'Alright, I'm taking command,' she says since she sees no point pussyfooting around a point of diabolic fortification beneath their freshly taken city. 'Bubbles, have our aquatic forces prepare to move in on my signal. I'm going to puncture the outer walls and then raise the water level to flood the interior of the fortress. Devils aren't known for their swimming skills. Tryll, you take all our flight capable forces to take position above the fortress and attack exposed devils on its upper surface. Surraruthru and I will join our aquatic forces in purging the interior once the assault is underway.'
'Healthy warniess is what's kept me in my state of pseudo-life for a very long time, Afina.' Tryll interjects. 'The dragon has a point. Something this well-defended likely has a surprise or two hidden, and I would hate to detonate some sort of bomb under the city we're in the process of liberating.'
'If that's the case then all the more reason to excise these devils immediately. The surface of the city is ours and they have no reason not to employ scorched earth tactics on it if they possess the ability,' she points out. 'Everyone take positions.'
Surraruthru mentally shrugs and slips into place, readying himself to go into the assault, but taking a moment to cast Spell Turning into the Tapestry again.
Note that everyone who had expired spell turning that's with us now has it again. Also, did anyone cap off our HP? I'm not hurt bad or anything, but I know Bubbles was tossing heals around.
Surraruthru
HP: 294/347
AC: 68 =38+4+5+6+7+4+4 (Def/Barkskin/GMA/MoP/CV/Shield)
Init: +13, Touch Atk: 37, ATK/Damage: +8, +2 extra attacks (Haste/Slam), +2d6 Holy Damage
Active: Mind Blank (CL20), Freedom of Movement (CL20), Superior Resistance +6 Saves (CL20), See Invisibility (CL20), True Seeing (CL20), Death Ward (CL20), Barkskin (CL20), Greater Mage Armor (CL20), Celestial Valor (CL29), Might of the Planetar (CL26)
Calleigh did some wand heals on one of my dogs but that's all that I saw mentioned.
Afina: 239/287, glaciante's spiteful ward (CL 27 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 25), see invisibility (CL 25), greater heroism (CL 25), interplanar telepathic bond (CL 24), shield (CL 25), magic tattoo (CL 26), magic tattoo (CL 26), energy absorption (CL 26), stupendous dragonskin (CL 26), seira's agility (CL 26), seira's strength (CL 26), seira's mind (CL 26), mind blank (CL 27), stoneskin (CL 26), control weather (CL 27), scalding touch (CL 27, SR 45), shadow form (CL 25), moment of prescience (CL 25), spell turning (CL 26)
AC 97, spell resistance 40, blindsense 30, immunity to fire, water, earth, cold, disease, poison
Spell charges: 5/0/8/4/1/8/6/5/0/0/0/1
20 uses left on blistering/searing scalding touch
Fenrir: 322/370, heroes feast (CL 20), greater mage armour (CL 7), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), haste (CL 25)
AC 43, spell resistance 25, freedom of movement, immunity to electricity, exhaustion, mind affecting, fatigue, fear, poison
Garm: 92/370, heroes feast (CL 20), greater mage armour (CL 7), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), haste (CL 25)
Attack: +39 (2d6+25) +10d6 skirmish, dimensional anchor
Tryll goes down and looks. It's solid ground, but it pulses with dull green light. The stone below is suffused with it.
Quick Spellcraft
<Serith> Yu roll for Serith < 59 > [d20=18]
Tryll can tell the light is a massive field of expanding magic that will destroy the the earth below and around in a great radius. Possibly city-sized. It also radiates overwhelming transmutation.
'Well! Good news bad news time, friends! First of all, the bad news: There is a very large explosive ward in here! It would likely level the city, or most of it, if triggered. The good news is that we have not yet triggered it and I may be able to dispel it.' Tryll sends back.
'Can you dispel it from where you are or do we have to be at the anchor?' Afina asks tersely. 'And can you tell if it's primed or needs time to charge up?'
Tryll takes a very close look at the spell!
What is it exactly, what's it do, how long, etc. What do I need to do here?
You'd need to get it at whatever's anchoring it, the center. You can tell it's the same anchor point as the fortress spell, somewhere in there.
Somewhere in the fortress. You could follow it, sure.
'This could take a while. It's anchored somewhere. I'm going to try to find the anchor without setting it off and killing us all. I'll keep you posted.'
Time to start the investigation train.
