Dark Rumblings
Do either of you have spell stowaway for timestop? She's mulling her options.
Ebony
HP: 570+20/570
Bonuses: Attack+7 (+4 morale, +3 luck), Damage+0 AC+15 (+15 armor), Saves+7 (+4 morale, +3 luck), Skills+4 (+4 morale), Checks+0
Resources: Channel Energy 13/13 Dispel Evil 3/3 (week) Holy Aura 1/1 Bardic Music 30/30
Spells Used: 1 11th level sorc, 1 12th level sorc
SLAs Used:
Spells Active: Greater Heroism (CL31), Death Ward (CL31), Recitation (CL31), Mass Energy Immunity (Cold) (CL31), Epic Mage Armor (CL31)
Notes: Include doubler for WoC on bardic music.
Marie does, Alicia doesn't.
She doesn't have much she can do offensively in a time stop though. Other than drop more maws of chaos.
Not necessarily a bad thing, mind you.
> roll 1d4+1
<Kobot> Kotono rolled 1d4+1 --> [ 1d4=2 ]{3}
In an instant, time seems to stop. Ebony gestures towards the frozen swarm of bugs, "If you would, Marielle?"
"I don't have delayed blast fireballs but I think this is better anyway!" Marie says brightly as she proceeds to cast again and again, more maws of chaos erupting inside the room frozen at the moment of birth... and then running wild in devouring everything once time resumes.
3 maws of chaos cast during the time stop.
[21:01] <@Ebiris> roll 3#31d6 maw of chaos x3
[21:01] <Kobot> Ebiris rolled 3#31d6 maw of chaos x3 --> [ 31d6=95 ]{95}, [ 31d6=90 ]{90}, [ 31d6=124 ]{124}
Marie: 515+20/515
Sorcerer spell slots: 6/4/10/8/7/7/6/6/7/4/5/4/2
Avatarlicia: 706+60/706
Sorcerer spell slots: 6/13/12/10/9/9/11/8/7/1/7/6/5/3
Duskblade spell slots: 6/17/17/16/9/4
"Please," Ebony agrees, merely holding her position.
When time resumes, the maws tear apart more insects. The barrage of them is enough to clear a path to within an empty, large communal bathing space. It was once perhaps elegant, but is overrun now. In the center reality seems to shudder, weep, tear.
"There," Ebony says, "Let us end this."
Alicia.
Ebony
HP: 570+20/570
SLAs Used:
[/quote]
Ahh, she was right after all, it was the bathroom!
"Good, lets," she seconds Ebony, gesturing out and uttering an arcane word before space ripples once before solidifying over the area, blocking out the dimensional intrusion.
It's still hidden under all those all-consuming maws of chaos of course.
Dimensional Lock cast.
Marie: 515+20/515
Sorcerer spell slots: 6/13/12/10/9/9/11/8/6/1/7/6/5/3
There is a soft groan as the wound begins to partially heal, partially mend - but the vermin are still coming, still being consumed.
K:P check.
[21:22] <@Ebiris> roll 1d20+46 planes Alicia
[21:22] <Kobot> Ebiris rolled 1d20+46 planes Alicia --> [ 1d20=15 ]{61}
[21:22] <@Ebiris> roll 1d20+50+15 planes Marie
[21:22] <Kobot> Ebiris rolled 1d20+50+15 planes Marie --> [ 1d20=7 ]{72}
The weakened boundaries are mended, but a dispel evil lis needed to cease the tide of vermin.
You also note that the rate of insect gathering seems to have been augmented, the spiritual wounds summoning insects far and wide as much as other outsiders.
Alicia certainly isn't walking into that chaotic maelstrom!
"Marie, I need you to be my familiar again for a moment," she says, making that happen and then giving her a dispel evil to hold the charge on. "Discharge it at the centre of the rift, please."
"Can do!" Marie chirps, walking ahead through the maws of chaos without being touched before she discharges the dispel evil into the rift.
Chaotic subtype makes her immune to Maw of Chaos.
Caster level check, Marie.
[21:41] <@Ebiris> roll 1d20+32 uses Alicia's CL since it's her spell
[21:41] <Kobot> Ebiris rolled 1d20+32 uses Alicia's CL since it's her spell --> [ 1d20=1 ]{33}
Slowly the wound heals before your eyes. The vermin scurry away, the survivors thinning out as the rift in the Prime is healed. You did it!
Free act.
As Marie begins to dismiss her maws of chaos, Alicia consecrates the area.
"We still need to find someone who can give us an idea where Allema's gone. Lets secure the rest of the cathedral."
Hopefully it wasn't just the swarm, the nycaloth, and that one thing she silver fired to death.
"Let us," Ebony agrees, "Shall we begin with checking everything in this room?"
Now that all the insects and worse are dead ore retreating, you can see several doors in the back of this room.
https://imgur.com/Hs1YeWx
