> roll 1d20+53 (+12 Moore, +6 sacred)
<Serith> Zombie_Ko roll for Serith < 72 > [d20=19]
> roll 15d6 full but nothing else, lucky
<Serith> Zombie_Ko roll for Serith < 43 > [d6=6,4,4,1,1,2,2,2,3,1,5,2,6,2,2]
The tentacles do not touch you, but even then, you wither. The merest passing of them is enough to weaken you, tiny parts of you simply not there anymore. But it is endured as you dodge, then...
Surraruthru, go.
Finnegan
HP: 245/342
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Create Magic Tattoo (CL25), Create Magic Tattoo (CL25), Greater Mighty Wallop (CL25), Energy Absorption (CL28), Share Talents (CL13)
Bonuses: +1 morale attack and will saves, immunity to fear and poison, +1 luck attack rolls, +2 competence attack rolls, +2 size category for bludgeoning and unarmed weapons, resistance 10 to all elements, +2 swim checks.
Surraruthru dives back into the small crater he dug out of the thing's flesh before!
> roll 1d6 Flailing Strikes
<Serith> Iddy roll for Serith < 2 > [d6=2]
> roll 1d20+28+7 Unarmed
> roll 1d20+25+17+7 Unarmed
> roll 1d20+18+17+7 Unarmed
> roll 1d20+13+17+7 Unarmed
> roll 1d20+23+17+7 Bite
> roll 1d20+23+17+7 Claw
<Serith> Iddy roll for Serith < 52 > [d20=17]
<Serith> Iddy roll for Serith < 62 > [d20=13]
<Serith> Iddy roll for Serith < 55 > [d20=13]
<Serith> Iddy roll for Serith < 54 > [d20=17]
<Serith> Iddy roll for Serith < 66 > [d20=19]
<Serith> Iddy roll for Serith < 64 > [d20=17]
<Serith> Iddy roll for Serith < 56 > [d20=9]
> roll 1d20+28+17+7 Flailing Stirkes
<Serith> Iddy roll for Serith < 55 > [d20=3]
<Serith> Iddy roll for Serith < 66 > [d20=14]
> roll 1d20+23+17+7+11 Crit Bite
<Serith> Iddy roll for Serith < 59 > [d20=1]
> roll 7#3d8+10+2d6 (Unarmed)
> roll 1d6+10 (Bite)
> roll 2#1d4+10 (Claw)
<Serith> Iddy roll for Serith < 35, 25, 29, 24, 32, 34, 31 >
<Serith> Iddy roll for Serith < 12 > [d6=2]
<Serith> Iddy roll for Serith < 14, 14 >
Surraruthru
HP: 344/344+5(Temp)
AC: 78 = 38+20+4 (Deflection)+12(Moore)+4(sacred)
Init: +13, Touch Atk: 29, +4 to Attack Rolls
Active: Epic Mage Armor (CL 25), Mindblank (CL 28), Fortunate Fate (CL15), Planar Tolerance (CL7), Moment of Prescience (CL 25), Energy Absorption (CL 28), Celestial Valor (CL 25)
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Water Breathing, Magic Tattoo (+1 Luck to Attack), Magic Tattoo (+2 Competence to Attack), Mighty Wallop (Greater), Heroes' Feast (+1 Morale to Attack Rolls & Will Saves, Immunity to Fear, 1d8+1 Temp. HP.)
You rip and tear further as you smash through a hunk of green ice, the ascend continuing. You rip further into the thing, tentacles lashing you futilely. You sidestep another as you rip more flesh, having to abandon the hole you made and make another. Hunks of it are missing from your work and Finnegan's, strange blood and acid pouring. Nonetheless it's still going as Finnegan leaps aside, dodging half a dozen tentacles and plunging his spear down.
> roll 1d20+60 (+1 aura, +3 heroics +1 luck, +2 competence, +6 sacred, +20 Moore, -20 PA)
<Serith> Zombie_Ko roll for Serith < 65 > [d20=5]
> roll 1d20+55 (+1 aura, +3 heroics +1 luck, +2 competence, +6 sacred, +20 Moore, -20 PA)
<Serith> Zombie_Ko roll for Serith < 64 > [d20=9]
> OOC: Taking 10 on his third attack for 60 total.
> roll 1d20+50 (+1 aura, +3 heroics +1 luck, +2 competence, +6 sacred, +20 Moore, -20 PA, +5 weapon supremacy)
<Serith> Zombie_Ko roll for Serith < 56 > [d20=6]
> roll 1d8+87+3d6+1d6
> roll 1d8+87+3d6+1d6
> roll 1d8+87+3d6+1d6
> roll 1d8+87+3d6+1d6
<Serith> Zombie_Ko roll for Serith < 100 > [d8=1][d6=3,6,2,1]
<Serith> Zombie_Ko roll for Serith < 104 > [d8=2][d6=5,3,5,2]
<Serith> Zombie_Ko roll for Serith < 99 > [d8=1][d6=5,2,1,3]
<Serith> Zombie_Ko roll for Serith < 103 > [d8=1][d6=2,6,3,4]
Finnegan is a blur as he stabs over and over again. More blood begins to pour out with each wound, as suddenly it stops rising. For a single, crystal clear moment all is still. Then the tentacles go still and the beast begins to fall - fast! You're plunging down even faster than you went up, out of the clouds in a split second.
Free act, y'all. Under extremely specific time limits here due to the falling, so bear that in mind.
Surraruthru takes to the air, descending along with the corpse...
"Let's see where this lands!" Moore says as he pulls off from it to fly above it and follow it as best he can, casting a Haste spell on the himself and the others so they can try and keep up with it falling!
That is, of course, presuming this isn't part of that weird place he was in earlier where you can't fly...
Finnegan follows. All of you get up and off a few thousand feet above the ground. Far below you see the beast slam in like a meteor, a massive crater made that destroys the passage down. It lies in the center, twitches once and then ceases to move.
As you stand there and take it in, a platform with a portal on it appears.
"Where? Inside of it?" Finnegan remarks, "I don't see it wearing fancy jewelry or useful magic trinkets."
"...I think we're being asked politely." Moore says with a gesture at the portal, which he flies over to. "Let's not keep our host waiting, it would be unsightly. I have a feeling if there is anything down there we'll end up with it in some form."
"Who knows what it ate, but yes, portal."
Surraruthru fies towards the portal.
The party goes through the portal. You stand in a room of glittering well. All around you in a 50ft radius are great heaps of gold and platinum coins. Just heaps of them. From beyond to 100ft around are ingots of precious metals, gems, works of art and jewelry, just laying about. At the end of that are the walls, where weapons and shields of magnificent make hang.
You have one suddenly, overwhelming instinct - you barely have time in here, perhaps a several seconds. Hurry before you never see this place again.
Act, y'all. You have one round's actions, use it wisely.
#791
Surraruthru begins chanting a spell, hoping to buy more time.
Time Stop, CL 25
<IronDragoon> roll 1d4+1 Time Stop
<Serith> IronDragoon roll for Serith < 3 > [d4=2]
He's pretty sure this won't work, but he's willing to try it anyway -- Moore clicks his boots together to see if time itself stops to give him just an extra moment...!
Boots of Temporal Acceleration
