To war once again (Moore)
Started by Anastasia, January 17, 2018, 04:21:53 PM
"This idiot can't even tell my mirror images apart." Moore says, scoffing. He gestures and flings a bolt of energy at the cornugon!
[14:17] <Nephrite> roll 1d20 ranged touch
[14:17] <Serith> Nephrite roll for Serith < 16 > [d20=16]
Bolt of Glory.
[14:17] <Nephrite> roll 15d6
[14:17] <Serith> Nephrite roll for Serith < 45 > [d6=3,3,5,4,5,1,1,1,5,6,1,4,3,2,1]
That is way too many 1's for my taste.
[22:03] <Nephrite> roll 1d20+28 SR
[22:03] <Serith> Nephrite roll for Serith < 36 > [d20=8]
The bolt hits the cornugon, momentarily staggering him as holy power wracks his body. His scales glow white before it fades away and...
Anything else this round or is that it?
He's just keeping up his Inspire Courage so that's it.
As you keep your song up, suddenly a column of fire erupts overhead, slamming down into you.
Ref.
[blockquote]Rolled 1d20+66 : 15 + 66, total 81[/blockquote]
You nimbly dodge the column of fire, avoiding it altogether. It came from above but no one's there as...
> roll 1d20+60
> roll 1d20+60
> roll 1d20+60
> roll 1d20+55
<Rei-chan> Kotono rolled : 1d20+60 --> [ 1d20=9 ]{69}
<Rei-chan> Kotono rolled : 1d20+60 --> [ 1d20=16 ]{76}
<Rei-chan> Kotono rolled : 1d20+60 --> [ 1d20=20 ]{80}
<Rei-chan> Kotono rolled : 1d20+55 --> [ 1d20=4 ]{59}
> roll 1d20+50
<Rei-chan> Kotono rolled : 1d20+50 --> [ 1d20=4 ]{54}
> roll 1d20+45
<Rei-chan> Kotono rolled : 1d20+45 --> [ 1d20=13 ]{58}
> roll 1d20+60 crit checkorama
<Rei-chan> Kotono rolled : 1d20+60 crit checkorama --> [ 1d20=6 ]{66}
> How demonic.
> roll 3d8+33
<Rei-chan> Kotono rolled : 3d8+33 --> [ 3d8=14 ]{47}
> roll 3d8+33
<Rei-chan> Kotono rolled : 3d8+33 --> [ 3d8=13 ]{46}
> roll 6d8+66
<Rei-chan> Kotono rolled : 6d8+66 --> [ 6d8=24 ]{90}
> roll 3d8+33
> roll 3d8+33
As the Master fights, the third malebranche going down?
'Moore, disengage and redeploy to the gates of the Fallen Throne, Mirima needs boosts there for her troops.' Sage Vul'lath sends.
Enemies pending your reply.
'Understood. The Master should have this under control now, but make sure someone keeps an eye out -- we've got some long-range spell-casters harrying us here.'
How far, approximately, is it to that location?
About 500ft down and 1500ft away. You also have a cornugon still trying to kill you.
Yeah, well, fuck that guy.
'Master, I'm leaving this one to you -- you have about a minute's worth before my songs stop working after I leave. I could also take you along.' Moore sends to him.
He is going to try and just Dimension Door all the way over there. Presuming The Master wants to stay here (which I am guessing he will) he will go and can make 1520 ft with one Dimension Door. He is not concerned about the cornugon's attempt at killing him for various reasons.
Indeed, as you do that, the cornugon snarls and fire erupts around you.
Ref on its turn, since it just can't seem to touch you.
[13:04] <Nephrite> roll 1d20+66 evasion
[13:04] <Rei-chan> Nephrite rolled : 1d20+66 evasion --> [ 1d20=13 ]{79}
I forgot the dice bot doesn't include extra lines again, sorry about that.
In a blink you're there. Castle gates are held by Mirima and the Graceful Blow, defending against a tide of devils, thick and relentless. They're holding the line but visibly pressed, and from here, you can see a vast wedge of devils is funneling towards this.
#59
He doesn't even need to say anything, he will just raise his voice and the inspiration will come.
[13:15] <Nephrite> roll 3d4 nonlethal
[13:15] <Rei-chan> Nephrite rolled : 3d4 nonlethal --> [ 3d4=7 ]{7}
Inspirational Boost as a Swift, +1 morale bonus to Inspire Courage.
Inspire Courage, everyone gets +17 to all their stuff to make people hit gud.
That will do it for his turn, as he used his standard to get here then his movement to use IC.
EDIT: Master will also still have the effects of Snowsong on him since it's localized to an area and doesn't follow the caster. Not that he's in any real danger anyway, but the extra cold damage and fast healing might help!
Active Spells: mind blank (CL17), fortunate fate (CL15), planar tolerance (CL7) and greater mage armor(CL5), Superior Resistance (CL 24), True Seeing (CL10), Bibliotecha Arcana (CL27), Harmonize (CL28), Righteous Halo (CL17), Foresight (CL28), Tapestry Buffs
HP: (52)417/417
AC: 62(72)(84), 46 (56) touch, 52 (62) flatfooted 20% miss chance, SR 41, 30 resist all to elements
20/32 Bardic music uses 3/3 Refrain
Saves: Fort +36(48), Ref +40(54), Will +41(51) (+6 due to Superior Resistance)
Stats: STR 18(22) (+6) DEX 31(35) (+12) CON 26(30) (+10) INT 32(36) (+13) WIS 22 (+6) CHA 35(43) (+16)
Spells:
0th - 4/4 (DC 22)
1st - 5/7
2nd - 6/7
3rd - 6/7
4th - 5/7
5th - 6/6
6th - 6/6
7th - 5/6
8th - 4/5
9th - 1/1
Favored Soul:
0th - 5/5
1st - 9/9
2nd - 9/9
3rd - 8/8
4th - 7/8
5th - 8/8
6th - 7/8
7th - 6/6
8th - 3/4
Tapestry Buffs
Elemental Body (fire) CL 28, 28 hour duration,
Surraruthru's Stupendous Dragonskin, CL 28, 28 hour duration
Strength of the Dragon Princess, CL 28, 28 hour duration
Mind of the Dragon Princess, CL 28, 28 hour duration
Agility of the Dragon Princess, CL 28, 28 hour duration
Endurance of the Dragon Princess, CL 28, 28 hour duration
Beauty of the Dragon Princess, CL 28, 28 hour duration
Create Magic Tattoo, CL 24, 24 hour duration (+1 luck bonus to attack)
Create Magic Tattoo, CL 24, 24 hour duration (+2 morale bonus to attack)
Create Magic Tattoo, CL 24, 24 hour duration (+1 caster level)
Energy Immunity (x4) CL 26, 24 hour duration (Grants complete protection agianst: acid, cold, electricity, sonic)
Evacuation Rune, CL 25, 24 hour duration.
