As Calleigh flies ahead in the passage, she notices she flies right over a nearly invisible beam, from one wall to the other at ankle level. It has the slightest blue cast to it.
"Ooooo a TRAP!" CAlleigh says, "Hey guys! I found a thing!"
Kascha's there first, walking carefully, "What sort of trap?" she calls, "Is it one we could accidentally trip?"
Surraruthru approaches cautiously as well, looking for it so he can learn its secrets...
Surraurthru inspects the trap, trying to figure out the spell and mechanics of with his Detect Magic it while everyone else avoids it. Hopefully.
Spellcraft. Just go ahead and make a check for this automatically next time if you come on something like this.
Rodger rodger.
> roll 1d20+57 Spellcraft
<Serith> Iddy roll for Serith < 72 > [d20=15]
It's a fairly simple beam that will trigger something if something passes through it. You can't tell what else from here, unfortunately. The beam connects to a greater spell, but you can't access it from here.
"Hmm, can't see what it'll trigger, just how. In any case, let's simply avoid it."
Easy enough to do with flight. "Boring," Dana drawls, "Where's some fucked up experiments to fight?
"Hopefully we don't find any, because if they happened, they were given succor and mercy," Kascha says, gently so.
"Indeed, this has been... rather simple so far. It makes me wonder what the difference in the next level will be..."
"Mages in general, I believe. We've not really run into anything challenging, however."
"Nothing serious - yet," Hanna agrees, "This is just the opening phase."
"Yeah, if the opening phase was blue balls from here to Elysium," Dana grouses, stomping along.
"Please don't fight," Kascha says, "I'm sure something will come up soon."
Ahead the passage ends in a single door that's already ajar. Past it you see it comes to a four way intersection, dimly lit at best and with three paths going off into the darkness.
