Surraruthru can see powerful arcane energy starting to gather around the blade.
Spellcraft.
> roll 1d20+34 Spellcraft
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 44 > [d20=10]
You can detect it is a burst of raw, powerful arcane magic. It's about to smash into the sword and likely obliterate it. With the shape the sword's in, you doubt even a powerful magical item would survive this.
Surraruthru wraps himself around the blade, trying to move it, readying himself to let loose a dispel against the building power.
Surraruthru
HP: 196/296 (100 Vile)
AC: 32+6
Init: +12, Touch Atk: 29
Active: Mindblank (CL25), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), 50% Spell Failure
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Energy Immunity (Fire)
Ability Damage: -4 Cha
> roll 1d100 Spell Failure
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 4 > [d100=4]
So much for that.
You rush forward, your magic coming apart. But it's too late.
The sword is engulfed in spellfire, burning bright blue. The battered blade bake and then breaks, shattering into scrap metal. "Ugh!" A cry of pain from ahead somewhere, a flash of white, heavenly light.
Surraruthru shakes his head to clear his vision of the bright light, searching for the source and looking for the scraps of the blade.
Kascha's at your side, while Sylvie flies to the blade. Ebony merely looks ahead, "Ahead," she points over a hill of books.
The blade is ruined, broken into a dozen pieces that are charred and burnt.
Surraruthru sighs at the loss of the sword, but doesn't lose hope. They'll just have to do this the hard way. With a good right hook and a lot of pent up anger.
"We might be able to do something with the shards if you want to collect them; but let's get this done either way."
With that, he takes to the air and heads over the books.
Kascha takes a moment to gather the shards and all of you hurry along.  You fly over the books and there is a figure there, kneeling. A shadowy, almost shapeless thing in the form of a man. Within it you see thousands and thousands of memories flowing, swirling. A dull white light surrounds him.
As you come over atop the hill, 50ft above and 60ft away from him, the figure stands. 'The sword is at last broken. Die.' It says impassively, coldly, like the lashes of a whip on your mind.
Chance to comment then we're probably going into init.
Surraruthru chuckles at this.
"For all your stolen knowledge, memories, and experience, you're still a fool, Secretus. The sword was powerful. It may have even been created to specifically counter you. But in the end, the sword was still a sword. It's power was meant to help its wielder. That's who truly has the power to beat you.
And, like I said. A dragon needs no blade. He has is claws, teeth, and own power. You will burn. You will break. You will die here. And it will be done to serve the glory of Seira and dragons. It will be done to give hope to all. And from it, we will take back the knowledge you have stolen. Your legacy will serve to do only one thing; make us STRONGER!"
> roll 1d20+51 Sylvie spellcraft
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 54 > [d20=3]
"The sword's power is lingering around him. It's forcing him here, but it won't last long," Sylvie says, cracking her knuckles.
'I am not forced here. You are forced here to die,' Secretus says.
"Silence, fiend!" Ebony steps forward, pausing to cough and spit out blood, "By all the laws of the heavens, you will be destroyed!"
As you speak, the books rise up. Images begin to form all around you as...
Init here. Good luck.
> roll 1d20+12 Init
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 17 > [d20=5]
I don't suppose the Spell Failure expired yet?
> roll 1d20+12 Surraruthru
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 22 > [d20=10]
> roll 1d20+24 Sylvie
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 25 > [d20=1]
> roll 1d20+8 Ebony
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 10 > [d20=2]
> roll 1d20+45 Secretus
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 64 > [d20=19]
Init is Secretus (64) > Sylvie (25) > Kascha (22) > Surraruthru (17) > Ebony (10)
Secretus opens.
'Die.' It is but one arcane words rise up from the books all around, forming a hissing chorus of fiendish words. Magic is wrought all around you, before a sheer wave of darkness engulfs you all.
He auto passes the SR check.
Fortitudes saves, all.
Kascha
HP: 183/271
Spells Active: Mind Blank (CL25), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Superior Resistance (CL25)
Bonuses: +1 morale attack/will saves, immunity to poison and disease
Resources Used: Greater elemental summon quickening
Sylvie
HP: 271/305
Spells Active: Mind Blank (CL25), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Greater Mighty Wallop (CL23), Endure Elements (CL23), Overland Flight (CL23)
Ebony
HP: 93/256 (-2 Strength drain)
Spells Active: Mind Blank (CL25), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Blinding Glory (CL22)
Resources Used: 3 dispel evil, 2 bardic music
Spell-like abilities
At will-aid, charm monster, color spray, comprehend languages, continual flame, dancing lights, detect evil, detect thoughts, disguise self, dispel magic, hold monster, greater invisibility(self only), major image, see invisibility, greater teleport (self plus 50 pounds of objects only); 1/day-wall of force. Caster level 23rd. The save DCs are 17 + spell level.
Kascha casts as a 23rd level wizard. (Caster level 26th for spells with the fire descriptor; caster level 25rd for other spells. +6 caster level bonus to overcome spell resistance.) The save DCs are 20 + spell level. Her spell themes are spells learned from Seira, fire magic and minor buffing. Her metamagic options are Empower Spell (+2), Maximize Spell (+3), Twin Spell (+4) and Quicken Spell (+4). She may apply the following metamagics to the following spells once per day without adjusting their casting time or spell level: Magic Missile, empower; Inner Beauty, quicken; Summon Greater Elemental, quicken.
[7/day]2: Glitterdustx2, Scorching Ray.
