Liber (Jaela, Moore)
Started by Anastasia, February 09, 2017, 02:33:24 PM
From here, Afina can see the arm sizzle as it doesn't stop - just an arm, filling up the passage, connecting to something far larger below. It doesn't seem remotely deterred by the flames.
Moore, go. Sylvie after you.
#196
"If you choose to use magic, then focus on overcoming its resistances!" Moore calls to his allies. "However, if you'd rather strike, then strike!"
Swift action to switch aura from Dexterity bonus to Determined Caster, so everyone gets +12 to bonuses to overcome SR.
Move action (via Harmonize) to use Inspire Courage, +14 to attack, weapon damage, and charm and fear saves.
Standard action to use Destined Strike, +3 to attack and weapon damage, improved crit feat, and +12 to confirmation on crit rolls.
Inspire Greatness is still in effect and will start counting down after this round.
This gives everyone the following total bonuses:
Attack: 14 (morale, inspire courage), +8 (competence, greatness), +3 (untyped, destined strike) +2 (untyped, bonus from harp)+1 (circumstance, aura) = +28
Weapon damage: 14 (morale) +3 untyped = +17
Bonus to overcome SR = +12
+2 to CL for spells (sorry, I forgot about this before but it's part of his repertoire)
+4 competence bonus to fort saves
Active Spells:  fortunate fate (CL15), planar tolerance (CL7), Superior Resistance (CL 24), Conviction (+4 saving throw), Tyche's Touch (+3 sacred saving throw), Harmonize (CL25), Greater Improvisation (CL25) (49 points left), Share Talents (CL25), Divine Insight, Surefooted Stride (CL25)
HP: (4)311+40/311
AC: 61, 32 touch
13/25 Bardic music uses, Refrain 0/3
Spells:
0th - 7/7 (DC 21)
1st - 4/7
2nd - 3/7
3rd - 2/6
4th - 6/6
5th - 1/6
6th - 3/5
7th - 5/5
8th - 1/2
Favored Soul:
0th - 9/9
1st - 9/9
2nd - 5/9
3rd - 7/8
4th - 8/8
5th - 7/8
6th - 6/7
7th - 4/4
+1 Luck Bonus on Attack Rolls
[/spoiler]
Sylvie nods and flies through, into the mess outside. She draws 21 as she hovers above it and lets it loose, light engulfing the hand.
> roll 21d12+21 she was going to melee, but that wall of fire changed her mind
<Serith> Kotono roll for Serith < 149 > [d12=6,9,4,5,12,1,11,4,8,8,10,1,3,5,12,7,10,1,3,5,3]
> roll 1d20+24 evasion
<Serith> Kotono roll for Serith < 33 > [d20=9]
The hand is badly scorched and pitted from the light, parts of it simply gone as if they were never there. Yet it still holds on and is beginning to rise up as...
Jaela.
And that is where Jaela swoops in for the kill!
[20:11] <@Rin> roll 1d20+58+5+1+2+14+2+8+3+2+1+20-22 divine might, diving charge smite, lunging strike, true strike, 22pa
[20:11] <Serith> Rin roll for Serith < 98 > [d20=4]
+2 more since it's an evil outsider, +1 more if Haste is up
[20:15] <@Rin> roll 5d8+305+110+70+25+15+70+15+10+2d6+4d6 last is goldenfire, smite, 1 con damage
[20:15] <Serith> Rin roll for Serith < 668 > [d8=8,5,7,2,6][d6=5,4,2,4,2,3]
Divine Might 14/14 rounds
Init +13
HP: 457+47/490
AC: 73 =65base+1AotDP(armor max dex +8)+2Foresight+5SoW, 20% miss chance (airborne creatures take a -1 penalty on attack rolls and damage rolls against you).
Full Attack (Gae Bolg, GMW, HW, K:D +5, CMT +1luck, CMT +2competence, HF +1morale/GH +4 morale, SofDP +2 attack/+3 damage, DM, vs devils only): +59/+54/+49/+44 or +63 AoO, 2d8+56+8d6+4d6 last is goldenfire
Spells Active: Energy Absorption CL 26, Create Magic Tattoo x2 CL 26, Elemental Body/Air CL 26, Surraruthru's Stupendous Dragonskin CL 26, Agility of the Dragon Princess CL 26, Strength of the Dragon Princess CL 26, Mind of the Dragon Princess CL 26, Stoneskin CL 26, Spell Turning CL 26, Contingency CL32, Permanency/Greater Blindsight CL32, Permanency/Mantle of Good CL33, Foresight CL25, Conviction CL29, Longstrider CL23, Divine Insight CL28, Lore of the Gods CL28, Mind Blank (CL26), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Righteous Halo CL28, Greater Heroism CL28, Tyche's Touch CL14 (+4 sacred to next save), Share Talents CL14 (+2 untyped to skills), Moment of Prescience CL23, Good Hope CL28, Shield of Warding CL28, Crown of Flames CL28, Mass Death Ward CL24.
