Gar Malleos II (Tryll, Surraruthru)
Started by Anastasia, January 08, 2018, 10:22:29 PM
It's hard to even look at. The magic on them is so overwhelming that you can only detect the ley line's power, but it's fearsome indeed. It's channeling life energy directly into them, using Lifasa's own energy to protect them. So long as that exists, you can only wound Lifasa instead of them.
It may be possible to dispel the link, but it would be exceptionally difficult and require vast skill. Alternately, somehow distancing them from the source of power may help.
Is there a way I can use spellcraft or something to alter the spell? Make it so that the spell channels only one way? To keep the damage from them from going into Lifasa? They'd still be receiving the energy, but it could be the first step. Alternately, is there a way I could coordinate dispel attempts with Jaela to boost our chances?
Not really, it's a live spell that you can't effect in time stop. Out of it you're in the middle of combat, it's just too live a situation to even get creative like that.
If you two dispelled together I'd allow a bonus, sure.
Okay, then I'll return to the others and run out the time stop and relay what I figured out to them with the plan.
Cool, say so IC. Simmer's still holding so Tryll is up.
'The spell is powerful. I can't do much against it unless I get really luck. But, if Jaela and I work to dispel it together, that might be enough.'
'Agreed,' Jaela concurs with Surraruthru. 'And instead of attacks, try to get one of them farther away from the leyline. That might weaken the link, or drop it altogether. Summoned monsters should do the trick for that.'
'You want bodies or more help dispelling?' Tryll replies.
'The more the better. The spell is very powerful.
'A shared dispel, first, and then a summons if this plan fails.'
'Can do.' Tryll readies an action: Twinned Psionic Dispel.
Init is Jaela (35) > Ettan (31) > Harkin (30) > Calleigh (27) > Simmer (23) > Surraruthru = Tryll (20) > Balyss (12)
"Ready!" Balyss says.
Holding to heal if needed. Jaela.
#509
Jaela will hold for the combo dispel.
Init: +22 (Sign, Grace), CHA +2, CL31
HP: 520+20/520
AC: 89 =76base+2Foresight+3Recitation+5ShieldOfWarding+1Grace+2AotDP, 20% miss chance
Touch AC: 83 =70base+2+3+5+1+2
Full Attack (Gae Buidhe +7, haste, HW, K:D +5): +51/+51/+46/+41/+36, 1d8+38+3d12 goldenfire
Full Attack (Gae Bolg, GMW, Haste, HW, K:D +5, vs devils only): +53/+53/+48/+43/+38, 4d8+40+11d6 and 1 negative level
Combat: Greater Heroism +4 morale/attack, Good Hope +2 morale/damage, Recitation +3 luck/attack, SotDP +2 attack/+3 damage, CMT +2 competence/attack, Celestial Valor +4 sacred attack/damage, Divine Might +17 damage: +15 attack, +26 damage
Gae Buidhe: The wielder acts outside of fate and destiny, they are immune to divinations (with the exception of detect good, which always reveals an overwhelming aura of good). Luck and insight bonuses to attack rolls, weapon damage rolls and DCs do not apply against attacks on the wielder, while the same bonuses to armor class and saving throws do not apply against attacks the wielder makes. Additional abilities that explicitly manipulate destiny or use it as a tool also fail (the DM's discretion is used to determine abilities that qualify for this).
[not used: Divine Favor +3 luck/damage]
Spells Active: Spell Turning CL26, Contingency CL36, Permanency/Greater Blindsight CL36, Permanency/Mantle of Good CL37, Foresight CL27, Moment of Prescience CL25, Lore of the Gods CL30, Invisibility Purge CL30, Fortunate Fate CL15, Mind Blank CL17, Greater Mage Armor CL7, Planar Tolerance CL7, Heroes Feast CL20, Righteous Halo CL30, Vision of the Omniscient Eye CL30, Greater Heroism CL30, Shield of Warding CL31, Conviction CL31, Crown of Flame CL30, Sign CL30, Divine Insight CL30, Interplanar Telepathic Bond CL26, Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30.
Short Duration Spells: Grace CL30, Recitation CL30, Haste CL27, Celestial Valor CL32.
Tryll: Intellect Fortress round 1/5: All savable damage halved so long as SR/PR applies.
Surru Spells: Energy Immunity (Acid, Cold, Sonic, Electricity) CL26, Elemental Body/Fire CL28, *Surraruthru's Stupendous Dragonskin CL 28, Strength of the Dragon Princess CL 28, Mind of the Dragon Princess CL 28, Agility of the Dragon Princess CL 28, Endurance of the Dragon Princess CL 28, Beauty of the Dragon Princess CL 28, *Create Magic Tattoo (+1 Luck to attack) CL 24, Create Magic Tattoo (+2 Competence to attack) CL 24, Create Magic Tattoo (+1 CL) CL 24,
Resistances and Immunities: Fire Immunity, Cold Immunity, Acid Immunity, Electricity Immunity, Sonic Immunity, Damage Reduction 25/Epic and Evil and Cold Iron, Spell Resistance 37 (49 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Immunity to fear and poison/Heroes's Feast, Immunity to dazzled and blinded/Vision of the Omniscient Eye, Never surprised or flat-footed/Foresight, physical damage reduced by half/Sublime Revelry. You are immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking/Elemental Body.
Old: Cold Resistance 10, Acid Resistance 20, Electricity Resistance 20, Sonic Resistance 20
Original:
Spells Left (1-9): 10/9/9/7/9/9/8/7/8
Spells Left (10-12): 8/6/4
Current:
Spells Left (1-9): 5/5/5/3/7/8/8/5/7
Spells Left (10-12): 6/1/3
Saves: conviction +5, recitation +3, hidden dawn +7, celestial valor +4 : +19; eotdp fort +2; foresight ref +2, haste ref +1, shield of warding ref +5, grace ref +1, aotdp ref +2.
Saves: Fort +73, Ref +74, Will +71
Gae Bolg: GMW, Keen Edge
Gae Trocaire: GMW, Keen Edge
Turning Left: 17/20
-Smites x1
-Mountainous Fire summons
-Channeled twinned Bolt of Glory into Gae Buidhe
-Bead of Karma
-True Strike x2
-Time Stop x1
-Spell Turning x1
-Foresight x1
-Moment of Prescience x1
Taking ten for K:A 62, K:N 41, K:R 66, K:P 66, Spellcraft 56
Hidden Dawn used with Mirajane
Golden Bracers (Hidden Dawn):
Flame Strike at will as an SLA
Sunburst at will as an SLA
Immunity to fire
Save bonuses increase to +7
Goldenfire damage on weapon damage rolls, natural attacks and spells and spell-like abilities with the fire descriptor rises to +6d6, unlimited range as long as on same plane.
Goldenfire Spell [Epic, Exalted]
Prerequisite: Searing Spell, con 25, must worship Lathander or another of the House of Nature
Benefit: A goldenfire spell ignores the immunity and resistance to fire of creatures affected by the spell. Evil creatures take 50% more damage from a goldenfire spell and suffer a -7 penalty to the saving throw, if applicable. The spell gains the good descriptor if it does not already have it. Any spell modified with goldenfire gains a sacrifice component of 1 point of Constitution damage. A goldenfire spell uses up a spell slot 3 levels higher than the spells's actual level.
