Gar-Malleos
We'll begin OOC for this one.
Okay, a few questions. First of all, who is going besides the five of you, if anyone? Second of all, what sort of prep? Third, anything else that needs to be noted before this begins?
Last call for purchases before Gar-Malleos. Go make them now if you need anything.
Surru, what is your tapestry going to look like here, since that's a big part of the boosting game.
Moore will have the following cast on himself:
Foresight (CL27), Greater Improvisation (CL27), Righteous Halo (CL16)
He can cast other things on the rest as necessary, such as Surge of Hope and so on if it doesn't conflict with tapestry buffs.
Afina will still have most of the longer duration buffs from when we went after Quinn. She'll eat at the cafeteria to restore some temp hp as well.
[17:35] <@Ebiris> roll 1d8+10 heroes feast
[17:35] <Rei-chan> Ebiris rolled : 1d8+10 heroes feast --> [ 1d8=7 ]{17}
Afina 329+17/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), death ward (CL 31), good hope (CL 30), control winds (CL 27), spell turning (CL 26)
defences: AC 98 (touch 61), CMD 90, spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, critical hits, negative energy, & death effects, halved damage from melee and ranged attacks
spell slots: 5/9/8/9/6/9/0/6/2/7/4/2/2
Is there anything special we're expecting? Unusual stuff we know about? Like... I dunno, is this happening with abnormal plane stuff like the negative plane effects? Do we know if they specialize in acid or something? Basically, anything I need to plan for that we already know about.
It's on Lifasa, though on a ley line nexus so there may be weird persistent effects. Silvber specialises in hellfire direct damage and dark speech charm/domination effects, and he has a bunch of nessian pit fiend bodyguards. They like hellball slas which do lots of elemental damage, though they usually make it unholy or vile damage anyway to get by resistances.
The following are the basic ones. I can throw in a Magic Circle Against Evil, but that's 10min/level, so it'd be 300 minutes. I suggest that be cast immediately before combat instead. That may help against the Hellfire since it has the Evil descriptor. Maybe?
I can't really do much against unholy or vile, as far as I'm aware. If anyone knows of a spell to help that, let me know.
Tapestry:
Elemental Body (fire) CL 28, 28 hour duration
You have the benefits of the attune form spell with respect to the appropriate element. If you choose a water body, for example, you can breathe normally on waterdominant planes.
You are immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking. You gain darkvision out to 60 feet.
Your creature type remains unchanged, so you are unaffected by spells that target elementals, but you gain the air, earth, fire, or water subtype depending on the elemental substance you chose.
Surraruthru's Stupendous Dragonskin, CL 28, 28 hour duration
Strength of the Dragon Princess, CL 28, 28 hour duration
Mind of the Dragon Princess, CL 28, 28 hour duration
Agility of the Dragon Princess, CL 28, 28 hour duration
Endurance of the Dragon Princess, CL 28, 28 hour duration
The target of this spell gains a +4 insight bonus to Constitution.
Beauty of the Dragon Princess, CL 28, 28 hour duration
The target of this spell gains a +4 insight bonus to Charisma.
Create Magic Tattoo, CL 24, 24 hour duration
+2 competence bonus on attack rolls.
Energy Immunity (x4) CL 26, 24 hour duration
Grants complete protection agianst: acid, cold, electricity, sonic
Quiescent Weaving: Haste, Retributive Enervation, Spell Turning, Greater Mirror Image
Self:
Epic Mage Armor CL 28, 24 hour duration
An invisible but tangible field of force surrounds the subject of epic mage armor, providing a +20 armor bonus to Armor Class. Unlike mundane armor, epic mage armor entails no armor check penalty, arcane spell failure chance, or speed reduction. Because epic mage armor is made of force, incorporeal creatures can't bypass it the way they do normal armor.
Moment of Prescience CL 28, 28 hour duration
This spell grants you a powerful sixth sense in relation to yourself. Once during the spell's duration, you may choose to use its effect. This spell grants you an insight bonus equal to your caster level (maximum +25) on any single attack roll, opposed ability or skill check, or saving throw. Alternatively, you can apply the insight bonus to your AC against a single attack (even if flat-footed). Activating the effect doesn't take an action; you can even activate it on another character's turn if needed. You must choose to use the moment of prescience before you make the roll it is to modify. Once used, the spell ends.
Bibliotheca Arcana, CL 28, 24 hour duration
You gain a +15 insight bonus to all knowledge checks and may make knowledge checks untrained. This knowledge extends to knowledge of your own life. You you have perfect recall of your own memories for the duration of the spell. Effects that change your memories, such as modify memory or mindrape, are suppressed for the duration of the spell. You gain the ability to read and speak all languages during this time, as if affected by a comprehend languages and tongues spell. Finally, you may instantly absorb the information of any written material you touch, as if by a scholar's touch spell. For the duration of the spell, you have perfect recall of the material read in this manner.
Looks great, waiting on posts from Jaela and Tryll.
#7
Thing of note. The memory crystal tree. I need to retrieve the crystal from the dude in the Grond's library with Sylvie. The tree's supposed to be planted into a ley line. I figure since we're going to one anyway, I could pop out, get it, finish the tree, and then hit the ley line. Once we finish the battle, or even during it, I could plant it and let it do its work. Input?
Edit: The ritual and everything has already been completed, I just need to retrieve the crystal and get the ritual complete. Dune? Ideas on a number of hours that would take and how it fits into the attack schedule?
Due to moving the assault up a day to sync us up, our old spells ran out but there are fresh ones!
Spells I cast on everyone: Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30.
Spell I cast on everyone, it has a short duration: Recitation CL30.
