Kascha casts:
Quickened Empowered Maximized Scorching Ray, CL 29. No Save, SR applies.
> roll 1d20+31 Touch ATK 1
<Serith> Iddy roll for Serith < 46 > [d20=15]
> roll 1d20+31 Touch ATK 2
<Serith> Iddy roll for Serith < 51 > [d20=20]
> roll 1d20+31 Touch ATK 3
<Serith> Iddy roll for Serith < 32 > [d20=1]
36 fire damage to each slime.
Maximized Fireball, CL 29, targeting it so it will hit as many as possible, Ref half, SR applies
60 damage to all.
Surraruthru
HP: 391/413 (359 base)
AC: 52+4 (Deflection)
Touch AC: 24, Flat Footed: 57, SR: 37, CMB: 33, CMD: 51
Init: +12, Touch Atk: 38
Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body: Fire (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength/Mind/Agility/Endurance/Beauty of the Dragon Princess (CL28), Bibliotheca Arcana (CL28), Create Magic Tattoo (CL24), Create Magic Tattoo (CL24), Energy Immunity: Acid/Cold/Electricity/Sonic (CL26), Epic Mage Armor (CL28)
Passive: True Seeing, Detect Magic, +15 to knowledge checks
Kascha
HP: 359/359 (305 base)
AC: 63
Touch AC: 47, Flat Footed: 57, SR: 38, CMB: 33, CMD: 61
Init: +14, Touch Atk: 31
Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body: Fire (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength/Mind/Agility/Endurance/Beauty of the Dragon Princess (CL28), Create Magic Tattoo (CL24), Create Magic Tattoo (CL24), Energy Immunity: Acid/Cold/Electricity/Sonic (CL26)
Passive:
Kascha stands and aims carefully, a trio of rays streaking out. Two of the oozes are pierced by the rays, color turning a bit reddish but nothing else ,a bit of smoke rising from where they were impacted, and then the fireball explodes amid them.
> roll 1d20+4 IO1
> roll 1d20+4 IO2
> roll 1d20+4 IO3
<Serith> Kotono roll for Serith < 8 > [d20=4]
<Serith> Kotono roll for Serith < 7 > [d20=3]
<Serith> Kotono roll for Serith < 19 > [d20=15]
The fireball scorches all of them, tinting them a semi-transparent light red, the oozes wobbling and jiggling.
Tryll, go.
Making assumptions here for the sake of expediency since we're so far behind. Feel free to correct me if I can't.
Tryll makes whatever necessary movement adjustments are needed to ensure that the slimes are lined up in roughly a line-ish group  and his allies are not in the way before establishing another link to the Positive Energy Plane and letting the gods decide who gets to live today.
Celestial Conduit (Twinned, Maximized, Empowered)
900 positive energy (untyped?) damage to everything in a 120 foot line.
Reflex DC 36 halves.
Rolling SR just in case:
[blockquote]Rolled 1d20+31 : 14 + 31, total 45[/blockquote]
Tryll
HP: 326
AC: 47
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Inertial Armor (CL 31), True Seeing (CL 28), Elemental Body (CL 28), Surraruthru's Stupendous Dragonskin (CL 28), Strength of the Dragon Princess (CL 28), Mind of the Dragon Princess (CL 28), Agility of the Dragon Princess (CL 28), Endurance of the Dragon Princess (CL 28), Beauty of the Dragon Princess (CL 28), Create Magic Tattoo (CL 24), Create Magic Tattoo (CL 24), Energy Immunity (CL 26)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, +19 armor bonus to AC (blocks incorporeal), True Seeing, +4 insight to all stats but Wisdom, +1 luck attack rolls, +2 competence attack rolls
Resources Used: 179/749 PP
Calleigh
HP: 217
AC: 56
Resources Used: 1 Entangling Ectoplasm wand charge.
> roll 1d20+4 they suck at Ref
<Serith> Kotono roll for Serith < 5 > [d20=1]
<Serith> Kotono roll for Serith < 11 > [d20=7]
<Serith> Kotono roll for Serith < 13 > [d20=9]
The blast of celestial power is sharp, overcharged and overwhelming. There's a clap like thunder and a gust of air, and when it clears ,the oozes are little more than slime on the ground. The back wall is cracked deeply, the stones of the floor scorched and fused together where the conduit touched it.
Well, that's one way to end an encounter. Free act.
"Very effective."
Surraruthru looks around the room for anything that he can take as loot...
In the mess of ooze, you can see the very bottom of the room is deeply cracked and crumbling.
There is the cabinet Kascha was investigating.
"The floor is cracking and crumbling. Don't fall. Let's check the cabinet."
Surraruthru flies to the cabinet to do just that!
You open the cabinet. Inside are several vials of green slime in jars of all various shapes and sizes.
Surraruthru inspects them for traps and general arcane identification with Detect Magic.
"Bottled slimes! Neat?" Calleigh hedges, ignoring Surraruthru's attempts at caution and hefting a vial.
Search check and Spellcraft both not needed, DC's trivial for you.
Calleigh hefts a vial. It's heavier than it looks, a slender crystal vial of green slime weighing several pounds.
There's no traps and you can detect a faint but persistent magic from the slime. You're fairly sure the slime in each vial is infinite, self replenishing as it is poured out of the vial.
Fortunately, Calleigh is also stronger than she looks, and hefts the vial easily. After a moment, it is subsequently stuffed into her bag of holding along with the rest of the vials and bottles.
