Io's Labyrinth
Started by Anastasia, December 12, 2018, 12:57:47 PM
this may not work on the board. It should be 77d4 of it doesn't come through. [blockquote]Rolled 20d4 : 4, 1, 2, 3, 2, 2, 1, 1, 3, 1, 2, 1, 4, 1, 1, 1, 3, 2, 2, 4, total 41[/blockquote]
Yeah, just roll it out fresh when you get on IRC.
Seira decides to clean up with efficiency, three bright stars forming around her before the bolts of glory find their target!
19:41 <CC> roll 3#1d20+35 SR
19:41 <Penuche> CC invokes Penuche's magic: < 51, 48, 38 >
19:42 <CC> roll 3#1d20+49+22 ranged touch
19:43 <Penuche> CC invokes Penuche's magic: < 88, 87, 88 >
19:43 <CC> roll 3#15d12 positive energy
19:43 <Penuche> CC invokes Penuche's magic: < 110, 102, 100 >
Give me a rank check, Seira.
19:46 <CC> roll 1d20+6
19:46 <Penuche> CC invokes Penuche's magic: < 17 > [d20=11]
> roll 1d20
<Penuche> Kotono invokes Penuche's magic: < 20 > [d20=20]
Power clashes as the dragon howls and screams, the shadows fading away. Yet it doesn't die, you feel it retreat - to Io's overwhelming presence, a gasp as it is utterly consumed, annihilated in a moment.
"Well done." Io's voice is heard. "I shall provide, as he is no longer able to. I believe this lesson stands self evident, for Shar's power draws, allures, tempts and overtakes."
Before the party they appear - three scrolls and a purple key.
Free act.
Seira examines the scrolls and the offered key!
Alicia recasts many moments of prescience as soon as she has a chance. "A good thing we ended it here before it could blight Creation any," she agrees while Seira checks over the scrolls and key.
Alicia: 696/696
Active spells: Extended nondetection (CL 33, 65hrs), extended repelling shield (CL 33, 54m), keen edge (CL 32, 308m), sensual blessing (CL 32, 20m), vision of the omniscient eye (CL 32, 20m), greater heroism (CL 32, 20m), death ward (CL 32, 20m), extended ray deflection (CL 33, 54m), divine insight (CL 32, 32hrs), foresight (CL 32, 317m), dance of the unicorn (CL 32, 29m), recitation (CL 32, 3m), greater visage of the deity (CL 32, 3m), ghost touch weapon (CL 32, 29m), many moments of prescience (CL 32, 32 hrs)
Defences: AC 79 (touch 40), CMD 109 spell resistance 47, status immunity (dazzled, blinding, polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), energy immunity (fire, cold, negative energy), energy resist 10 (acid), nondetection (DC 48), ray deflection
Stat buffs/penalties: +9 shield AC, 17-20 crit range, +25 competence perception, +10 insight perception, +4 morale skills/saves, +2 insight AC/reflex, +3 luck attack/saves, +1 natural armour, +4 str, +2 dex, +4 con, +2 int, +4 wis, +4 cha, +18 morale attack/damage
Perceptions: Darkvision 2 miles, scent, low-light vision, tremorsense/blindsight 2 miles, arcane sight, perception +88
Sorcerer spell slots: 6/16/16/13/6/9/14/6/6/7/7/2/6/2
Duskblade spell slots: 6/22/21/20/7/7
Quick-casts left: 2
Loot update. Spells pasted here.
Iosodaelanaja's Endless Sight
Divination
Level: Clr 12, Rgr 10, Sor/Wiz 12
Components: V, S, M
Range: Touch
Target: Creature touched
Duration: 10 min/level
Spell Resistance: No
Your vision extends up to 100ft per caster level, able to see anything within that range with perfect clarity, granting you a +20 competence bonus to Spot checks. This vision is sufficient to see it anything within the range of your vision as if you were before it and studying it closely. You gain the ability to see in any mundane darkness and any magical darkness of 9th level or lower, as well as through magical and non magical fog, mist, smoke and similar obstructions. You cannot be blinded and you can see through intense light that would normally be blinding without harm or penalty, be it magical or non magical.
This spell does not bestow x-ray vision or similar abilities. Solid objects still stop your vision as normal.
Material Component
A crystal prism worth 100 gold.
Danatha's Improvisation
Transmutation
Level: Brd 7
Duration: 1 min/level
This spell is identical to improvisation, except as noted here. You can use your pool of luck to improve saving throws or weapon damage rolls in addition to attack rolls, skill checks and ability checks.
Sorrow's Touch
Transmutation
Level: Corrupt 14
Components: V, S, Corrupt
Range: Touch
The target's touch, including unarmed attacks and natural weapons, slowly wears away everything the touched creature is. This inflicts 2 points of vile ability damage to all six ability scores per touch.
Creatures who suffer vile ability damage from sorrow's touch and who are not fully healed of it within 1 minute must make a Fortitude save or slip into a black depression. Such creatures are listless, unwilling to do anything except lament their failings and miseries. The only cure is to heal the vile ability damage caused by sorrow's touch. Creatures affected by this ability will cease to see to basic personal needs such as grooming, hygiene, eating and drinking. In all aspects, the creature will sit and wait to die, mired in sorrow.
Corruption Cost
1d6 points of ability damage to all six ability scores.
"Yeah I'm burning this one," Seira says, putting the first two scrolls away. "What were you thinking? Seriously."
A burst of divine will purifies the vile scroll.
"Know your enemy so that you can crush them better?" Oberuth suggests.
Meanwhile Antenora turns to Moore, checking him over.
Jetina lowers her blade, "What are the other two scrolls and why is one so objectionable?"
Aiming to destroy or purify the scroll? To be clear.
Alicia trusts Seira's judgement on that, having often found worthless unholy magic in their past adventures. "I'm surprised the key isn't magic. A mundane lock isn't going to stop us here unless we feel like being especially sporting. Which way would people like to go next? Explore more in this area, or try another direction back from where we started?"
I was honestly being fancy about burning it, but if my divine powers of purification can work on scrolls like that I'd like to try it!
"I'll be sure to make copies for all participants," Seira promises to Jetina, "plus any special insights I might have. The other scrolls are actually pretty great, but this one tainted any user without fail."
"What about the door Madigar sat before?" Amaryl asks, "We could explore that?"
Antenora shakes her head, "I say we go north, down to the sapphire blue halls."
"That sounds good, or the metallic silver hall? WE've met a despair dragon and a chromatic dragon. Maybe that leads to a metallic dragon?" Jetina ventures, returning back to the party. "Ah. Corrupt magic, then."
In theory it might be possible, but conceptual spells like this don't convert easily, so we'll just burn it. It's not the sort of spell that you flip and makes a good counter spell, really, and I don't want to slow us down having to redesign an analogue to it from scratch.
"Just give me a moment here," Seira says, precasting a couple spells and taking a closer look at the cavern they're in. Her senses are already better than what Iosodaelanaja's spell could help with, and she looks for any hidden doors or locks for the purple key!
Perception take 10 for 105, and I'm emulating a spell that's to Detect Secret Doors as Greater Arcane Sight is to Detect Magic so we don't waste  a lot of time on this.
