Gar Malleos II (Tryll, Surraruthru)
Started by Anastasia, January 08, 2018, 10:22:29 PM
Will only counter a dispel or Levi's spells this round.
Init: +22 (Sign, Grace), CHA +2, CL31
HP: 520+20/520
AC: 89 =76base+2Foresight+3Recitation+5ShieldOfWarding+1Grace+2AotDP, 20% miss chance
Touch AC: 83 =70base+2+3+5+1+2
Full Attack (Gae Buidhe +7, haste, HW, K:D +5): +51/+51/+46/+41/+36, 1d8+38+3d12 goldenfire
Full Attack (Gae Bolg, GMW, Haste, HW, K:D +5, vs devils only): +53/+53/+48/+43/+38, 4d8+40+11d6 and 1 negative level
Combat: Greater Heroism +4 morale/attack, Good Hope +2 morale/damage, Recitation +3 luck/attack, SotDP +2 attack/+3 damage, CMT +2 competence/attack, Celestial Valor +4 sacred attack/damage, Divine Might +17 damage: +15 attack, +26 damage
Gae Buidhe: The wielder acts outside of fate and destiny, they are immune to divinations (with the exception of detect good, which always reveals an overwhelming aura of good). Luck and insight bonuses to attack rolls, weapon damage rolls and DCs do not apply against attacks on the wielder, while the same bonuses to armor class and saving throws do not apply against attacks the wielder makes. Additional abilities that explicitly manipulate destiny or use it as a tool also fail (the DM's discretion is used to determine abilities that qualify for this).
[not used: Divine Favor +3 luck/damage]
Spells Active: Spell Turning CL26, Contingency CL36, Permanency/Greater Blindsight CL36, Permanency/Mantle of Good CL37, Foresight CL27, Moment of Prescience CL25, Lore of the Gods CL30, Invisibility Purge CL30, Fortunate Fate CL15, Mind Blank CL17, Greater Mage Armor CL7, Planar Tolerance CL7, Heroes Feast CL20, Righteous Halo CL30, Vision of the Omniscient Eye CL30, Greater Heroism CL30, Shield of Warding CL31, Conviction CL31, Crown of Flame CL30, Sign CL30, Divine Insight CL30, Interplanar Telepathic Bond CL26, Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30.
Short Duration Spells: Grace CL30, Recitation CL30, Haste CL27, Celestial Valor CL32.
Tryll: Intellect Fortress round 1/5: All savable damage halved so long as SR/PR applies.
Surru Spells: Energy Immunity (Acid, Cold, Sonic, Electricity) CL26, Elemental Body/Fire CL28, *Surraruthru's Stupendous Dragonskin CL 28, Strength of the Dragon Princess CL 28, Mind of the Dragon Princess CL 28, Agility of the Dragon Princess CL 28, Endurance of the Dragon Princess CL 28, Beauty of the Dragon Princess CL 28, *Create Magic Tattoo (+1 Luck to attack) CL 24, Create Magic Tattoo (+2 Competence to attack) CL 24, Create Magic Tattoo (+1 CL) CL 24,
Resistances and Immunities: Fire Immunity, Cold Immunity, Acid Immunity, Electricity Immunity, Sonic Immunity, Damage Reduction 25/Epic and Evil and Cold Iron, Spell Resistance 37 (49 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Immunity to fear and poison/Heroes's Feast, Immunity to dazzled and blinded/Vision of the Omniscient Eye, Never surprised or flat-footed/Foresight, physical damage reduced by half/Sublime Revelry. You are immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking/Elemental Body.
Old: Cold Resistance 10, Acid Resistance 20, Electricity Resistance 20, Sonic Resistance 20
Original:
Spells Left (1-9): 10/9/9/7/9/9/8/7/8
Spells Left (10-12): 8/6/4
Current:
Spells Left (1-9): 7/6/5/5/8/8/8/6/7
Spells Left (10-12): 7/4/4
Saves: conviction +5, recitation +3, hidden dawn +7, celestial valor +4 : +19; eotdp fort +2; foresight ref +2, haste ref +1, shield of warding ref +5, grace ref +1, aotdp ref +2.