Resistances and Immunities: Fire Immunity, Cold Resistance 10, Acid Resistance 20, Electricity Resistance 20, Sonic Resistance 20, Damage Reduction 25/Epic and Evil and Cold Iron (10/Adamantium from Stoneskin), Spell Resistance 35 (45 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Immunity to fear and poison/Heroes's Feast, Never surprised or flat-footed/Foresight, Immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking/Elemental Body (Air).
Spells Left (1-9): 8/9/8/1/8/5/8/2/6
Spells Left (10-11): 6/2
Saves: Fort +61, Ref +62, Will +61
-True Strike x4
-Turning x5
-Teleport x1
-Greater Teleport x1
-Moment of Prescience x2
-4 smite
-True Seeing component x1
-Stoneskin 120/150
Jaela swoops in amid the flames, enduring them as she stabs into the creature's arm. It explodes into goldenfire, burning away to nothing as she impales it all the way through. Hail continues to fall in the meantime, pummeling both you and Sylvie.
Ref saves, you two.
[18:27] <@Ebiris> roll 1d20+42 evasion
[18:27] <Serith> Ebiris roll for Serith < 53 > [d20=11]
[20:26] <@Rin> roll 1d20+62 evasion
[20:26] <Serith> Rin roll for Serith < 74 > [d20=12]
> roll 1d20+48 12/13 inspiration
<Serith> Kotono roll for Serith < 67 > [d20=19]
Hail continues to fall but you dodge. As you do, Mirajane's eyes widen, "It's coming! The rest of it!" she shouts, preparing.
Readying a mass heal if it's needed, since she can't do a lot directly at the moment. Impure spirit is up.
The ground all around you - far more than just where the hand broke through - explodes up in a rain of shards. As you endure that, the creature emerges. Far larger than a titan or even a dragon, it looms over a hundred feet tall. It is roughly humanoid and male, beautiful to look at. It is missing its left arm and looks furious as it raises its foot up to stomp Jaela flat.
Its movement provoked an AoO from you, Jaela. You can take it if you like.
Though in an awkward position, Jaela seizes upon her chance!
[20:35] <@Rin> roll 1d20+43+5+1+2+14+2+8+3+2+1-22+4 AoO
[20:35] <Serith> Rin roll for Serith < 75 > [d20=12]
[20:36] <@Rin> OOC: +3 more
[20:37] <@Rin> roll 1d8+29+44+14+5+3+14+3+2+2d6+4d6 last is goldenfire
[20:37] <Serith> Rin roll for Serith < 136 > [d8=3][d6=4,1,3,4,1,6]
Also I realized I forgot 110 more damage from the previous attack.
Init +13
HP: 457+47/490
-True Strike x4
-Turning x5
-Teleport x1
-4 smite
-Stoneskin 120/150
It's a stab straight up, managing to impale the shin of the creature. Goldenfire spreads and burns through it, but slowly. It resists, the wound merely a pinprick as its other foot comes on down.
> roll 1d20+50 vs Jaela AC
<Serith> Kotono roll for Serith < 62 > [d20=12]
Whiff.
Yet Jaela's not there anymore, already gone and safe. She leaps back, avoiding the crater-making impact as...
Afina.
Alright, time to start stabbing! Flying at and past the creature, Afina delivers a pair of deadly stabs from her tiny blade against the giant monster!
Using Afame as swift for +4 dodge
[19:02] <@Ebiris> roll 1d20+77 stab
[19:03] <Serith> Ebiris roll for Serith < 83 > [d20=6]
[19:03] <@Ebiris> roll 1d20+72 stab
[19:03] <Serith> Ebiris roll for Serith < 82 > [d20=10]
[19:03] <@Ebiris> roll 1d4+41+2d6+2d6+2d6+5d6+2d6
[19:03] <Serith> Ebiris roll for Serith < 87 > [d4=1][d6=6,1,1,3,4,1,1,5,3,3,5,6,6]
[19:03] <Serith> Ebiris roll for Serith < 94 > [d4=4][d6=1,5,5,6,1,3,1,4,5,5,6,2,5]
Afina: 303/303, glaciante's spiteful ward (CL 27 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 25), see invisibility (CL 25), interplanar telepathic bond (CL 24), magic tattoo (CL 26), magic tattoo (CL 26), energy absorption (CL 26), stupendous dragonskin (CL 26), seira's agility (CL 26), seira's strength (CL 26), seira's mind (CL 26), mind blank (CL 27), stoneskin (CL 26), control weather (CL 27), scalding touch (CL 27, SR 45), moment of prescience (CL 25), spell turning (CL 26), Tyche's Touch (CL 14), Mass Conviction (CL 14), Share Talents (CL 14), shield (CL 25), haste (CL 25)
AC 103, spell resistance 40, blindsense 30, immunity to fire, water, earth, cold, disease, 50% miss chance, freedom of movement,
Spell charges: 5/0/6/2/0/7/4/1/0/0/0/0
18 uses left on blistering/searing scalding touch
2 points vile wisdom damage
Init is Afina (63) > Screaming Face (60) > Moore (54) > Sylvie (53) > Jaela (34) > Mirajane = Impure Spirit (20)
Afina zips around the massive spirit as she attacks again and again, rising up and leaving little cuts all over its body. It's as if a titan is trying to be worn down by papercuts, as the ground and world shakes again.