[8/day]3: Dragonskinx, Seira's Unicorn Arrowx2PHB2(1), Ray of Dizzinessx2SC, Ray of Exhaustionx2.
[6/day]4: Assay Spell Resistancex, Dragon BreathSC, Empowered Scorching Ray, Inner BeautyFC1, SR, Greater Mirror ImagePHB2.
[6/day]5: Empowered Fireball, Greater FireburstSC, Life's Gracex3SC, SR.
[6/day]6: Empowered Enervation, Surge of Hope
[6/day]7: Elemental BodySC, Limited Wish, Righteous Smite
[4/day]8: Dimensional Lock
[4/day]9: Mass Heal, Twinned Greater Fireburst, Empowered Righteous Smite, Wish
[4/day]10: Celestial ValorHome, Energy ImmunityHome
Sylvie casts as a 13th level chameleon (Caster level 23rd.) Her save DCs are 24 + spell level (arcane) or 15 + spell level (divine). Her spell selection themes are personal power and planar survival.
Arcane casting
[4/day]0: Detect Magicx2, Prestidigitationx2
[8/day]1: Improvisationx3SC, Magic Missilex2, Shieldx2
[8/day]2: Body of the SunSC, Detect Thoughts, Electric LoopSCx2, Resist Energyx2, See Invisibilityx2
[7/day]3: Amorphous FormSC,, Displacement, Greater Mighty WallopRD, Heroism, Sylvie's Speedy AppraisalHome, Vampiric Touch
[7/day]4: Assay Spell ResistanceSC, Attune Formx2SC, Dimensional Anchor, Dimension Door, Enervationx2
[7/day]5: IndomitabilitySC, Overland Flight, Teleportx2, Wall of Forcex2.
[7/day]6: Bite of the Weretigerx3SC, Disintegrate, Greater Heroismx2.
[3/day]7: Greater Teleport, Limited Wish, Waves of Exhaustion.
RD - Races of the Dragon.
SC - Spell Compendium.
Divine casting
[4/day]0: Create Waterx3, Cure Minor Wounds.
[5/day]1: ConvictionSC, Divine Favorx2, Foundation of StoneSC, Goodberry
[5/day]2: Aid, Lore of the Godsx3CC, Spiritual Weapon
[5/day]3: BlindsightSC, Cure Serious Woundsx3
[5/day]4: Death Wardx2, Divination, Divine Power, Freedom of Movement.
[4/day]5: Plane Shift, Righteous Mightx2, Spell Resistance, Zone of RevelationSC
[4/day]6: Healx4.
[1/day]7: Aura of VitalitySC
CC - Complete Champion
Arcane Dilettante casting. 9 spells with a maximum of level 8. Save DCs are 22 + spell level.
Bite of the Werebear, Cone of Cold, Enervation, Greater Mirror Image, Greater Invisibility, Greater Mighty Wallop, Greater Heroism, Polar Ray, Shield.
Ebony casts as an 23rd level bard. (Caster level 27th vs dispel) The save DCs are 20 + spell level. Her metamagic options are Consecrate Spell (+1) and Purify Spell (+1). Ebony may use Consecrate Spell and Purify Spell spontaneously without increasing the casting time of the spell.
[3/day]0: Dancing Lights, Detect Magic, Mage Hand, Mending, Prestidigitation, Summon Instrument.
[5/day]1: Alarm, Cure Light Wounds, Expeditious Retreat, Feather Fall, Grease.
[5/day]2: Alter Self, Cure Moderate Wounds, Glitterdust, Mirror Image, Silence.
[2/day]3: Charm Monster, Cure Serious Wounds, Fear, Gaseous Form, Major Image.
[3/day]4: Cure Critical Wounds, Greater Invisibility, Hold Monster, Modify Memory, Sirine's GraceSC
[4/day]5: Greater Dispel Magic, Mass Cure Light Wounds, Seeming, Song of Discord, Summon Monster 5.
[4/day]6: Mass Charm Monster, Mass Cure Moderate Wounds, SnowsongFrost, Veil.
[0/day]7: Heal, Rain of EmbersBoED(1d2 str drain), True Seeing, Vision.
Frost - Frostburn.
Ebony casts as a 22nd level sorcerer. (Caster level 26th vs dispel) The save DCs are 20 + spell level. Her metamagic options are Consecrate Spell (+1) and Purify Spell (+1). Ebony may use Consecrate Spell and Purify Spell spontaneously without increasing the casting time of the spell.
[5/day]0: Acid Splash, Arcane Mark, Detect Poison, Disrupt Undead, Flare, Light, Message, Open/Close, Resistance.
[7/day]1: Bless, Detect Undead, Endure Elements, Magic Missile, Vision of HeavenBoED.
[8/day]2: Blur, Command Undead, Consecrate, See Invisibility, Zone of Truth.
[8/day]5: Dismissal, Hallow, Heavenly LightningBoED, Sending, Sicken EvilBoED, S(1d4-2 str).
[5/day]6: Aspect of the DeityBoED, Bolt of GloryBoED, Storm of ShardsBoED(1d3-2 str drain).
[2/day]7: Greater Teleport, Holy Word, Righteous SmiteBoED.
[3/day]8: Greater Planar Ally, Polar Ray, Lightning RingSC.
[4/day]9: Blinding GloryBoED, Reaving DispelSC, Time Stop.
[2/day]10: Planet DefenderHome, Unseen NeedleHome
