The Assault on Avernus
Started by Anastasia, May 08, 2018, 02:48:19 PM
Current distance from Glasya?
The whole 'haha you're man-like' routine is bad enough from tavern drunks, but coming from a planar lord it just feels especially petty, and Alicia's opinion of Glasya lowers commensurately.
'How is Glasya in a fight Donald? She doesn't look injured,' she tries to get some further details from her allies before she commits to action, recalling how difficult it was to lay her blade on Lixer's avatar.
'She's good and her wounds don't stick. They just vanish,' Donald sends back.
Okay, metagamey but I've seen Glasya's statblock and I know about the passing onto minions bit.
Would that be overcome with a rank check? I can take 10 for 62 on planes.
You've heard of it but don't know details, but know that you've never heard of it being overcome. Glasya isn't in combat often, admittedly, so you don't have much info to work with.
Then perhaps it's best to just put her in time out for now.
Quickened Time Stop. Any countermeasures or spell-stowaways?
[18:21] <@Ebiris> roll 1d4+1
[18:21] <Kobot> Ebiris rolled 1d4+1 --> [ 1d4=2 ]{3}
Alicia: 624/624
Active spells: Extended nondetection (CL 31), extended greater anticipate teleportation (CL 31), foresight (CL 31), true seeing (CL 31), mass death ward (CL 31), greater heroism (CL 31), miracle (diseaseimmunity, CL 31), vision of the omniscient eye (CL 31), energy resistance x5 (CL 31), spell turning (CL 31), fortunate fate (CL 31), interplanar telepathic bond (CL 31), good hope (CL 31), righteous wrath of the faithful (CL 30), dance of the unicorn (CL 30), recitation (CL 30), greater visage of the deity (CL 30), extended repelling shield (CL 31), master's touch (CL 30), sensual blessing (CL 30), ghost touch weapon (CL 30), ghost touch armour (CL 30), consecrated ward (CL 31), many moments of prescience (CL 30)
Defences: AC 73 (touch 37, incorp touch 56), CMD 107, spell resistance 45, energy immunity (fire, cold), energy resistance 30 (all), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affection, fear, dazzled, blinded), freedom of movement, nondetection (DC 46)
Stat buffs/penalties: +2 insight AC/reflex, +4 morale attack/skills/saves, +10 insight perception, +3 morale damage, +2 morale ability checks, +2 luck attack/saves, +4 Str, +2 Dex, +4 Con, +2 Int, +4 Wis, +4 Cha, +1 natural armour, +7 shield AC, +4 insight skills, +25 competence perception
Perceptions: Darkvision, scent, low-light vision, blindsight, tremorsense 1 mile, true seeing, perception +83
Sorcerer spell slots: 6/8/8/4/4/3/4/8/6/7/4/3/4/1
Duskblade spell slots: 6/12/11/10/9/3
Yes.
Thus you cat. At the same time a ring of Glasya's finger glows bright, radiant. The Lord of the Sixth chuckles, "Ah, a private battle?" she asks, as everything else goes still around you. She slowly saunters forward, "You goodly types, always getting into fights you can't hope to win. It's endearing."
Continue the rest of your turn.
So... other creatures can't be affected during time stop. So time-stopped devils would be safe from having damage deflected onto them?
"It shortens things a lot, but I expect you're used to that," Alicia retorts, figuring she's got no choice but to focus on defeating Glasya now. But... she recalls Taelfagn's last battle, the reports she read of it. If Glasya is using a similar method to avoid injury, she's just signed her own death warrant.
The next thing that happens is Alicia looms over Glasya and the stilled battlefield of Avernus, her sword whirling down to slice into the Lord of Hell over and over much as happened to Lixer. Only this time she front-loads her assault rather than holding it back.
Swift to go colossal+, full attack. Will have a swift left over depending on how this plays out.
