You do so. The next room is a short hallway, with another door behind it. This door is of shiny, polished metal. No sign of decay here despite the water. This door glows intensely blue, the stones around it also glowing bright.
Calleigh carefully pokes around, looking for traps and stuff. How much water is there?
Meanwhile, Tryll tells the group, 'Next up is a hallway with a warded door. The walls are not warded, so Calleigh was able to get around them. Past the door is a short hallway with another door, though the room is pristine. The next door and the wall are also warded. Calleigh will need assistance before going further.'
Search, Calleigh.
"Sounds odd, if this is a fuckin' walled off passage," Dana grunts. "Doesn't make sense."
"Unless," Kascha says softly, holding a hand to her chest, "If it's walled off because it's not meant to be disturbed?"
'Possible. Probable, even. It could lead to some ancient terrible monster. Or a control center for the dungeon's magics.' Tryll replies.
"Last thing that was walled off was the wolf. Could be something else needs liberation. If the walls aren't protected, we can use acid to detach the door from the wall, depending on what the magic on the door is."
"Could also be a treasure vault," Canderella says, rather brightly. "That's something well protected."
"Quite. Let's find out."
Surraruthru heads towards the door!
The party reaches the first door without incident, Calleigh ahead and past it. It's exactly like Calleigh saw.
Surraruthru inspects the door, trying to puzzle out the magic with his Detect Magic.
> roll 1d20+57 Spellcraft
<Serith> Iddy roll for Serith < 61 > [d20=4]
It's a powerful warding spell that stops magic detection around the door, makes it almost impossible to force open or lickpick and resists basic spells like knock to open it.
"Magic to resist opening in various ways."
Does it seem reasonable to use Acid Splash to eat away the stone from around the hinges so the door falls? How many uses would it take?
You're pretty sure the protections on it would null your acid damage.
