Survivors
Started by Anastasia, December 03, 2018, 12:35:37 PM
Moore takes in a breath and flies over, attempting to put his rapier against Abdel's neck.
"This is your last chance to surrender, before our weapons pierce you instead of your disgusting creations, and you come back with us alive and with holes in you." Moore says.
I'm not sure what sort of roll this calls for with regards to attack here.
Give me an Intimidate check.
The efreet stares up at you, your tiny rapier at his throat. His eyes travel to Cresiel nearby as well and gives you a look like poison, "I yield," he grinds out.
"Great." Moore says. "Now tell me how to deactivate all your golems. I'm sure there's a command word you instilled in all of them."
No reply, then Cresiel simply hefts his hammer, staring down at him.
With a breath, "Sissazz." Abdel looks up, not even hiding his glare.
Moore turns and shouts. "Sissazz!"
He then turns to look and see if the spider golem stops trying to get past the wall of force!
The spider golem comes to a stop, no longer fighting against it.
Free act.
"I appreciate your understanding. Now, I'm going to put you to sleep. I suggest you don't resist." He warns him. "Also, if there's a third one of you running around, I'm going to be very angry."
Limited Wish for higher-level Sleep, yadda yadda.
[21:24] <Nephrite> roll 1d100 spell failure
[21:24] <Penuche> Nephrite invokes Penuche's magic: < 3 > [d100=3]
[21:24] <Penuche> Nephrite invokes Penuche's magic: < 84 > [d100=84]
Perhaps out of fear or simply knowing he is defeated, Abdel does not resist, falling aslumber.
Jetina lowers her blade, "A good day's work. Are we going to linger?"
Cresiel frowns, "We should have asked him how to stop that damnable rain or disable the teleportation defenses."
"It's fine, we'll just deal with it." Moore says. "But yes, I do intend to take everything here for re-distribution to Celestia. I especially want to free the souls of the slaves who are stuck in these golems. For right now, we'll retrieve the other Abdel and give them to Celestia. After that, I have a quick rendezvous I've been asked to attent to by Lady Seira about something. While I'm doing that, I'd like the three of you to come back here and investigate it, I'll join up with you all after that."
So plan is to grab them, go back, drop off and come back later?
Grab them, go back, drop off and come back now, if that makes sense. Moore will be joining them later, though yes.
Okay, assuming getting out goes without difficulty, how are you planning on getting past the rains?
I admittedly just figured Gate would work to get us out, since we haven't actually tried it. If it doesn't, then Moore will use his Lyre of Building to just build a pathway from the house all the way back to the cave that they can use to get through, at least to get out. Getting back may be a challenge if the building doesn't stay up but we can worry about that later.
