Finding Calley
I don't know if you've added it, but everyone has an extra +4 to attack and damage rolls, Improved Critical Feat, +15 to threat confirmation. It isn't fair to just make you retroactively recalculate everything, but just keep it in mind going forward from now if you were not already.
Thank you, this has been a message from the Pixie Broadcasting Station.
I'll add the damage, it doesn't meaningfully change anything and I don't think it changes misses to hits. Lemme add that to the spoiler block, missed it somehow. Good catch.
Cresiel braces a moment, righting himself before whirling, going to charge into them. "This ends!" he declares, flying straight at the pit fiend.
> roll 1d20+97 (+31 Moore, +1 haste, +14 furious strike, +3 valiant fury, +4 pixie) Cresiel
<Serith> Kotono roll for Serith < 99 > [d20=2]
> roll 2d6+43+2d6+7d6
<Serith> Kotono roll for Serith < 84 > [d6=6,1,4,5,4,6,6,5,1,2,1]
The two clash, wand of green fire against warhammer. Cresiel's slam pushes against the flames, which erupt around him and bathe the solar in a flickering green glow. The flames gutter out before Cresiel's blow, which slams into the pit fiend's spare arm, brought up to shield his face. The beast is pushed back, the blow ringing along with a loud CRACK of infernal bone giving way.
Meanwhile, Kaja, "You're mind, slaver!" The half dragon lunges forward, a blur as he races at the efreet - who lashes out suddenly, a wide backhand that...
Kaja can't make the check to avoid the AoO. Additionally, he won't use spring attack here since he wants to end in full attack range. So he just has to take it.
> roll 1d20+103 (+24 ??? (various condensed), +3 ???, +5 ???, +13 smite good)
<Serith> Kotono roll for Serith < 110 > [d20=7]
> roll 2d8+139+3d6+1d6+3d8 and fort
<Serith> Kotono roll for Serith < 174 > [d8=1,1][d6=5,4,6,4][d8=5,3,6]
> roll 1d20+42 Kaja
<Serith> Kotono roll for Serith < 45 > [d20=3][/i]
The blow slams into Kaja's face, a horrid snap of bone and scale. Kaja spits out teeth and blood, face caved in, and yet still going. With a macabre grin he lashes out, holding his position.
The wound is horrific thanks to ability, Kaja failed the save. He cannot speak and is mute until proper healing is obtained.
> roll 1d20+93 (+31 various, +4 pixie, +3 valiant fury) Gem
<Serith> Kotono roll for Serith < 110 > [d20=17]
> roll 1d20+93 (+31 various, +4 pixie, +3 valiant fury) Gem crit?
<Serith> Kotono roll for Serith < 99 > [d20=6]
> roll 4d6+288+2d6
<Serith> Kotono roll for Serith < 308 > [d6=6,1,5,4,3,1]
Bleeding and with a ruined face, Kaja's blade strikes true. He slices deep into the efreet's arm, nearly severing it below the elbow, then across his stomach. Armor is cut through as steam and fire erupts from the wound like blood, lava pouring out. The efreet gasps and stumbles back as Kaja does the same, then...
Disfigured woman is up in the next post. Chance to react.
+6 str/con, +4 attack/damage, improved crit, +15 comfirmation.
Cresiel
HP: 700 (68)/700 (fast healing 11, regeneration 17)
Spells Active: Haste (CL30), Surge of Hope (CL30), Celestial Valor (CL31) Mass Energy Immunity (Fire) (CL31), Mass Death Ward (CL31), Fortunate Fate (CL31), Divine Agility (CL31)
Bonuses: +18 morale attack rolls, weapon damage rolls, saves vs charm/fear, +8 attack rolls, +3 fort saves, +12 morale to saves, +12 dodge to AC, fast healing 11, +1 attack rolls, +1 attacks on full attack, +1 ref, movement speed boost, +4 morale attack rolls, weapon damage rolls, saving throws, ability checks, skill checks, immunity to fear, +8 sacred vs negative emotion, +4 sacred attack rolls, armor class, saving throws, weapon damage rolls, immunity to fire, +10 enhancement agility.
Resources Used: Burst of Glory, Divine Agility,
Xandra
HP: 496 (25)/521 (fast healing 11)
Spells Active: Haste (CL30), Surge of Hope (CL30), Celestial Valor (CL31) Mass Energy Immunity (Fire) (CL31), Mass Death Ward (CL31), Fortunate Fate (CL31), Jetina's Deathlessness (CL31)
Bonuses: +18 morale attack rolls, weapon damage rolls, saves vs charm/fear, +8 attack rolls, +3 fort saves, +12 morale to saves, +12 dodge to AC, fast healing 11, +1 attack rolls, +1 attacks on full attack, +1 ref, movement speed boost, +4 morale attack rolls, weapon damage rolls, saving throws, ability checks, skill checks, immunity to fear, +8 sacred vs negative emotion, +4 sacred attack rolls, armor class, saving throws, weapon damage rolls, immunity to fire, immune to negative energy, energy drain, ability damage, ability drain, poison, paralysis and stunning, half of damage is nonlethal damage
Kaja
HP: 377 (138)/515 (fast healing 11), muted.
Resources Used: 1 dervish dance
Jetina
HP: 412 (67)/478 (fast healing 11)
In total:
Attack: +31
Weapon damage: +22
AC: +16 (4 sacred, 12 dodge)
Saving throws: +16 (4 sacred, 12 morale)
Fast Healing 11
"Come on, you feckless spawn of Belial!" Moore shouts. "You can't even kill a pixie properly! You're next, witch!"
lalalala if Kaja can't talk then someone has to talk for him.
