, this time trying to ignore the voices he hears and focus on the pure voice of Ebony he remembers from their time together.
Intelligence check, +4 circumstance bonus.
> roll 1d20+8+4 Int
<Kobot> Iddy rolled 1d20+8+4 Int --> [ 1d20=8 ]{20}