Halved physical damage, negated 'pain' attacks, immunity to negative energy/death effects/energy drain, +2 morale to attack/damage/saves/ability checks/skill checks, +2 luck to AC/attack/saving throws or +3 if worshiping the same religion
Spells Active: Spell Turning CL26, Contingency CL32, Permanency/Greater Blindsight CL32, Permanency/Mantle of Good CL33, Foresight CL27, Moment of Prescience CL25, Lore of the Gods CL30, Invisibility Purge CL30, Fortunate Fate CL15, Mind Blank CL17, Greater Mage Armor CL7, Planar Tolerance CL7, Heroes Feast CL20, Righteous Halo CL28, Vision of the Omniscient Eye CL30, Greater Heroism CL27, Shield of Warding CL31, Conviction CL31, Crown of Flame CL30, Sign CL30, Divine Insight CL33, Interplanar Telepathic Bond CL26, Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30, Epic Mage Armor CL27.
Let's also bring Mei and Candy. I'll wear Hidden Dawn with Candy.
Hidden Dawn
Rank 1: CR 10 or sparring, fire resistance 10, 100ft range.
Rank 2: CR 13, +2 fortitude saves, 125ft range.
Rank 3: CR 15, searing light at will as an SLA, 150ft range.
Rank 4: CR 18, +2 reflex saves, 200ft range.
Rank 5: CR 20, flame strike at will, 300ft range.
Rank 6: CR 21, +2 will saves, 400ft range.
Rank 7: CR 24, +2d6 goldenfire damage on weapon damage rolls, natural attacks and spells and spell-like abilities with the fire descriptor, 700ft range.
Rank 8: CR 27, immunity to fire, 1000ft range.
Rank 9: CR 29, save bonuses increase to +7, 5000ft range.
Rank 10: CR 32, goldenfire damage rises to +4d6, unlimited range as long as on same plane. <-- Current Rank
Okay, so did you all work things out. Who is going precisely? There was some chatter over Tryll's downtime, so let's hash that out as well as Surru's crystal thing, if possible.
My understanding is we're doing this on t minus 83 days to accommodate Surrurathru's stuff that he did on t minus 84, but that Moore and Tryll have been doing their own stuff that has pushed them on to t minus 77 or something so they're in the future and thus can't take part? They'd need to confirm since it's not really my lookout to be keeping track of everyone else's flow of time.
My compromise to keep the ritual from still taking a week was for Tryll to spend the next 6 days after the ritual (83-77) on the rebuilding and for Moore to be available. If this isn't feasible or Moore's participation in the ritual did indeed take a week then he's not available for anything until day 77.
We'll work with that, then. That leaves Yuth at loose ends and with Surru's tree project, which I notably didn't get done (read as: forgot about since this was a weekend of stuff for me) so lemme see if Iddy pokes in anytime before session or if we'll have to wing that.
Yuth, you're off today so poke on IRC and I'll chat with you directly. If you can't, say so and we'll handle this over in nagging instead.
#13
Updated spoiler block for a new day and Surru's tapestry, only adding ones of interest to avoid clutter
Afina 383+52/383
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), sublime revelry (CL 31), death ward (CL 31), good hope (CL 30), recitation (CL 30), shield (CL 27), agility of dragon princess (CL 28), endurance of dragon princess (CL 28), beauty of dragon princess (CL 28), magic tattoo (CL 28), magic tattoo (CL 28), energy immunity (acid) (CL 28), energy immunity (sonic) (CL 28), energy immunity (elec) (CL 28)
defences: AC 106 (touch 66), spell resistance 42, immunity to fire, water, earth, cold, acid, sonic, electricity, disease, poison, fear, mind-affecting, critical hits, negative energy, & death effects, halved damage from melee and ranged attacks
spell slots: 6/9/10/10/7/9/9/8/8/8/7/5/3
Attack: +60 (1d4+28 + various)
This has come up once or twice in passing, but worth noting again. The very few sources of instant death in Balmuria are generally deific things, usually intermediate or greater deities. If you have the extreme misfortune to run into those, death ward doesn't help. Adding immunity to death effects in the description of it doesn't really apply in this particular game. As those ID effects are the domain of deities and beyond the normal scope of how 3.5 considers instant death, death ward and the like don't impact them.
Canderella will offer epic mage armor if Afina isn't handing it out.
Mei uses heavenly blessing to give everyone 52 temporary hit points.
More in the last post, this is just setup.
Canderella
HP: 383+52/383
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (CL28), Surraruthru's Stupendous Dragonskin (CL28) Everything But Wisdom of the Dragon Princess (CL28), Create Magic Tattoox2 (CL28), Energy Immunityx4 (CL28), Sublime Revelry (CL31), Mass Death Ward (CL30), Recitation (CL30)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, elemental traits, immunity to elemental damage, +10 armor bonus to AC and damage reduction 10/magic, +4 insight to all stats but Wisdom, +1 luck attack rolls, +2 competence attack rolls, halved damage from melee attacks, immunity to pain, immunity to negative energy and energy drain, +2 luck AC/attacks/saving throws
Mei
HP: 502+52/502
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (CL28), Surraruthru's Stupendous Dragonskin (CL28) Everything But Wisdom of the Dragon Princess (CL28), Create Magic Tattoox2 (CL28), Energy Immunityx4 (CL28), Sublime Revelry (CL31), Mass Death Ward (CL30), Recitation (CL30), Heavenly Grace (CL26)
Heavenly Grace
Epic; 9th
You are protected by the forces of righteousness and safe from death. You are immune to negative energy, energy drain, ability damage and ability drain for 24 hours. Creatures who use these against you suffer 7d6 points of damage each time they do.