Saves: Fort +73, Ref +74, Will +71
Gae Bolg: GMW, Keen Edge
Gae Trocaire: GMW, Keen Edge
Turning Left: 19/20
-Mountainous Fire summons
-Spell Turning x1
-Foresight x1
-Moment of Prescience x1
Taking ten for K:A 62, K:N 41, K:R 66, K:P 66, Spellcraft 56
Hidden Dawn used with Mirajane
Golden Bracers (Hidden Dawn):
Flame Strike at will
Immunity to fire
Save bonuses increase to +7
HP: 691+54=745
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (fire) (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength of the Dragon Princess (CL28), Mind of the Dragon Princess (CL28), Agility of the Dragon Princess (CL28), Endurance of the Dragon Princess (CL28), Beauty of the Dragon Princess (CL28), Create Magic Tattoo (+1 luck ATK) (CL24), Create Magic Tattoo (+2 comp ATK) (CL24). Create Magic Tattoo (+1 CL/ML) (CL24), Energy Immunity (all elements) (CL26), True Seeing (CL30), Inertial Armor (CL30)
Bonuses: +4 insight to STR/Dex/CON/Int/CHA, +1 luck to ATK, +2 comp to ATK, +1 CL/ML, Energy Immunity, +1 morale to ATK & Will, Immune to Fear, +18 armor to AC (applies to incorporeal touch)
Resources Used: 133/789
HP: 345+54=399+18
Spells Active: Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (fire) (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength of the Dragon Princess (CL28), Mind of the Dragon Princess (CL28), Agility of the Dragon Princess (CL28), Endurance of the Dragon Princess (CL28), Beauty of the Dragon Princess (CL28), Create Magic Tattoo (+1 luck ATK) (CL24), Create Magic Tattoo (+2 comp ATK) (CL24). Create Magic Tattoo (+1 CL/ML) (CL24), Energy Immunity (all elements) (CL26), True Seeing (CL32), Inertial Armor (CL32), Intellect Fortress (CL 32)
Bonuses: +4 insight to STR/Dex/CON/Int/CHA, +1 luck to ATK, +2 comp to ATK, +1 CL/ML, Energy Immunity, +1 morale to ATK & Will, Immune to Fear, +18 armor to AC (applies to incorporeal), 18 temp HP
Noting for prosperity: Surraruthru now knows whatever that Ice Blizard/Fog spell was.
Surraruthru
HP: 364/364 (364 base)
AC: 54
Touch AC: 24, Flat Footed: 57, SR: 37, CMB: 33, CMD: 51
Init: +12, Touch Atk: 38
Active: Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body: Fire (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength/Mind/Agility/Endurance/Beauty of the Dragon Princess (CL28), Bibliotheca Arcana (CL28), Create Magic Tattoo (CL24), Create Magic Tattoo (CL24), Energy Immunity: Acid/Cold/Electricity/Sonic (CL26), Epic Mage Armor (CL28), Greater Arcane Sight (CL28), Intellect Fortress: 5rnds All savable damage halved so long as SR/PR applies
Passive: True Seeing, Detect Magic, +15 to knowledge checks
Noted. I'll talk to you about that later. As to the question if you can dispel and if you can will you ?
I see you guys forgot to add Celestial Valor to your sheets.
#396
Can I tell the CL of it? Gonna guess 40, but you know what they say about assumptions. Also what spell level and school, please? I'll roll whatever if you need me to.
Surraruthru
AC: 54
Active: Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body: Fire (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength/Mind/Agility/Endurance/Beauty of the Dragon Princess (CL28), Bibliotheca Arcana (CL28), Create Magic Tattoo (CL24), Create Magic Tattoo (CL24), Energy Immunity: Acid/Cold/Electricity/Sonic (CL26), Epic Mage Armor (CL28), Greater Arcane Sight (CL28), Intellect Fortress: 5rnds All savable damage halved so long as SR/PR applies, Celestial Valor
30, not as strong as the primals, who have notably powerful caster levels.
 Eh, I'll counter it with a Greater Dispel Magic.
> roll 1d20+41 GDM Serith
<Kotono> Choose and reroll.
<Serith> Iddy roll for Serith < 53 > [d20=12]
The spell is stopped, Surraruthru flinging out yet another dispel to block it.
Levistus (60) > Jaela (48) > Primal 1 (44) > Primal 2 (43) > Amea = Ice Monolith 1 = Ice Monolith 2 (41) > Primal 3 (39) > Ice Weird (36) > Primal 4 (32) > Surraruthru (30) > Simmer (27) > Gelugon Commanders = Calleigh (25) > Tryll (24) > Elemental Armies (18) > Balyss (11)
"They're strong, master," The ice weird murmurs, as Levistus appears unconcerned.
Meanwhile, the fourth primal elemental gathers in power, as...
It's a sheer, raking blast of piercing cold over all of you. Lots of damage, lots of pain. Custom spell, forged of sheer elemental will. Countering anyone yes/no?
Arcane Sight/CL/Level/School?
Can I take 10 on Spellcraft?
40, 13th, evocation.
You can, generally.
I'll throw a GDM at it. Worrying how many of these I'm going through on this first round.
[blockquote]Rolled 1d20+41 : 19 + 41, total 60[/blockquote]
With another cry, Surru unravels another spell. Whew! The elemental holds position as...
Go Surru, your turn.
What do my MAGIC EYES reveal to me about spells still on the enemies? The rough idea is to smack 'em with a Rain of Devastation, but if there are not enough spell levels out there for it to be worth it...