[18:39] <@Ebiris> roll 1d20+81+30 channelled vivacious flux grasp, 12th level arcane strike, divine might, blinding speed (2/5 rounds), moment of prescience
[18:39] <Kobot> Ebiris rolled 1d20+81+30 channelled vivacious flux grasp, 12th level arcane strike, divine might, blinding speed (2/5 rounds), moment of prescience --> [ 1d20=4 ]{115}
[18:39] <Kobot> Ebiris rolled 1d20+81+30 channelled vivacious flux grasp, 12th level arcane strike, divine might, blinding speed (2/5 rounds), moment of prescience --> [ 1d20=6 ]{117}
[18:39] <@Ebiris> roll 1d20+76+30 channelled vivacious flux grasp, 12th level arcane strike, divine might, blinding speed (2/5 rounds), moment of prescience
[18:39] <Kobot> Ebiris rolled 1d20+76+30 channelled vivacious flux grasp, 12th level arcane strike, divine might, blinding speed (2/5 rounds), moment of prescience --> [ 1d20=9 ]{115}
[18:39] <@Ebiris> roll 1d20+76+30 channelled vivacious flux grasp, 12th level arcane strike, divine might, blinding speed (2/5 rounds), moment of prescience will smite for +20 more if previous attacks failed
[18:39] <Kobot> Ebiris rolled 1d20+76+30 channelled vivacious flux grasp, 12th level arcane strike, divine might, blinding speed (2/5 rounds), moment of prescience will smite for +20 more if previous attacks failed --> [ 1d20=10 ]{116}
[18:39] <@Ebiris> roll 1d20+71 channelled vivacious flux grasp, 12th level arcane strike, divine might, blinding speed (2/5 rounds)
[18:39] <Kobot> Ebiris rolled 1d20+71 channelled vivacious flux grasp, 12th level arcane strike, divine might, blinding speed (2/5 rounds) --> [ 1d20=1 ]{72}
[18:39] <Kobot> Ebiris rolled 1d20+71 channelled vivacious flux grasp, 12th level arcane strike, divine might, blinding speed (2/5 rounds) --> [ 1d20=14 ]{85}
[18:39] <@Ebiris> roll 1d20+66 channelled vivacious flux grasp, 12th level arcane strike, divine might, blinding speed (2/5 rounds)
[18:39] <Kobot> Ebiris rolled 1d20+66 channelled vivacious flux grasp, 12th level arcane strike, divine might, blinding speed (2/5 rounds) --> [ 1d20=7 ]{73}
[18:39] <Kobot> Ebiris rolled 1d20+66 channelled vivacious flux grasp, 12th level arcane strike, divine might, blinding speed (2/5 rounds) --> [ 1d20=15 ]{81}
[18:40] <@Ebiris> roll 1d20+61 channelled vivacious flux grasp, 12th level arcane strike, divine might, blinding speed (2/5 rounds)
[18:40] <Kobot> Ebiris rolled 1d20+61 channelled vivacious flux grasp, 12th level arcane strike, divine might, blinding speed (2/5 rounds) --> [ 1d20=8 ]{69}
[18:40] <Kobot> Ebiris rolled 1d20+61 channelled vivacious flux grasp, 12th level arcane strike, divine might, blinding speed (2/5 rounds) --> [ 1d20=11 ]{72}
[18:40] <@Ebiris> roll 6d6+55+3d6+2d6+12d4+2*30d12
[18:40] <Kobot> Ebiris rolled 6d6+55+3d6+2d6+12d4+2*30d12 --> [ 6d6=19 3d6=10 2d6=5 12d4=33 30d12=206 ]{534}
[18:40] <Kobot> Ebiris rolled 6d6+55+3d6+2d6+12d4+2*30d12 --> [ 6d6=26 3d6=10 2d6=8 12d4=26 30d12=185 ]{495}
[18:40] <Kobot> Ebiris rolled 6d6+55+3d6+2d6+12d4+2*30d12 --> [ 6d6=20 3d6=11 2d6=8 12d4=25 30d12=177 ]{473}
[18:40] <Kobot> Ebiris rolled 6d6+55+3d6+2d6+12d4+2*30d12 --> [ 6d6=28 3d6=12 2d6=8 12d4=38 30d12=220 ]{581} +5 more damage if smite applied
