Now where am I?! (Moore)
Okay, then let's go with that, as high as the fire resist will go! He'll try and eke out a little extra on the fire resistance if possible.
15:20] <Nephrite> roll 1d20+55 perform in place of concentration because of silly feats
[15:20] <Rei-chan> Nephrite rolled : 1d20+55 perform in place of concentration because of silly feats --> [ 1d20=14 ]{69}
30, that's the max for the spell.
Immediately both of you feel better, no longer charring. Aaaaaaaah.
Technically Limited Wish should let me have a slightly stronger version!!
Moore will cast Heal on Ilsenine anyway.
Now with that taken care of, he will fly over to the lever to see what it says on it.
Less that and more than resistance higher than 30 is rare pre-epic, and usually goes into immunity anyway. It exists every now and again, but again, it's not common.
This lever has no writing on it at all. Ilsenine sighs, "Well done," she says as the burning stops. "We are...ah. I am grateful." Ilsenine adds in.
Ilsenine
HP: 284/284
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Freezing Glance (CL23), Surge of Hope (CL25), Snowsong (CL25), Mass Resist Energy (CL25)
Bonuses: +1 morale attack/will, immunity to fear and poison, +4 morale saves, attacks, ability checks, skill checks and weapon damage rolls, +4 morale armor class and charisma, fast healing 1, resistance to cold 15, resistance to fire 30.
Ilsenine casts as a 20th level beguiler (caster level 23rd, +2 bonus to caster level checks). Her metamagic options are Silent Spell (+1), Still Spell (+1), Reach Spell (+1) and Twin Spell (+3). The save DCs are 22 + spell level.
Ilsenine's advanced learning spells are: Power Word Pain (1st), Ray of Dizziness (3rd), Shadow Evocation (5th), Freezing Glance (6th), Mass Charm Monster (8th)
Ilsenine has two bonus spells from a blessing from Yggdrasil: Mass Snake's Swiftness (2nd) and Aura of Vitality (7th)
0: 6
1: 9
2: 9
3: 9
4: 9
5: 8
6: 7
7: 8
8: 8
9: 7
Ilsenine manifests auras as a 1st level marshal.
Minor Auras(+10): Motivate Dexterity.
Ilsenine casts as a 1st level wild defender. The save DCs are 19 + spell level.
1: Towering OakSC
Placeholder.
[/quote]
Moore will go check the treasure chest, since they have time now!
Take 10 for 49 on spellcraft!
The chest is not magical - and you can see it's made of thick metal, which you'd know would block your spell from scanning inside of.
Moore will simply try and open it! Maybe he's over-complicating it.
The chest does not open. Locked.
That's about to be expected. He'll go over and try the golden lever!
The lever is pulled. The chest springs open a moment later.
"Amazing," Ilsenine drawls, "There's not much to recommend it once the lava's neutered."
Time to check the chest again!
Take 10 for 49 on spellcraft, 32 on Appraise on whatever happens to be in it.
Within is a clay pot, fairly small, with tiny writing on the outside.
Moore will investigate the clay pot's writing!
I said I was spellcrafting whatever was in it!! Take 10 for 49.