"NO!" A man's voice cries in anguish, "GIVE IT BACK!" Earthquakes intensify, the skies turning pitch black.
At the same time, you can see it, 400ft ahead. A blur of black, a screaming face trailed by energy. It's howling in fury and racing right towards all of you, too.
Go Moore.
Moore moves ahead to keep up with the others and continues to offer them inspiration!
He's maintaining Inspire Courage for now.
Destined Strike and Greatness have 10 rounds left.
Sylvie meanwhile flies around the creature, pointing at the onrushing face ahead. An invisible field of force appears, shimmering once briefly, 100ft ahead of it. It breaks its open charge towards all of you.
Jaela.
Leaving Sylvie to face the other threat, Jaela slips into her favorite stance for combat and strikes at the titan's wounded foot repeatedly!
[21:36] <@Rin> roll 1d20+56+28
[21:36] <Serith> Rin roll for Serith < 94 > [d20=10]
[21:36] <Serith> Rin roll for Serith < 95 > [d20=11]
[21:36] <@Rin> roll 1d20+51+28
[21:36] <Serith> Rin roll for Serith < 90 > [d20=11]
[21:36] <@Rin> roll 1d20+46+28
[21:36] <Serith> Rin roll for Serith < 80 > [d20=6]
[21:36] <@Rin> roll 1d20+41+28
[21:36] <Serith> Rin roll for Serith < 73 > [d20=4]
[21:38] <@Rin> roll 2d8+56+8d6+17+14+4d6 last is goldenfire
[21:38] <Serith> Rin roll for Serith < 138 > [d8=6,1][d6=3,5,6,4,3,5,4,4,2,1,3,4]
[21:38] <Serith> Rin roll for Serith < 144 > [d8=4,5][d6=3,4,4,1,5,4,1,6,3,5,6,6]
[21:38] <Serith> Rin roll for Serith < 144 > [d8=1,8][d6=5,3,5,6,4,4,1,4,5,1,5,5]
[21:38] <Serith> Rin roll for Serith < 139 > [d8=6,4][d6=6,1,3,4,4,1,4,1,6,5,1,6]
[21:38] <Serith> Rin roll for Serith < 140 > [d8=6,6][d6=2,3,1,4,4,6,6,5,4,3,1,2]
Gambit.
"Mirajane, get over here!" she calls out to her daughter in-between her strikes. "Let's hit it together, like we practiced!"
This is where I'd like Mirajane and I to use Twin Gambit from the Angelfeather Stone.
Angelfeather Stone: This stone enables the combination magic 'Twin Gambit.'
Twin Gambit
Users: One creature that has the feat Robilar's gambit and one creature with combat reflexes.
Positioning: Users must be adjacent to one another.
Duration: 1 round.
Saving Throw: None.
On using this combination magic, the user with combat reflexes moves into the same square(s) as the user with Robilar's gambit. The users must be the same size, with the sole exception of small and medium creatures. These two types of creatures may use this ability together. Both creatures offer up Robilar's gambit, and both gain an AoO whenever Robilar's gambit is triggered on either of them. If one of the users is dropped during this combination magic, the other keeps the benefits of Robilar's gambit for the rest of the round, including gaining an AoO against the creature who dropped the other use. This combination magic may be repeated each round as the users wish. When the users cease to use it, the user with combat reflexes must immediately leave the other user's square.
Divine Might 13/14 rounds
Init +13
HP: 490+47/490
AC: 74 =65base+1AotDP(armor max dex +8)+2Foresight+5SoW+1Haste, 20% miss chance (airborne creatures take a -1 penalty on attack rolls and damage rolls against you).
Full Attack (Gae Bolg, GMW, HW, K:D +5, CMT +1luck, CMT +2competence, +1 Haste, SofDP +2 attack/+3 damage, DM, vs devils only): +56/+56/+51/+46/+41 or +60 AoO, 2d8+56+8d6+4d6 last is goldenfire
-True Strike x4
-Turning x5
-Teleport x1
-4 smite
-Stoneskin 120/150
