Raven's Nest
Started by Anastasia, June 04, 2018, 11:25:43 AM
Seira breathes goldenfire down the murderholes!
[21:51] <@Lisa> roll 20d10
[21:51] <Kobot> Lisa rolled 20d10 --> [ 20d10=97 ]{97}
Alicia meanwhile carves a needle-thin ray of silver fire through the door's hinges!
[19:54] <@Ebiris> roll 40d10
[19:54] <Kobot> Ebiris rolled 40d10 --> [ 40d10=232 ]{232}
Stone sizzles under the goldenfire, soldiers within perhaps burnt as stone liquefies under your superhot breath, slowly starting to roll down the front of the castle. At the same time, as Seira breaths all over the murder holes, Alicia smoothly bores out the hinges of the gates. They stay up, but the hinges should be good and shot now.
"On three?" Seira offers, counting off before turning about and slamming her tail into the gates!
That's enough for Alicia to go kick the door down!
[20:01] <@Ebiris> roll 1d20+32 strength
[20:01] <Kobot> Ebiris rolled 1d20+32 strength --> [ 1d20=11 ]{43}
Alicia: 864+62/864
Active spells: Extended nondetection (CL 31), many moments of prescience (CL 31), extended greater anticipate teleportation (CL 31), foresight (CL 31), death ward (CL 30), greater heroism (CL 31), vision of the omniscient eye (CL 31), spell turning (CL 31), good hope (CL 31), righteous wrath of the faithful (CL 30), dance of the unicorn (CL 30), recitation (CL 30), greater visage of the deity (CL 30), extended repelling shield (CL 31), master's touch (CL 30), sensual blessing (CL 30), celestial valor (CL 31), glorious rally (CL 31), divine insight (CL 31)
Defences: AC 72 (touch 36), CMD 116, spell resistance 45, energy immunity (fire, cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affection, fear, dazzled, blinded), freedom of movement, nondetection (DC 46)
Stat buffs/penalties: +2 insight AC/reflex, +6 morale attack/damage/AC/saves, +4 morale skills, +10 insight perception, +3 morale damage, +2 morale ability checks, +3 luck attack/saves, +36 Str, -2 Dex, +20 Con, +2 Int, +4 Wis, +4 Cha, +15 natural armour, -8 size AC/attack, +7 shield AC, +4 insight skills, +25 competence perception, +4 sacred attack/damage/AC/saves
Perceptions: Darkvision, scent, low-light vision, blindsight, tremorsense 1 mile, true seeing, perception +83
Sorcerer spell slots: 6/8/8/4/5/5/5/7/5/5/7/4/5/4
Duskblade spell slots: 6/12/11/9/9/4
[22:02] <@Lisa> roll 1d20+20+1
[22:02] <Kobot> Lisa rolled 1d20+20+1 --> [ 1d20=16 ]{37}
"Three!" Antenora call, charging in to shoulder check the door.
> roll 1d20+13 Antenora
<Kobot> Kotono rolled 1d20+13 Antenora --> [ 1d20=4 ]{17}
> roll 1d20+8 Amaryl
<Kobot> Kotono rolled 1d20+8 Amaryl --> [ 1d20=6 ]{14}
> roll 43+37+17+14
<Kobot> Kotono rolled 43+37+17+14 --> {111}
Tail and shoulder, boot and ram. It's enough, Amaryl adding her own charging kick to the doors as you all hit them. The gates groan and fall inward with a tremendous CLANG, crashing through stone even louder, landing heavily and shaking the castle. Past the fallen gates is a hall, a partially intact force of air elementals of medium and large size ahead. On seeing you they flow out towards you - easily a few hundred if you don't miss your guess.
Incoming!
Init, y'all.
Antenora
HP: 550+42/550
Spells Active: Good Hope (CL31), Celestial Valor (CL31), Glorious Rally (CL31), Recitation (CL31), Divine Insight (CL31), Divine Presence (CL30), Righteous Wrath of the Faithful (CL31), Death Ward (CL30), Mind Blank (CL31), Vision of the Omniscient Eye (CL31), Foresight (CL31), Spell Turning (CL31)
Bonuses: +6 morale attack rolls, weapon damage rolls, saving throws and armor class, +2 morale ability checks and skill checks, +8 sacred saves vs fear and negative emotion magic, +4 sacred attack, saving throws, armor class and weapon damage rolls, nonstacking holy on all weapons, immunity to fear, +2 luck attack roll sand saving throws, +15 to one skill check, +5/+10/+15 (does not worship Alicia/one alignment opposed/both alignments opposed) sacred bonus to Intimidate, extra attack on full attack, death ward immunities, +10 insight spot.
