The gaps are a little over a foot wide. Swimming and elongated you should be able to, but most bigger things couldn't.
Alright, I'll wait for Yuth or Bubbles to have the elementals grind away the earth holding it in place.
Calleigh approaches over Bubbles' left shoulder, trailing Tryll-mist. She has had hands on her hips and a cute frown on her face. "Well, this is super duper gross. Ugh. Ew! Noooope!"
With a soft pop, her tiny form is replaced by an equally-tiny ball of soft light. "There! That's better. No more nose!"
To the group, Tryll's placid and watery tones fill their minds, 'Quite. Let's proceed, then.'
To the elementals, 'Quietly, if you would?'
The grate is taken down with a mix of earth adn water elementals. The rusted thing nearly falls apart as it's put aside, dropped into the waters as a gush of debris-filled water his the stream.
"Alright everyone!" Bubbles says, "I'm in contact with Aurora and our best maps of this. We go ahead and then begin to split up to clear out locations."
In your minds Bubbles sends, 'The vanguard and siege units are doing well so far, but it's early. Diabolical resistance hasn't kicked in full yet.'
'They will, soon. I can't imagine this us anything other than an attempt to lure us in. Let us go further and see what we run into.'
Quick question, where are Tryll'n'Surraruthru relative to the army? On point, in the middle, in the back or something else?
Might wanna be in the middle. We can coordinate better. None of us are dedicated front-liners.
Okay, who's your frontliner then?
Bubbles will join you in the middle.
I'd probably be the closest of the four of us to a front liner.
Earth and water elementals in the front pls. Remember they scoutin'.
The group proceeds into the tunnel - really just a large sewer full of unpleasant water and dark. Fortunately darkvision and your own light sources are both sufficient to see - about 100ft down you can see a barricade. Raised wooden platforms just out of the water, the way blocked by wooden debris. Here several barbazu stand as well as several mortal archers and a single erinyes. Perhaps two dozen enemies in all, arrows already flying at the water elementals.
The water elementals surge ahead, while earth elementals begin to poke out of the walls. Courre scouts fall back and fling magic missiles, while phase spiders climb the walls and cautiously approach.
Chance to act or give commands. If you're going to directly join the battle we'll do init.
Surraruthru calls on his innate power as a Faerie Dragon and breathes false life into the barricade, pulling the boards and nails of the platforms into the battle by having them harass, attack, and tangle up the devils and archers, hopefully distracting them and keeping them off balance.
Animate Object, CL 25, Duration 25 rounds
Animate 25 small objects, 2 small = 1 Medium, 4 Small = 1 Large, 8 Small = 1 Large, 16 Small = 1 Garganutan, 32 Small = 1 Clossal.
Intent is to animate the platforms in their entirety, and if there are small objects left over, the nails and such as flying darts.
Surraruthru
HP: 347/347, Speed: 100 ft, 140 ft fly, 100 ft swim.
AC: 64 = 38+20(EMA)+4(Deflection)+2(Stat)
Touch AC: 21, Flat Footed: 24, SR: 35, CMB: 29, CMD: 45
Init: +13, Touch Atk: 38, ATK: 38/35/28/23
Active: DR 10/magic, 10/adamantine, +2 Init, +5 ATK, +2 AC, Resistance 10 Acid/Cold/Elec/Sonic, Immunity to poison/sleep/paralysis/stunning/crits/flanking, +1 ATK in water, Drench
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Energy Absorption CL 26, Elemental Body: Water CL 26, Agility of the Dragon Princess CL 26, Strength of the Dragon Princess CL 26, Mind of the Dragon Princess CL 26, Mind Blank CL 26, Stoneskin CL 26 (260 min), Spell Turning CL 26 (260 min), Moment of Prescience CL 26, Superior Mighty Wallop CL 26, Epic Mage Armor CL 26
Magic Items
Gauntlets of Fell the Greatest Foe: +1d6 damage to target for every size category larger than you it is
Boots of Swift Passage: 20-foot teleportation as a move action 5/day.
Headband of Conscious Effort +15: +15 Competence bonus to Concentration checks, 1/day make a Concentration check in place of Fort save.
Wounding Amulet of Natural Attacks and Adaptation +8: +8 to Natural Attacks (Bite, Claw, Claw), all attacks deal 1 Constitution Damage, immune to all harmful vapors and gases (such as cloudkill and stinking cloud effects, as well as inhaled poisons) and allowing him to breathe, even underwater or in a vacuum.
Calleigh is manifesting psionics! Psicrown activate, form of...
With a squishy nouse, a massive form assembles itself from the air and charges down the tunnel toward the barricade!
It's an astral construct! It's charging, it's got Pounce, and it's ready to ruin everyone's day! Hurray!
Those count as direct action, so let's do init.
