Surraruthru and spellhoarding (Surraruthru)
Started by Anastasia, February 22, 2017, 02:44:16 PM
"Thank you, Kascha. You help and support has been invaluable."
With that, Surraruthru begins his work, pulling out supplies and components from his Haversack as he goes.
First of all, make a Spellcraft check for the circle as well as an K:A check for setting up.
Take 10 for 47 on Spellcraft and 51 for K:A
Setting up the circle and everything's easy enought. It's just prep, you've done it more times than you can count. Kascha stays back as...
You said three phases, so begin phase one and I'll call for any appropriate checks.
I meant three chambers, one for the hear then Gold's and then mine, I'll make each chamber and then the tapestry stuff?
Surraruthru continues to concentrate on the circles, moving to carve out the space for the Red Dragon Heart, working to carve focuses in for the fire, dragon, and magic forces and traits contained in it.
Doable enough, so okay, we'll assume you got that. Two more Spellcraft checks.
#141
Take 10 for 47 on both.
Settingup takes time and effort, but soon enough the basics are set up. Once you begin, there's no going back - win or lose, the ritual can't be stopped.
Proceed when you're ready.
Surrarthru places the rest of the components as need and then begins focusing on his own power, frying to feel the seperate powers inside of himself: the life force that pours forth with raw power of a dragon; the arcane power of his magic flowing from his mind and will; and the burning of his pride and rage hot enough to char the world just from the embers. Once he seperated these in himself, he focuses on threading them into his tapestry like he wove the Bracers for Kascha before trying to find resonating properties in Gold's blood. However, he takes the extra step of threading the power of Good, blooming from his Celestial nature to connect to the same Nature in Gold's blood.
I figure that's a good pause point, or do you want me to do the whole thing at once?
In phases is fine. Make 2 Spellcraft checks and 4 K:A checks.
> roll 1d20+37 Spellcraft
<Serith> Iddy roll for Serith < 53 > [d20=16]
I feel I've expended my good luck for the round, so take 10 for 51 on the 4 K:A's
Okay. Do me a favor and post the overview of the ritual you wrote a few pages ago real quick?
Surraruthru intends to use the Red Dragon Heart as the template for the ritual to become a True Dragon. He plans to combine the heart with the blood of other True Dragons (Balruk's blood and Gold's blood ideally, or whoever he can convince to donate) and his own magic to draw the power and natures contained in the heart into himself and bind them with his life force through his abilities, skills, and experience as a Grand Weaver.
Using the Red Dragon Heart as a template for the creature he wants to become, he will use Balruk's blood as a catalyzing agent. He's depending on the nature of a Prismatic Dragon to act as a bridge and link the nature of a True Dragon contained in the heart with the similar nature of Dragon in himself and to be a power magnifier. Gold's blood will provide a second link to the heart by similarly forming a bridge, using the nature of Good that Gold Dragons embody with his nature as a Celestial (Good) and his alignment, which should sympathetic to each other.
Using these two bridges to the heart, Surraruthru will then thread in his magic and life force along those connecting links much in the same way he threads his magic and life force into the Eldritch Tapestry, which allows him to connect his magic with others. After Weaving his magic into the links, he will then draw the power into himself and his life force through the tapestry to complete the ritual.
Additional note: Using Gold's blood in place of Baleruk's.
Power begins to flow into you like a torrent, overwhelming as fire erupts all around you. Gah!
Constitution check.
> roll 1d20+8 Con
<Serith> Iddy roll for Serith < 12 > [d20=4]
