Now where am I?! (Moore)
> roll 1d100
<Serith> Kotono roll for Serith < 72 > [d100=72]
Do you have any cold resistance?
[blockquote]Rolled 1d20+55 : 14 + 55, total 69[/blockquote]
Snow begins to fall and you shiver. C-c-cold. You're getting cold fast, but you hold your concentration to finish your spell. No response.
"Blocked...?" Moore murmurs to himself. Fine, then.
He casts Safety to find a good place to go to get out of this weather!
Sure, he could just Greater Plane Shift off wherever he is...
You get results - that constantly change. 3 miles ahead in a cave. No, 200 feet ahead, inside the tree. No, fly straight up into the clouds. No. It's constantly changing, the spell switching every few seconds.
IS HE STILL IN LIMBO?!
AAAAAAAAAAAAAAAAAAHHHH!!!!
He takes a breath. Calm. Calm. Calm... Maybe this is still part of the maze.
In that case, he will just have to head straight forward and see what happens.
It's open forest with a stream. Need something more specific.
Well he was pretty much just picking a direction but let's go with he'll follow the stream.
Which direction, upstream or downstream?
Upstream. He'll also keep an eye on the safety spell and see if there's any consistency to it at all.
The safety spell gives up the ghost after a few more minutes, sputtering into incoherency and then failing altogether.
You walk perhaps another 10 minutes before you're really starting to shiver. It's cold enough to snow here and a wind blows, cutting through your wet clothes and leaving you miserably numb.
Fort.
[13:27] <Nephrite> roll 1d20+41 fort
[13:28] <Serith> Nephrite roll for Serith < 52 > [d20=11]
If this really is Limbo, maybe he can try and make it a little warmer around himself? He may as well give it a shot -- he tries to focus on the ambient temperature around him to raise it up just a little.
You endure the cold and keep it together as...
Wisdom check, go go anarchery.
