Feel free to declare you're using it, since it does take time to do so.
As the five of you talk, all the nubs above begin to crackle with electricity, the room lit up with bolts of blue-white voltage.
Surraruthru stares at the magic, focusing on his Detect Magic to see what sort of electrical attack this might be building to.
Spellcraft.
Going to react or keep on going, Calleigh?
Hanna looks up and says, entirely calmly, "We are all protected against lightning, correct?"
"Pretty!" Calleigh says as she zips toward the nearest wall.
> roll 1d20+54 Spellcraft
<Serith> Iddy roll for Serith < 55 > [d20=1]
"Indeed. Unless it's an augmented type of lightning. Like an admixture. Or something like Simmer's fire and designed to punch through protections."
Surraruthru
HP: 413/413 (359 base)
AC: 52+4 (Deflection)
Touch AC: 24, Flat Footed: 57, SR: 37, CMB: 33, CMD: 51
Init: +12, Touch Atk: 38
Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body: Fire (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength/Mind/Agility/Endurance/Beauty of the Dragon Princess (CL28), Bibliotheca Arcana (CL28), Create Magic Tattoo (CL24), Create Magic Tattoo (CL24), Energy Immunity: Acid/Cold/Electricity/Sonic (CL28), Epic Mage Armor (CL28)
Passive: True Seeing, Detect Magic, +15 to knowledge checks
Kascha
HP: 359/359 (305 base)
AC: 63
Touch AC: 47, Flat Footed: 57, SR: 38, CMB: 33, CMD: 61
Init: +14, Touch Atk: 31
Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body: Fire (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength/Mind/Agility/Endurance/Beauty of the Dragon Princess (CL28), Create Magic Tattoo (CL24), Create Magic Tattoo (CL24), Energy Immunity: Acid/Cold/Electricity/Sonic (CL28)
Passive:
It's lightning. A hell of a lot of lighting, but just lightning.
Calleigh goes through the wall and...
In which direction, Calleigh?
"I believe it's just lightning. A lot of it, though. Beware your eyes."
Uh, whichever was in front of us, I guess. North?
Lightning rains down, a massive discharge that has no effect on the party at all.
Meanwhile, Calleigh peeks into the next room. It's full of multi-colored mist, shimmering bright. It's essentially a hallway with a slight curve otherwise, with a door leading further north at the far end.
'According to Calleigh, the next room is filled with some sort of colored, prismatic mist. It's a hallway with a slight curve leading further north.' Tryll tells the group.
"Scout the next or deal with prismatic mist?"
Surraruthru lets the group decide. Personally, he has a necklace of adaptation, so he thinks he'll be fine...
Surraruthru
Kascha
AC: 63
Passive:
"The lightning's fucking harmless so let's go," Dana says, heading north.
Canderella looks up, "Aw. Charming. Aren't you the cutest, little and feeblest lightning spells I've ever seen."
Surraruthru hops up into a glide to land on Canderella's shoulder.
"With the proper preparation, most magic can be rendered useless. Beware this mist. I imagine it will act much like a poison cloud. Breathe it in and be subject to it. If you can cast a spell to protect yourselves, I suggest you do. I would like to avoid having to expend magic to dispel it. Such spells will most assuredly become more valuable the further in we get."
'It it becomes a bother, I'll get rid of it for you. I understand if you are more...limited.' Tryll replies airily.
Surraruthru chuckles at the ineffectual barb.
"Please feel free to expend your all encompassing power. I simply hope you're not over estimating your endurance. Lasting power is often more impressive."
