Salvation at last (Tryll)
Started by Anastasia, February 20, 2017, 04:07:59 PM
Both hit. Make a caster level check if it allows SR/PR, otherwise go to damage.
Muhuhahaha no SR/PR!
Initial damage!
[blockquote]Rolled 8d6 : 2, 6, 4, 5, 3, 5, 2, 5, total 32[/blockquote][blockquote]Rolled 8d6 : 2, 2, 4, 3, 4, 6, 3, 4, total 28[/blockquote]
Secondary damage![blockquote]Rolled 20d6 : 2, 3, 5, 5, 4, 6, 5, 6, 5, 3, 5, 4, 2, 3, 3, 2, 5, 2, 4, 5, total 79[/blockquote][blockquote]Rolled 20d6 : 3, 4, 5, 3, 5, 2, 1, 5, 6, 1, 3, 1, 4, 6, 5, 6, 5, 3, 4, 5, total 77[/blockquote]
Calleigh elects to spend her entire round taking a double move action, escaping the field to join Tryll.
Also![blockquote]Rolled 1d4 : 2, total 2[/blockquote] Multiply that by 10! He moves that many feet and now faces a random direction! Kn owing this is the Astral, he could eisily be cacing any direction on X, Y, or Z axes.
Your tornadoes slam into the great creature - so large that you just barely  move it, the winds battering it to little visible effect. However, it's turned away from the party now, thankfully.
Mei (31) > Fantase = Patar (22) > Rosa (18) > Tryll = Calleigh (17) > Astral Dreadnought (14)
Just in time for it to turn around and fly towards Tryll with silent intensity. Antimagic comes over him once more as the beast closes 300ft like it's nothing, parting the Silver Sea to come right on you.
Any immediates or anything?
If it turns off its antimagic cone AND casts a SR/PR spell, yes! If not, no.
That was a bit of a stupid question in retrospect,  yes.
> roll 1d20+50 vs Tryll's AC of ???
<Serith> Kotono roll for Serith < 51 > [d20=1]
Yet the beast charges with hunger instead of skill, giving Tryll the chance to flit back and away from being swallowed like a crumb. The beast's teeth are huge this close up, like greatswords.
Mei holds position with a frown, before forming her eldritch powers into a glaive and charging the rear of the dreadnought. Its tail lashes out as she does, psychic winds buffering all of you in the aftermath.
> roll 1d20+50 vs tail AoO vs Mei's AC of 49
<Serith> Kotono roll for Serith < 58 > [d20=8]
> roll 6d8+40
<Serith> Kotono roll for Serith < 68 > [d8=1,6,6,7,5,3]
> roll 1d20+39 Mei Fort
<Serith> Kotono roll for Serith < 51 > [d20=12]
Mei is hit hard by the tail, right in the chest. At the same time she raises her glaive up, slashing into the beast's flesh.
> roll 1d20 touch AC vs a creature this big, we all know it's 1 or hit
<Serith> Kotono roll for Serith < 17 > [d20=17]
> roll 1d20+24
<Serith> Kotono roll for Serith < 28 > [d20=4]
But the glaive sparks out when it touches the dreadnought, leaving Mei knocked back for no gain.
Fantase and Patar continue to get well away from this, retreating flat out.
Rosa's up, she'll hold one second for you two. Go.
Rosa
HP: 343+15/343
Bonuses: +1 morale attacks and will saves, immunity to fear and poison
Mei
HP: 415/472
Hm. Time to gamble.
Seeing that the dreadnought wants very much to eat him, Tryll will oblige! Tryll takes a five foot step forward, then keeps going, phasing straight through the thing's face and into its neck!
There will be more to my action, depending on how things go. I'll pause here to let you react if there's anything due to happen.
It's easy. Even easier than it should be - once you pass into its neck, you feel a tremendous suction pulling at you. Erratically, sometimes working and sometimes not, but nonetheless tugging at you.
> roll 1d100 51+ is a problem
<Serith> Kotono roll for Serith < 87 > [d100=87]
Bad luck. Strength check.
Oh look at that I don't have a strength score.
Can I substitute my Int score since we're on the astral?
Yeah, that's fine, something needs to sub and since that's what's moving you here, that's reasonable.
[blockquote]Rolled 1d20+11 : 10 + 11, total 21[/blockquote]
Gaaah! You're sucked in - past acid that at least can't hurt you and in. You're now deep within the beast - a vast space larger than you can see, pulsing walls of purple. In here amid pools of stomach acid is debris - rocks, bodies, mostly intact trees and even a few stone buildings. They're littered about within.
Finish your turn, Yuth.
'I appear to have entered the belly of the beast. Can anyone out there hear me?' Tryll sends to Calleigh, Rosa, & Mei.
