Deeper into the sewers (Surraruthru)
Started by Anastasia, February 10, 2017, 03:26:17 PM
"Elementals, do what you can to stabilize the area!"
'Tepen, this whole area is shaking like an Earthquake. White flash and something howling.'
Can I tell if the howl came from the same source as the dragon roar?
'Multiple reports, hold on and hold position,' Tepen commands, as the elementals do just that.
Winds blow through the tunnel, a woman's voice declaring, "Return to Hell or die!"
Surraruthru holds position for a moment, letting the winds slice around him, feeling restless...
'... Tepen, I think I should keep going on. I get the feeling whatever dragon is down here may not be what I thought. That voice just sent wind through the sewers. That means at least a portion of the power backing it is down here, I think... I'm going to keep going, but I'll keep in the shadows and be careful.'
With that, Surraruthru keeps going towards the sound of the dragon roar and winds, using every bit of stealth he can.
Can I take 10 on the hide/move silently checks?
'Surraruthru,' Tepen sends, 'I've received word this is the result of Semyaza, Alicia and Syala crossing blades. All forces have succeeded faster than anticipated, the battle for Benfal has begun earlier than expected. All possible forces, refugees and prisoners are being returned to Aurora with all haste, as conditions will continue to deteriorate. The battle of deities and an archdevil on the Prime will bring about apocalyptic conditions.'
Surraruthru contemplates for a moment, considering his nature, where he is, the roar and voices, and Seira.
'... Tepen, I'm continuing. I have Gate prepared. If need be, I'll go back to the Cauldron for evacuation. I have... an unusual feeling that I need to continue and find the source of this. I'll send the elementals back unless they volunteer to stay, but I think this is something I'm supposed to do.
... If I die, give all my things to Kascha.'
With that, he continues forward.
Surraruthru
HP: 282/347
AC: 53 =38+4+5+6 (Def/Barkskin/GMA)
Init: +13, Touch Atk: 37, ATK/Damage: +4,
Active: Mind Blank (CL20), Freedom of Movement (CL20), Superior Resistance +6 Saves (CL20), See Invisibility (CL20), True Seeing (CL20), Barkskin (CL20), Greater Mage Armor (CL20), Spell Turning (CL29), See Invisibility (CL20), True Seeing (CL20), Greater Heroism (CL26)
'Very well, General Afina has signed off on this. Good luck,' Tepen sends to you.
Just trying to track down the roar?
Yep. I have suspicions about what's going on, so I want to track down the roar.
You fly through the tunnels as fast as you can. They shake and quake before you as you fly on, earthquakes shaking everything around you. As you fly along you hear another roar, closer. You're getting closer, you just know it.
It's then that the wall to your left bursts open, ice lined with purple fire exploding out in a jagged rain. A fiendish voice screams in pain from all around you.
Reflex save.
> roll 1d20+29 Reflex
<Serith> Iddy roll for Serith < 45 > [d20=16]
You dodge and roll ahead, avoiding it as you fly along. You dive into the waters and down as a hunk of ceiling falls, emerging up past it safely. Around a corner, hurrying as you see part of the walls ahead melting into a rainbow colored slurry, before shifting into unusual geometric patterns. It hurts to look too closely at them.
Another dragon's roar. Closer. You're getting closer as the apocalypse unfolds around you. It's just ahead, you think, as the water in the tunnel boils away in an instant, leaving behind a black crust on the now dry tunnels.
Surraruthru continues cautiously, believing more and more his suspicions are correct, maintaining both stealth and cover as much as he can, keeping on his toes for more magical surprises as he inspects the magical forces happening around him.
Checking for magical instability or twisting of spells so I can be ready for it if I need to cast or something.
Detect magic-ing? Make Spellcraft if so.
Yes, detect magic. Need someone to roll for me. Dunno how the forum roll works. Need to learn later.
[blockquote]Rolled 1d20+37 : 7 + 37, total 44[/blockquote]
The magic around here is going wild. There's a chance any spell cast could react in unpredictable ways.
