Gar Malleos II (Tryll, Surraruthru)
Started by Anastasia, January 08, 2018, 10:22:29 PM
Since Tryll's not here, can someone roll Ref for him?
[blockquote]Rolled 1d100 : 1, total 1[/blockquote] incorporeality
[blockquote]Rolled 1d20+27 : 11 + 27, total 38[/blockquote] Reflex
This looks like it will probably hurt, so Tryll once again shields the party!
Intellect Fortress, 4 rounds of it.
HP: 691+54=745
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (fire) (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength of the Dragon Princess (CL28), Mind of the Dragon Princess (CL28), Agility of the Dragon Princess (CL28), Endurance of the Dragon Princess (CL28), Beauty of the Dragon Princess (CL28), Create Magic Tattoo (+1 luck ATK) (CL24), Create Magic Tattoo (+2 comp ATK) (CL24). Create Magic Tattoo (+1 CL/ML) (CL24), Energy Immunity (all elements) (CL26), True Seeing (CL30), Inertial Armor (CL30)
Bonuses: +4 insight to STR/Dex/CON/Int/CHA, +1 luck to ATK, +2 comp to ATK, +1 CL/ML, Energy Immunity, +1 morale to ATK & Will, Immune to Fear, +18 armor to AC (applies to incorporeal touch)
Resources Used: 167/789
HP: 345+54=399+18
Spells Active: Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (fire) (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength of the Dragon Princess (CL28), Mind of the Dragon Princess (CL28), Agility of the Dragon Princess (CL28), Endurance of the Dragon Princess (CL28), Beauty of the Dragon Princess (CL28), Create Magic Tattoo (+1 luck ATK) (CL24), Create Magic Tattoo (+2 comp ATK) (CL24). Create Magic Tattoo (+1 CL/ML) (CL24), Energy Immunity (all elements) (CL26), True Seeing (CL32), Inertial Armor (CL32), Intellect Fortress (CL 32)
Bonuses: +4 insight to STR/Dex/CON/Int/CHA, +1 luck to ATK, +2 comp to ATK, +1 CL/ML, Energy Immunity, +1 morale to ATK & Will, Immune to Fear, +18 armor to AC (applies to incorporeal), 18 temp HP
Resources Used: Hope[/i]
The attack was noted as bypassing incorporeality.
300 damage. Jaela takes none, Tryll takes full.
The blast flies, Jaela dodging to the side. Tryll is slower, hit by it and sent careening back. It hurts, throbs, stings, freezes, burns. His mind reels from the impact as...
Harkin.
Harkin bellows a warcry and brings his hammer down, a massive gout of the same energy flying at Tryll, following up at the wounded hero. It gleams over him and...
> roll 1d20+73 ranged touch
<Rei-chan> Kotono rolled : 1d20+73 ranged touch --> [ 1d20=5 ]{78}
Touch AC? Good thing you have lots of hit points.
Intellect fortress isn't an incorporeality effect. Did SR/PR apply?
Also not that.
That was to Moore's roll before you posted just before me. Fortress applies but it's not an SR/PR triggering effect.
300 more damage, also buffered down.
Init is Jaela (35) > Ettan (31) > Harkin (30) > Calleigh (27) > Simmer (23) > Surraruthru = Tryll (20) > Balyss (12)
Calleigh is up.
Tryll's form disperses with an agonized noise, then abruptly snaps back together as though the strikes never happened.
'Hello, Harkin. I can do that regeneration trick, too. Can you stop us before we undo yours?' Tryll taunts!
Using 2 charges of Paragon's Fortune.
Calleigh's head pokes out of the rock. "Surprise!" Then she vanishes back inside.
At the same time, a very large humanoid appears directly above Harkin and proceeds to fall on him. It leads with its fists.
[blockquote]Rolled 1d20+30 : 7 + 30, total 37[/blockquote][blockquote]Rolled 1d20+30 : 13 + 30, total 43[/blockquote][blockquote]Rolled 1d20+30 : 15 + 30, total 45[/blockquote]
Calleigh drops a Huge astral construct on Harkin's head. +2 to to those attacks if flanking applies. It should, because he's not attacking from the front.
HP: 691+54=745
Resources Used: 167/789, 2 charges of Paragon's Fortune.
HP: 345+54=399+18
Resources Used: Hope, 68/800 Astral Legion Psicrown
You get a bellow of fury, "You won't stop us or your whore half blood!"
Harkin is fast - able to parry the blows, now with a giant astral construct in his face as...
Simmer, Surraruthru and Tryll. As direct damage is problematic here, Simmer will hold pending you two. Go S&T.
Surraruthru begins casting, planning to get an unobstructed and secret look at the two!
Time Stop, CL 29
> roll 1d4+1
<Serith> Iddy roll for Serith < 4 > [d4=3]
Okay, you have four rounds to go and play with. Go for it.
Round 1: Double move to get to the two so that Arcane Sight works and then INSPECT THEM.
Follow on rounds will depend on the results of the inspection!
Okay, cool. Follow up with Spellcraft- yes, I know this normally doesn't apply with greater arcane sight in play. You're looking at a naked ley line, it's an exceptional situation.
> roll 1d20+57 Spellcraft
<Serith> Iddy roll for Serith < 66 > [d20=9]
