Oh sorry, misread. Good catch.
You probably could, you think.
Surraruthru begins calling on his innate dragon magic to use acid to eat away the stone!
I've got 2 castings of Acid Splash via Dragon/Sorc, and 2 more from Wiz. Lemme know how many get used so I can update.
All 4 will do.
With some tactically applied acid, the door hinges give way, the door falling backwards and revealing Calleigh and her door.
Surraruthru approaches the new door, avoiding the water, and begins to study the magic on it.
> roll 1d20+57 Spellcraft
<Serith> Iddy roll for Serith < 59 > [d20=2]
It's the same magic, only wider spread and stronger. All the stone around the door is protected, too.
"Same magic, more powerful. Extends to the stone, so the same trick won't work. We'll have to break the magic."
How's Tryll on PP? You wanna do the dispel or do you want me to?
'Please, allow me.' Tryll replies.
Area Dispel[blockquote]Rolled 1d20+20 : 19 + 20, total 39[/blockquote]
Tryll
HP: 326
AC: 47
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Inertial Armor (CL 31), True Seeing (CL 28), Elemental Body (CL 28), Surraruthru's Stupendous Dragonskin (CL 28), Strength of the Dragon Princess (CL 28), Mind of the Dragon Princess (CL 28), Agility of the Dragon Princess (CL 28), Endurance of the Dragon Princess (CL 28), Beauty of the Dragon Princess (CL 28), Create Magic Tattoo (CL 24), Create Magic Tattoo (CL 24), Energy Immunity (CL 26)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, +19 armor bonus to AC (blocks incorporeal), True Seeing, +4 insight to all stats but Wisdom, +1 luck attack rolls, +2 competence attack rolls
Resources Used: 136 PP
Calleigh
HP: 217
AC: 56
The magic on the door shudders thrice before winking out.
"Dana, if you wouldn't mind. Just in case there's some kind abomination, spell-warped, evil bull or something."
This opens into a rather large chamber. The stone here is pristine and unmarred despite water running down it. The air within is pure and fresh, not a hint of staleness. The room is sloped, a downward hill rather like a funnel. At the bottom, rather than a hole, is a cylinder of glimmering black force, about 20ft wide and reaching from floor to ceiling.
Along one wall is a wooden cabinet, decorated with carvings of dragons and closed firmly shut.
There's no other doors leading in or out of the room.
"Interesting... Kascha, would you mind checking out the cabinet? I'll investigate the cylinder."
Kascha flies over to do just that. Canderella lingers by the door while Dana follows Surraruthru.
"So, any idea?" she asks, as you reach the cylinder.
