The depths of Ice
Started by Anastasia, August 20, 2018, 01:33:26 PM
You'd need to get someone to remove the rubble to really get a look - too much of it is covered.
Tryll uses the endless power of telekinesis to clear away the debris!
The rubble is so moved, a rather intricate shape inside. All wavy lines and delicate curves, suggesting that...
K:A or K:P, whichever.
[blockquote]Rolled 1d20+50 : 4 + 50, total 54[/blockquote]
It's a portal, unactivated and woven into the magic of this place. The only problem is that it's keyed to individuals of a distinct bloodline, it will only work for them unless you can fool it somehow.
UMD checks!
Tryll
[blockquote]Rolled 1d20+49 : 11 + 49, total 60[/blockquote]Calleigh[blockquote]Rolled 1d20+40 : 9 + 40, total 49[/blockquote]
In case of unintended activation, Calleigh pulls out a wand of Silence!
Got it! You're pretty sure it's activated now and should work. In theory.
Meanwhile Dana watches and Debonah says, "A portal? Is it bait or is it a real opportunity?"
'It appears to be designed to only function for persons related to a specific bloodline. It's unlikely anyone would expect us to be able to use it. Unless they're watching us right now. Actually.' Mind Blank is manifested! 'Right. So long as nobody is directly observing our progress, we should be able to get somewhere marginally useful.'
Benyen nods quickly, "Better than being here, at least."
"Much better," Debonah agrees, "Before Tryll exhausts himself by sending himself flying all over."
'The only part of me that's exhausted is my dignity.'
"Then let's go," Dana agrees, "Let's fuckin' do this!"
Thus does Tryll activate the glyph once everybody is ready and clearly going to be affected by said teleportation all at once.
