A Faraway Victory
Started by Anastasia, July 24, 2018, 04:18:50 PM
I think this calls for initiative.
[18:50] <@Ebiris> roll 1d20+21 Alicia init
[18:50] <Rei-chan> Ebiris rolled : 1d20+21 Alicia init --> [ 1d20=14 ]{35}
[18:50] <@Ebiris> roll 1d20+22 Marie init
[18:50] <Rei-chan> Ebiris rolled : 1d20+22 Marie init --> [ 1d20=9 ]{31}
Nerveskitter for both. (Alicia is casting and share-spelling it with Marie)
Alicia: 1140+20/1140
Active spells: Extended nondetection (CL 32), many moments of prescience (CL 32), extended greater anticipate teleportation (CL 32), sensual blessing (CL 31), epic mage armour (CL 31), righteous wrath of the faithful (CL 31), recitation (CL 31), death ward (CL 32), dance of the unicorn (CL 32), spell turning (CL 32), greater visage of the deity (CL 31), foresight (CL 31), vision of the omniscient eye (CL 31), extended repelling shield (CL 32), extended ray deflection (CL 32), divine protection (CL 31), energy immunity (electricity) (CL 31)
Defences: AC 93 (touch 28), CMD 108, spell resistance 46, energy immunity (fire, cold, electricity), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting), freedom of movement, nondetection (DC 47)
Stat buffs/penalties: +25 competence perception, +12 armour, +3 morale damage, +3 luck attack/saves, +34 Str, -2 Dex, +20 Con, +2 Int, +4 Wis, +4 Cha, +1 natural armour, -7 size, +2 insight AC/reflex, +10 insight perception, +9 shield AC, +4 morale attack/saves/skills, +1 morale AC
Perceptions: Darkvision, scent, low-light vision, blindsight, tremorsense 1 mile, true seeing, perception +84
Sorcerer spell slots: 6/7/9/9/8/9/7/8/8/7/7/6/5/4
Duskblade spell slots: 6/12/12/10/10/6
Marie: 912+20/912
Active spells: Extended superior resistance (CL 31), extended mind blank (CL 31), greater arcane sight (CL 31), righteous wrath of the faithful (CL 31), recitation (CL 31), death ward (CL 31), extended repelling shield (CL 31), bibliotheca arcana (CL 31), sensual blessing (CL 31), extended ray deflection (CL 31), extended nondetection (CL 31), divine protection (CL 31), power of the huntress (CL 31)
Defences: AC 99 (touch 22), CMD 70, spell resistance 43, energy immunity (electricity, negative energy), energy resistance 10 (acid, cold), status immunity (protection, death effects, energy drain) protective aura, ray deflection, nondetection (DC 46), improved evasion
Stat buffs/penalties: +4 deflection AC vs evil, +3 morale damage, +11 shield AC, +15 insight knowledge, +25 competence perception, +3 luck attack/saves, +4 morale attack/saves/skills, +16 natural armour, +1 morale AC, +10 enhancement strength/constitution, +4 enhancement dexterity, +3 enhancement natural armour, +20 competence stealth, +6 initiative
Perceptions: Darkvision 60, blessed sight 120, see invisibility, greater arcane sight, scent, low-light vision, blindsight 60, tremorsense 60, perception +70
Sorcerer spell slots: 6/5/8/8/6/8/6/6/6/7/6/2/3
You are 100% correct.
> roll 1d20+11 Antenora
<Rei-chan> Kotono rolled : 1d20+11 Antenora --> [ 1d20=8 ]{19}
> roll 1d20+10 Syala
<Rei-chan> Kotono rolled : 1d20+10 Syala --> [ 1d20=13 ]{23}
> roll 1d20+5 minions
<Rei-chan> Kotono rolled : 1d20+5 minions --> [ 1d20=12 ]{17}
> roll 1d20 Statue?
<Rei-chan> Kotono rolled : 1d20 Statue? --> [ 1d20=4 ]{4}
Init is Alicia (35) > Marie (31) > Syala (23) > Antenora (19) > Minions (17) > Statue? (4)
Go.
Time to see if their enhanced senses render them more vulnerable to sensory attacks, as a gesture from Alicia goes out while she flies forward, a burst of kaleidoscopic light enveloping the cultists and their toy!
Maximised radiant assault
[19:05] <@Ebiris> roll 1d20+32 maximised radiant assault SR
[19:05] <Rei-chan> Ebiris rolled : 1d20+32 maximised radiant assault SR --> [ 1d20=3 ]{35}
90 damage, DC 32 will halves. 6 rounds dazed (only dazzled if save succeeds)
Sorcerer spell slots: 6/7/9/9/8/9/7/8/7/7/7/6/5/4
Marie: 912+20/912
> roll 1d20+6 (-10 ???)
<Rei-chan> Kotono rolled : 1d20+6 (-10 ???) --> [ 1d20=12 ]{18}
The blast hits them hard, cultists falling and others screaming, rocking back and forth ont he ground. The statue stops moving as ...
Marie.
Marie just runs forward in a mad dash! No one really needs her to be casting any spells right now and she can make it easier for those speedy goddesses to move around without having to slow for her.
Run action for 160 feet. That brings her into range to use greater arcane sight on the statue and see what's up with it.
It's a construct waiting to be activated. It's gonna wake up and do construct things, like attacking and breading supernatural  blasts of acid over all of you.
"Don't wreck the statue please!" Marie calls back to the divine trio. "I can use it!"
Syala merely snaps her fingers, as lightning strikes from the blue, immolating the cultists.
Using alter reality to mimic chain lightning.
> roll1 d20+31 SR
<Rei-chan> Kotono rolled : d20+31 SR --> [ 1d20=8 ]{39}
> roll 20d6
<Rei-chan> Kotono rolled : 20d6 --> [ 20d6=71 ]{71}
Reflex saves irrelevant here.
Cries as the already grievously wounded cultists are slaughtered with lightning, leaving behind corpses and little else. You won!
Free act, statue's not doing anything immediately.
As Alicia and the others catch up, Marie tries to take control of the golem for herself!
She has Use Magic Device!
[19:50] <@Ebiris> roll 1d20+50 use magic device
[19:50] <Rei-chan> Ebiris rolled : 1d20+50 use magic device --> [ 1d20=8 ]{58}
You feel that the construct is meant to be awakened and controlled. Another presence is there, stirring it, warring against you.
Opposed Charisma check.
[19:58] <@Ebiris> roll 1d20+12 charisma
[19:58] <Rei-chan> Ebiris rolled : 1d20+12 charisma --> [ 1d20=1 ]{13}
> roll 1d20+12 could tie?!
<Rei-chan> Kotono rolled : 1d20+12 could tie?! --> [ 1d20=1 ]{13}
You both suck. Reroll, it's a true tie.
[20:08] <@Ebiris> roll 1d20+12 should've used that good hope spell Seira always drops
[20:08] <Rei-chan> Ebiris rolled : 1d20+12 should've used that good hope spell Seira always drops --> [ 1d20=11 ]{23}
<Rei-chan> Kotono rolled : 1d20+12 could tie?! --> [ 1d20=6 ]{18}
Marie's will is stronger, forcing out the other will. You feel the construct, ready to obey your commands at will.
Do you want to control it or have it be DM controlled based on commands?
Golems are pretty dumb so just have it DM controlled based on Marie's verbal orders.
"Got it! Thanks for the golem Jade!" Marie crows before she points back through the open gate the cultists just dragged the dragon-statue through. "Go that way!" she commands, following after it.
"Good job Marie," Alicia praises as she advances, taking the lead once more.