Amid the chaos and bloodshed, the disfigured woman continues to creep back, against an intact wall as she throws again, this time aimed dead on at Kaja.
> roll 1d20+86 (+24 ??? (various condensed), +3 ???, +8 ???, +1 ???)
<Serith> Kotono roll for Serith < 95 > [d20=9]
> roll 1d2+39+2d6
<Serith> Kotono roll for Serith < 46 > [d2=2][d6=4,1]
The shuriken flies swift and two, going low as it cuts straight through Kaja's left leg. It falls away as he tumbles to the ground, a yelp of pain as...
Init is Moore (53) > Kaja (52) > Cresiel (48) > Distorted Woman (42) > Worm = Human = Pit Fiend = Efreet (17) > Jetina = Xandra (16)
Chance to react, since emergency healing is an interrupt that matters, it's for that too.
Cresiel
Xandra
Kaja
HP: 354 (161)/515 (fast healing 11), muted, minus left leg.
Jetina
In total:
Attack: +31
Weapon damage: +22
Fast Healing 11
[/quote]
Yes, Jetina will use an Emergency Healing here for Mass Heal again for 275.
#486
Sorry, having some connections here at work, not sure if this is going through or not.
[blockquote]Rolled 1d20+33 : 20 + 33, total 53[/blockquote]
test test
EDIT: ok, seems like we're good now, not sure what happened there. I can reroll if you need me to.
Yeah, just reroll. I'm not sure what happened or what you were editing for, but since I don't wanna figure it out due to time issues, just make a reroll real quick.
[blockquote]Rolled 1d20+33 : 9 + 33, total 42[/blockquote] Yeah, on my end I couldn't see anything in the actual post, it was weird. All good now, it seems.
The spell erupts out, a torrent of magic healing the party. Kaja's face is still a ruined, if a healed ruin, and he's down a leg, but he's not bleeding any more. Meanwhile, the worm's body only slowly regrows, poking out minorly as the human scowls at this all, bringing his hands together, "Oh great Lord of the Fourth, bestow on them pain and suffering!"
Will saves, all. Immunity to pain-effects negates.
Cresiel
HP: 700/700 (fast healing 11, regeneration 17)
Xandra
HP: 521/521 (fast healing 11)
Kaja
HP: 515/515 (fast healing 11), muted, minus left leg.
Jetina
HP: 478/478 (fast healing 11)
In total:
Attack: +31
Weapon damage: +22
Fast Healing 11
[/quote]
I had to check if Jetina's spell covered that (it does not)
[blockquote]Rolled 1d20+62 : 8 + 62, total 70[/blockquote] Moore, mettle
[blockquote]Rolled 1d20+50 : 7 + 50, total 57[/blockquote] Xandra
[blockquote]Rolled 1d20+54 : 10 + 54, total 64[/blockquote]Jetina, mettle
> roll 1d20+49 Cresiel
<Rei-chan> Kotono rolled : 1d20+49 Cresiel --> [ 1d20=16 ]{65}
> roll 1d20+29
<Rei-chan> Kotono rolled : 1d20+29 --> [ 1d20=9 ]{38}
You endure.  Xandra prays a moment, golden light shielding her. Jetina merely doesn't stop, ignoring it. Yet even as Cresiel goes on, Kaja shudder and shakes on the ground. He screams in agony, convulsing.
Kaja is unable to act due to overwhelming pain. He is currently treated as helpless.
Amid all this, the pit fiend lunges forward, want out at Cresiel. The wand begins to burst with green flames as...
Ref.
> roll 1d20+54 evasion
<Rei-chan> Kotono rolled : 1d20+54 evasion --> [ 1d20=5 ]{59}
Yet Cresiel's shield comes up, flames held at bay as the two glare, face to face. Then the fiend spits out, sizzling red saliva going right for Cresiel's eyes.
Touch AC so just a 1/20 check.
> roll 1d20 this is a 1/20 check
<Rei-chan> Kotono rolled : 1d20 this is a 1/20 check --> [ 1d20=8 ]{8}
Fort.
<Rei-chan> Kotono rolled : 1d20+49 Cresiel --> [ 1d20=4 ]{53}
> roll 10d8 vile damage
<Rei-chan> Kotono rolled : 10d8 vile damage --> [ 10d8=48 ]{48}
> roll 1d4+2 Charisma damage
<Rei-chan> Kotono rolled : 1d4+2 Charisma damage --> [ 1d4=2 ]{4}
The Charisma damage is also vile. Both are halved, so 24 damage and 2 points of vile Charisma damage.
The spit glows and melts into Cresiel's face, twisting it, making it droop in places, flesh crumbling away like too soft snow in the sunshine. As this happens, "Bastards," The efreet gasps, his dangling hand feebly touching his side - and his wounds heal an instant, gone.
"You only delay the inevitable!" Cresiel snaps, as...
Xandra and Jetina.
Cresiel
HP: 700 (24 vile)/700 (fast healing 11, regeneration 17) 2 vile Charisma damage
Xandra
Kaja
HP: 515/515 (fast healing 11), muted, minus left leg, unable to act due to pain.
Jetina
In total:
Attack: +31
Weapon damage: +22
Fast Healing 11
[/quote]
[/quote]
Jetina's going to move over to tag Kaja with a Sublime Revelry, which I would think would get rid of his pain -- can you verify before I commit to that?
Also, the efreet's hand is currently not held up, yes?
I'm a derp, sublime revelry doesn't need her to move, it's got a range on it anyway.