Resources Used: Divine Presence, 1 use of boots
Amaryl
HP: 488+62/488
Spells Active: Good Hope (CL31), Celestial Valor (CL31), Glorious Rally (CL31), Recitation (CL31), Divine Insight (CL31), Amaryl's Greater Arrow Mind (CL17), Righteous Wrath of the Faithful (CL31), Death Ward (CL30)
Bonuses: +6 morale attack rolls, weapon damage rolls, saving throws and armor class, +2 morale ability checks and skill checks, +8 sacred saves vs fear and negative emotion magic, +4 sacred attack, saving throws, armor class and weapon damage rolls, nonstacking holy on all weapons, immunity to fear, +2 luck attack roll sand saving throws, +15 to one skill check, threaten within reach with bow, do not trigger AoOs for using bow, +4 insight ranged attack rolls, +1 bonus attack with with bow as if hasted, extra attack on full attack, death ward immunities, +10 insight spot.
Resources Used: 1 5th level spel
#67
[22:07] <@Lisa> roll 1d20+10
[22:07] <Kobot> Lisa rolled 1d20+10 --> [ 1d20=4 ]{14}
+2 from Good Hope so it's 16.
[spoiler]Seira's spells: nondetection (CL 31), mind blank (CL 31) many moments of prescience (CL 31), moment of prescience (CL 31), greater anticipate teleportation (CL 31), foresight (CL 31), death ward (CL 30), vision of the omniscient eye (CL 31), spell turning (CL 31), good hope (CL 31), righteous wrath of the faithful (CL 30), recitation (CL 31), sensual blessing (CL 31), celestial valor (CL 31), glorious rally (CL 31), greater arcane sight (CL 31), divine insight (CL 31)
DragonSeira: 666/666
Armor Class: 81 (Touch AC 46)
Full Attack (GMF +5, Haste, flanking): +60/+60/+60/+60/+55/+50/+45 (6d10+92+15d6) and bite +58 (4d6+92+15d6) and claw +58 (2d8+83+15d6) and wings +58/+58 (2d6+83+15d6) and tail slap +58 (2d8+101+15d6)
Saves: Fort +61, Ref +52, Will +53
+13 attack, +10 damage
+10 saves (+12 ref), +12 AC
[20:08] <@Ebiris> roll 1d20+22 nerveskitter
[20:08] <Kobot> Ebiris rolled 1d20+22 nerveskitter --> [ 1d20=12 ]{34}
+2 more from good hope so 36
Alicia: 864+62/864
Sorcerer spell slots: 6/7/8/4/5/5/5/7/5/5/7/4/5/4
> roll 1d20+11 Antenora
<Kobot> Kotono rolled 1d20+11 Antenora --> [ 1d20=16 ]{27}
> roll 1d20+28 Amaryl
<Kobot> Kotono rolled 1d20+28 Amaryl --> [ 1d20=2 ]{30}
> roll 1d20+15
<Kobot> Kotono rolled 1d20+15 --> [ 1d20=1 ]{16}
While I tally up init, make K:P checks, y'all.
[20:15] <@Ebiris> roll 1d20+52 planes
[20:15] <Kobot> Ebiris rolled 1d20+52 planes --> [ 1d20=10 ]{62}
As you get in and get a closer look - ah. You n otice the elementals are in formation, in order. Each of them wears a tiny black pin lined with silver. This rings a bell. Before you is a branch of the Black Wind Army, one of Yan-C-Bin's personal forces. This army of medium and large air elementals are honed in the Blood War, learning tactics that they use to devastating effect when they return to Air for combat. They are powerful, efficient warriors who rely on overwhelming their foes with crushing currents of winds and combined attacks, as well as some magic to generate electricity or acid. They are methodical, powerful and relentless, but not stupid.
In the back you can see one in particular, wearing a steel helmet in addition, a large air elemental. In his hands is a scythe - Guster the Slayer, a captain of the Black Wind Army. He can kill virtually anything in a blow of his scythe, if he hits it just so.
'Alicia, this is one of Yan-C-Bin's forces, they forge themselves in the Blood War. Expect good tactics.' Antenora sends. 'I've heard nothing but praise for them. We may want to end this before they can establish a rhythm.'
Init is Alicia (34) > Amaryl (30) > Atnenora (27) > Seira = Black Wind Army (16)
The army begins 50ft away and goes down another 50ft. At the end of this is Guster, so 100ft away.
