Now where am I?! (Moore)
Moore and Ilsenine fly through the heat, racing ahead to the light. You endure and reach it - it's a glowing point in a dead end, gleaming and floating in the air. You're also heading right towards it.
Chance to do something. You may start taking fire damage if you're here long. Other than the point of light, there's a dead end here with nothing of note.
Moore will simply try and fly into it! It's probably an escape mechanism of some sort -- he doesn't really have a lot of time to analyze it!
You fly and light engulfs you.
Again.
What opposes light?
When your vision clears, you are above the maze of waters, the waterfalls all around you. They go up further, though no further obstructions block your way.
Moore blinks, then blinks again and rubs at his eyes.
Darkness? That's the easy way out, though, isn't it...?
He looks around to make sure Ilsenine made it out safely as well, then he checks his bag for the gemstones to see if they're still in there.
Ilsenine is there, as are the gems and items obtained within.
"Huh... I wonder if the gemstones were just extra prizes." Moore says. "Well, onwards and upwards?" He asks as he offers his hand out.
You fly upward. At last you reach the top of the waterfalls. Here open ground stretches in all directions. To the west you can see a small keep, sitting there undisturbed. To the south you notice a small collection of houses, a little less than even a village or hamlet.
Above you, you see the roof of the cavern at last,  including a fairly large hole that leads to pitch blackness beyond the cavern.
"Do you feel like spending more time here?" Moore asks. "It looks like we have the option of leaving if we want. I think it'd be fine to spend a bit more time here to look for other things."
"That assumes it takes us to freedom," Ilsenine says, "I find myself questioning that."
"I suppose that's a good point too." Moore says as he starts towards the keep.
> roll 1d100
<Serith> Kokokokokokoko roll for Serith < 16 > [d100=16]
Spellcraft.
This should come as no surprise but he's taking 10 for 49. If Surge of Hope is still active (he cast it when they were in the last treasure room and was good for 25 minutes) then it's 53.
You can feel it as you enter. This is a wild magic zone. You'll be at risk of your spells failing and taking on bizarre, unpredictable results here.
Caster level checks when you cast with an unknown DC. Failure results in a random effect instead.
Does it feel like his detect magic that's always on is going to be affected at all?
"Hmm... We'll have to be careful here. No casting spells unless we need to." Moore says. "I think my music should be unaffected, though."
