Dark Rumblings
"Not here, but perhaps deeper within," Alicia says as she takes a moment to re-consecrate this room before she tries opening the door nearby to the West.
On consecrating the room, the altar repairs. Atop it is a glowing, metallic holy symbol of Mystra. It fills the room with radiance, the sacs burning away in blue spellfire.
Well done, Alicia. The wound is above you. There should be stairs to the north and to the west - you are not far from the western ones.
Thank you, Mystra.
With that Alicia tries the West door to see if it has stairs in it.
Probably vermin to exterminate too.
Marie: 515+20/515
Sorcerer spell slots: 6/6/10/8/7/7/6/6/7/7/6/4/2
Avatarlicia: 706+60/706
Sorcerer spell slots: 6/13/12/10/9/9/11/8/7/3/7/6/6/4
Duskblade spell slots: 6/17/17/16/9/4
Vermin die as a matter of course. It is an east/west hallway, filled with the corpses of vermin. Nothing too remarkable here, it has the feel of a working corridor rather than anything else.
https://imgur.com/a/CL1LF2B
Consecration happens then Alicia tries opening the door to the south midway down the corridor.
Vermin die, of course.
Ahead is a stairwell with stairs going up.
You can hear a vast rustling of wings and chittering of insects above.
Marie will probably get to unleash her barrage again soon! Undaunted, Alicia consecrates before leading the way upstairs.
As you climb up? Guh! You see it - a vast tidal wave of insects and vermin, coming down at you like a waterfall. They're moving in perfect tandem - a swarm. As you see this, closing in on you with seeming inevitability...
Init. Feel free to make K:N here, too.
Supreme init for Alicia
[19:23] <@Ebiris> roll 1d20+11+5 Marie, nerveskitter
[19:23] <Kobot> Ebiris rolled 1d20+11+5 Marie, nerveskitter --> [ 1d20=13 ]{29}
[19:23] <@Ebiris> roll 1d20+50+15 Marie nature
[19:23] <Kobot> Ebiris rolled 1d20+50+15 Marie nature --> [ 1d20=16 ]{81}
[19:23] <@Ebiris> roll 1d20+49 Alicia nature
[19:23] <Kobot> Ebiris rolled 1d20+49 Alicia nature --> [ 1d20=17 ]{66}
Marie: 515+20/515
Sorcerer spell slots: 6/5/10/8/7/7/6/6/7/7/6/4/2
> roll 1d20+8 Ebony
<Kobot> Kotono rolled 1d20+8 Ebony --> [ 1d20=1 ]{9}
> roll 1d20+8 swarm
<Kobot> Kotono rolled 1d20+8 swarm --> [ 1d20=12 ]{20}
Init is Alicia (7777) > Marie (29) > Swarm (20) > Ebony (9)
Both of you identify this as a ruin swarm. It's much stronger than a normal swarm, able to restore its losses and heal fast, as well as with other powers. You can sense the power of entropy behind this one - don't get chewed up and stung by it.
"Don't hold back on this one," Alicia cautions, taking a step back and raising her hand as a pair of radiant lances of sunlight erupt forth to detonate amidst the swarm!
Maximised sunlance and quickened sunlance.
[19:44] <@Ebiris> roll 1d20+31 maximised sunlance SR
[19:45] <Kobot> Ebiris rolled 1d20+31 maximised sunlance SR --> [ 1d20=7 ]{38}
[19:45] <@Ebiris> roll 1d20+31 quickened sunlance SR
[19:45] <Kobot> Ebiris rolled 1d20+31 quickened sunlance SR --> [ 1d20=1 ]{32}
Fortunately tinks off our own SR given the huge radius.
[19:45] <@Ebiris> roll 30d6
[19:45] <Kobot> Ebiris rolled 30d6 --> [ 30d6=117 ]{117}
[19:45] <@Ebiris> roll 6d6
[19:45] <Kobot> Ebiris rolled 6d6 --> [ 6d6=20 ]{20}
Maximised does 180 damage on impact and 36 damage in 180 foot radius, quickend does 117 on impact and 20 in 180 foot radius.
No save vs the impact damage, DC 34 ref half on the radius damage. Blinded if save fails.
Marie: 515+20/515
Sorcerer spell slots: 6/13/12/10/9/9/11/8/7/3/7/6/5/3
> roll 1d20+23 vs 1
<Kobot> Kotono rolled 1d20+23 vs 1 --> [ 1d20=1 ]{24}
> roll 1d20+23 vs 2
<Kobot> Kotono rolled 1d20+23 vs 2 --> [ 1d20=4 ]{27}
The glow of the sun illuminates the stairwell, insects consumed by the radiance. When you can see clearly again, not an nisect is left from your assault, the swarm wiped out in a single, overwhelming alpha attack.
Well, blowing 12th+ level spell slots is one way to solve that problem after winning init. Free act.
Marie exhales as she loosens the tension in her poise as she'd been preparing to unleash her own magical fury. "Feeling a bit superfluous, huh?" she commiserates with Ebony.
"I may have overestimated the trouble this would be," Alicia admits, leading the way up the sun-bleached stairs.
"Not at all. I am honored to be here," Ebony pulls her hood back down, "Perhaps you have grown inured to that, being her familiar for so long."
"Familiarity breeds contempt, hmm?" Alicia hums, the edge of a chuckle on her breath.
"I don't hold you in contempt, Alicia!" Marie's quick to insist, bunching up her fists at her side as she hurries along after the raven-haired goddess.