[18:40] <Kobot> Ebiris rolled 6d6+55+3d6+2d6+12d4+2*30d12 --> [ 6d6=23 3d6=13 2d6=8 12d4=36 30d12=173 ]{481}
[18:40] <Kobot> Ebiris rolled 6d6+55+3d6+2d6+12d4+2*30d12 --> [ 6d6=18 3d6=16 2d6=7 12d4=30 30d12=199 ]{524}
[18:41] <Kobot> Ebiris rolled 6d6+55+3d6+2d6+12d4+2*30d12 --> [ 6d6=16 3d6=9 2d6=8 12d4=35 30d12=205 ]{533}
[18:41] <@Ebiris> roll 6d6+55+3d6+2d6+12d4+2*30d12
[18:41] <Kobot> Ebiris rolled 6d6+55+3d6+2d6+12d4+2*30d12 --> [ 6d6=19 3d6=5 2d6=12 12d4=24 30d12=192 ]{499}
[18:41] <Kobot> Ebiris rolled 6d6+55+3d6+2d6+12d4+2*30d12 --> [ 6d6=22 3d6=11 2d6=6 12d4=23 30d12=205 ]{527}
[18:41] <Kobot> Ebiris rolled 6d6+55+3d6+2d6+12d4+2*30d12 --> [ 6d6=14 3d6=10 2d6=6 12d4=26 30d12=150 ]{411}
Alicia: 624/624
Defences: AC 77 (touch 28, incorp touch 46), CMD 107, spell resistance 45, energy immunity (fire, cold), energy resistance 30 (all), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affection, fear, dazzled, blinded), freedom of movement, nondetection (DC 46)
Stat buffs/penalties: +2 insight AC/reflex, +4 morale attack/skills/saves, +10 insight perception, +3 morale damage, +2 morale ability checks, +2 luck attack/saves, +36 Str, -2 Dex, +20 Con, +2 Int, +4 Wis, +4 Cha, +15 natural armour, -8 size AC/attack, +7 shield AC, +4 insight skills, +25 competence perception
Sorcerer spell slots: 6/8/8/4/4/3/4/8/6/7/4/3/3/0
Glasya is like smoke - impossible to touch, blurring as your blade comes close to dodge. You can't lay a hand on her - until you channel pure holy power into it. That is enough for one moment, a slash across her face. Her dress glows as she glares, the wound mostly healed in an instant, just a few droplets of blood marring her face.
"Oh, that was amusing," Glasya says, as...
Glasya used an immediate there. Anything else or is your turn done?
The smite hit but the others didn't. She didn't come in unprepared.
That really did not go as well as she'd hoped. Still, she'll make use of her sword while it's still full of divinely charged acid - she won't be good for another of those today after all, so she quickly whips her arm out and sends the titanic Bonds scything through Glasya and back again!
[19:01] <@Ebiris> roll 1d20+83 quickened whirling blade please crit
[19:01] <Kobot> Ebiris rolled 1d20+83 quickened whirling blade please crit --> [ 1d20=6 ]{89}
Alicia: 624/624
Sorcerer spell slots: 6/8/8/4/3/3/4/8/6/7/4/3/3/0
Your blade is blurred past, Glasya moving to the side fast as the wind. "You're good," Glasya admits, "I'd have use for someone like you. But someone like you isn't going to be interested, are you?"
"I've had offers before, yours are no different," Alicia returns, bracing herself for the counterattack.
Glasya's wound heals the rest of the way as she asks, "What drives you so, Alicia? You know this is suicidal." Her voice is back to being sweet, "Tell me what motivates you." Her voice is heard easily, despite the size difference, as...
How many things do you have up to dispel and the CL on them? She's dispelling you.
Has it been long enough for spell turning to be functional again?
