Surraruthru and spellhoarding (Surraruthru)
Started by Anastasia, February 22, 2017, 02:44:16 PM
I'm not interested in identifying them, just if he has spells on him. Does that take time the same way?
Surraruthru begins casting a spell to prepare for another magical onslaught!
Spell Turning, CL 33, 330 minute duration
Surraruthru
HP: 126/347
AC: 70=38+4+20+1+7 (Deflection/EMA/Dodge/MotP(NA))
Init: +13, Touch/Atk: 38/42+5
Active: Epic Mage Armor (CL26), Superior Mighty Wallop (CL26), Greater Heroism (CL26), Elemental Body: Fire (CL26), Might of the Planetar (CL26)
Whatever the dragon's doing, you can't see it and don't see any sign of it.
Go, next turn for you.
Surraruthru digs into his Handy Haversack, retrieving his wand of Battlemagic Perception, and uses a charge on himself!
Retrival is a Move Action, wanding is standard.
Battlemagic Perception, CL 5, 50 minute duration
You gain a +5 competence bonus on Spellcraft checks made to identify a spell as it is being cast.
If you have at least 5 ranks in Spellcraft, you are also able to sense the use of any spell or spell-like ability within 100 feet, so long as you have line of effect to the caster.
With a Spellcraft check (DC 15 + spell level) you can even ascertain the spell being cast.
This determination happens quickly enough that you can
attempt to counter the spell as a free action.
Counterspell attempts are otherwise handled normally, and you can counter the spell even if you do not have line of sight to the spellcaster.
Surraruthru
HP: 126/347
You cast it and again nothing is happening. Where is the dragon...?
Go.
Surraruthru calls on his innate power, deciding to try and play the Red's game.
Obscuring Mist SLA, CL 26, 26 minute duration.
Then as move action, Surraruthru will teleport to the left of the cube far enough to keep it just on the edge of vision. About 125ft, I think.
You teleport away - and you can hazily see a red flaming mass that has to be the dragon slam into your cube. It shatters this time, the dragon going straight through it and plunging down, out of sight.
Go.
Surraruthru pulls on his innate power again and turns invisible, then flies as slowly and quietly as he can down towards where the red dragon disappeared to, hoping to angle in and approach from behind it.
You fly a grand 20ft efore you can begin to make out the dragon, 120ft down and 80ft ahead of you.
That's a move action, going to take a standard?
I used my invisibility SLA. That's a standard isn't it?
So you did.
The dragon looks around and his gaze finds you all too fast. He chants and is gone - teleportation? Looks like it, you've used that very spell moments ago. Where is he now?
Go.
Surraruthru holds his ground for the moment, taking a defensive stance and preparing to dodge what he assumes will be another dive attack.
I need to get into melee, so my intent here is to try and bait him in and dodge just enough to stay in range.
