I have Duelward if not. Which means I can counter spell his dispel.
#316
Miss chance definitely applies to that. I also have Glaciante's spiteful ward, so if he successfully dispels my epic mage armour (which is what he should make the first check against) then he needs to make a DC 35 will save or take 4 points of ability drain to all stats and auto-fail every dispel check he makes from then on unless fixed via miracle or wish.
I'll let Afina have her miss chance.
Okay, I'm going to rule spell turning applies before miss chance. I'll read up on it more later and see if this is covered anywhere official, but for now that's how I'm rolling with it.
Afina has 9 levels of spell turning and it's an 11th level spell, so...18% chance of it getting through, otherwise it is turned back on him.
> roll 1d100 1-18 Emopixie time
<Serith> Kotono roll for Serith < 46 > [d100=46]
Reeeeflected.
> roll 8#1d20+37
<Serith> Kotono roll for Serith < 45, 52, 43, 47, 51, 46, 51, 54 >
Magic collapses around the Nessian, a sound like a window breaking echoing through the halls as...
Init is Afina (52) > Nessian (35) > Fenrir (31) > Garm (28) > Surraruthru (17) > Bubbles = Elementals (16.1) > Tryll (16) > Misalea (14) > Dana (11) > Calleigh (10) > Construct 1 (8) > Construct 2 (3)
Wolves are up. Go.
Fenrir and Garm both split off to come at the Nessian's flanks, fangs bared as they each take a bite before splitting back off again!
They have spring attack so no AoOs provoked.
[22:43] <@Ebiris> roll 1d20+41 Garm flanking
[22:43] <Serith> Ebiris roll for Serith < 60 > [d20=19]
[22:43] <@Ebiris> roll 1d20+41 Fenrir flanking
[22:43] <Serith> Ebiris roll for Serith < 55 > [d20=14]
[22:43] <@Ebiris> roll 2d6+25+10d6 and dimensional anchor Garm
[22:43] <Serith> Ebiris roll for Serith < 74 > [d6=3,4,4,5,3,3,2,6,4,6,3,6]
[22:43] <@Ebiris> roll 2d6+25+10d6 and dimensional anchor Fenrir
[22:43] <Serith> Ebiris roll for Serith < 66 > [d6=2,3,3,6,1,3,2,4,2,5,6,4]
Flanked and surrounded, the Nessian is bit twice. He grimaces and holds his ground as the wolves savage his legs, then...
Surru.
Surraruthru begins casting again, mimicking his last spell!
Time Stop, CL 26.
> roll 1d4+1
<Serith> Iddy roll for Serith < 5 > [d4=4]
Round 1: Might of the Planetar, CL 26, Duration 26 rounds, Tapestry.
You gain a +16 enhancement bonus to Strength, a +2 enhancement bonus to Dexterity, a +8 enhancement bonus to Constitution, and a +7 enhancement bonus to natural armor. You gain a slam attack that inflicts 2d8 + 1.5 times your Strength modifier. You gain the benefits of the blind-fight and power attack feats as well.
Round 2: Celestial Valor, CL 29, Duration 29 Minutes, 29 creatures targeted (Tryll, Calliegh, Surraruthru, Afina, Dana, Misalea, Bubbles, Fenrir, Garm, other non-named NPCs for the rest/Elementals)
+8 sacred bonus to saving throws against fear and any emotion based effect that would sap the will to fight, such as calm emotions or crushing despair. In addition, celestial valor grants a +4 sacred bonus to attack rolls, weapon damage rolls, armor class and saving throws. Finally, any weapon they use counts as a holy weapon for the duration, granting 2d6 extra damage against evil targets.
Round 3: Greater Heroism, CL 26, 26 minute duration, Tapestry.
+4 morale bonus on attack rolls, saves, and skill checks, immunity to fear effects, and temporary hit points equal to your caster level (maximum 20).
Round 4: Shield, CL 29, Duration 29 Minutes, Tapestry.
+4 shield bonus to AC.
Move: Activate Quiescent Weaving, releasing the four Resist Energy spells I preloaded for Resist 30 to Acid, Electricity, Fire, Sonic.
Round 5:
Standard: Pull out my Everfull Mug and drink a bit of clean water. That sewer put a foul taste in when I was swimming. Use the rest of it to wash scum off of my scales. Gotta look good, after all.
Move: Fly through one of the holes in the Wall of Force and land behind the Pit Fiend.
Surraruthru
HP: 294/347
AC: 68 =38+4+5+6+7+4+4 (Def/Barkskin/GMA/MoP/CV/Shield)
Init: +13, Touch Atk: 37, ATK/Damage: +8, +2 extra attacks (Haste/Slam), +2d6 Holy Damage
Active: Mind Blank (CL20), Freedom of Movement (CL20), Superior Resistance +6 Saves (CL20), See Invisibility (CL20), True Seeing (CL20), Death Ward (CL20), Barkskin (CL20), Greater Mage Armor (CL20), Celestial Valor (CL29), Might of the Planetar (CL26)
One fly in the ointment: You can't target other creatures with effects in timestop. The only exception is area effects that have a duration that exceed the time stop's duration. The tapestry doesn't allow you to apply spells to creatures that are an illegal target, it explicitly says this.
I guess I'll just have the buffs for myself, then.
Init is Afina (52) > Nessian (35) > Fenrir (31) > Garm (28) > Surraruthru (17) > Bubbles > Tryll (16) > Misalea (14) > Dana (11) > Calleigh (10) > Construct 1 (8) > Construct 2 (3)
In a blink Surraruthru is there, across distance faster than any can follow. He's ready as Bubbles pauses and then...
Bubbles will hold and be the emergency mass heal-er. Tryll, go.
Twin strokes of black lightning arc from Tryll's mostly-invisible form.
Twinned Stygian Bolt. Rolling for SR.
[blockquote]Rolled 1d20+27 : 6 + 27, total 33[/blockquote][blockquote]Rolled 1d20+27 : 2 + 27, total 29[/blockquote]
No joy for that one. Anything else happening on your turn or is that it?
I can do swift actions at any point on my turn, yes?
