Now where am I?! (Moore)
As you spin wildly, cast amid the planes, a voice speaks to you. That of a loud, resonant voice, meant to carry.
"Welcome, friends! I am Sir Froggington of Ribbit, a wondrous and rather hungry spokesman, so I shall make this quick. My patron is an avid fan of mazes and challenges. You recently went through one of his and he has decided that another must happen, even with a small push. You may consider yourselves slaad-napped if it helps, friends, and the rewards will be quite good to the bold and the brave. Good luck!"
You appear in a large lake. You splash right down into it, glimpses of a cavern and waterfalls seen before you slip below the waterline. Cold. The water's icy cold and quite dark.
He knew it!!!!!
Moore sputters as he splashes near the top of the lake.
"Limbo is not really a suitable place for a second date, if you ask me... a third, maybe." He says as he steadies himself and goes to fly out of the lake and move over to help Ilsenine up too. "On the plus side, it doesn't seem like we're in any real danger, are you all right?"
Make a Swim check first then, since you went right into the drink. Ilsenine will make one too.
> roll 1d20+3 Ilsenine is not a swimmer
<Serith> Kotono roll for Serith < 10 > [d20=7]
You emerge from the icy depths. Looking around, you are briefly stunned by the crashing of water. You are in a large underground lake, dozens of waterfalls plunging down. They plunge down from thousands of feet high, making gentle archers that shimmer with rainbows. The sight is breath-taking and enthralls you for a few seconds.
There's one little problem. Ilsenine hasn't come up from the cold waters.
Moore takes a deep breath and goes down into the water after her!
Oh, wait, he doesn't need to breathe. Oh well -- habit.
<Rei-chan> Kotono rolled : 1d20+3 Ilsenine is not a swimmer --> [ 1d20=1 ]{4}
Ilsenine is below, sinking deeper into the waters as she splashes about, failing at swimming.
Moore will cast Dimension Door to get close to her so he doesn't have to waste time swimming. Well, if it works, anyway!
Plan is to Dimension Door then help her up and out of the water. If dimension door does not work, then he will swim.
No good. Dimensional warding, most likely.
<Rei-chan> Kotono rolled : 1d20+3 Ilsenine is not a swimmer --> [ 1d20=11 ]{14}
Meanwhile, Ilsenine at least stops sinking, but she's not getting any closer to the surface.
He will just have to do it the old fashioned way!
Oh! How silly of him, he will cast Haste on himself to help get there more quickly.
He takes a deep breath in case he needs to take his amulet off to help her breathe, but either way will swim!
You swim down to her, reaching Ilsenine. She quickly grabs onto you.
I'm not entirely sure how the necklace of adaptation would work if she needs air, but either way he does have it.
Moore will start swimming up!
You swim up and back to the surface. Once up, Ilsenine takes a deep breath and coughs. "What manner of peril is this?"
"Are you at all familiar with some of the dungeons that Ithea and the others went through?" Moore asks. "I think it's similar to that, except this one seems to be designed on a maze or a labyrinth."
Ilsenine frowns. "Then we are in peril, I have heard stories of these dungeons. We should seek safety and escape as swiftly as possible."
