Now where am I?! (Moore)
The pentagon glows and crumbles away. From the waters a dagger emerges, forming from water into solid steel.
"Hmm..." Moore will examine the dagger before picking it up and putting it away!
Take 10 for Spellcraft 49
It is a dagger+1, animal bane.
"I wonder if pentagons are 'treasures' then." Moore shrugs. He can hear what's coming from the east, but he heads west first to investigate!
The west leads to a square block of a room. On the far western wall are two squares and a pentagon.
There are little tunnels to the west and south, as well as a hole in the ceiling that leads upwards.
You can again hear the whistling of wind. It sounds closer now than it did before.
Moore will go over to touch the pentagon again to see if the behavior is the same!
Moore touches the pentagon. It glows and fades away, a dagger coming out of the water and forming, falling to the ground at your feet.
A moment later, one square glows and crumbles, then the other follows. The passage up is filled in, replaced by a passage down. The passage you came from then seals up, while a passage to the north opens up.
To be clear there are now the following passages: Down, North, South and West. Up is gone, as is the passage to the East you came through.
"So pentagons are treasure." Moore says as he takes this next dagger, analyzes it and the puts it away.
"I don't think we need to go down... but perhaps there's a new area below?" Moore offers.
It's a dagger+1, ooze bane.
"Hold on," Ilsenine says, "Let's check north first. If I'm reckoning it right, that should take us back one room south of where we came up on this floor."
Moore nods and will head that way, north!
You come up into the room you fought the elemental in - the narrow hallway, right at the dead end where the stones where. There's now a tunnel there going back south. It's otherwise unchanged, including the passage to the east still glowing.
"Ah, this leads back here." Moore nods. "Going back and down might have some room for we missed, or we can follow that." He gestures in the eastern direction.
"We already went that way," Ilsenine points out, "Though it gives us access back that way if there's a passage in one of those rooms we wish to explore."
"Hm, the only stones I saw back there was the line, which might seal it off and make us go in another direction. For now, then..." Moore begins to head in the eastern direction!
You head to the east and back to familiar territory.
This opens up into a larger, vaguely circular room with a low roof.
There is a passage to the south. There's also a hole in the ground heading back down to the previous floor.
The line and square you already activated here are still gone.
