Io's Labyrinth
Started by Anastasia, December 12, 2018, 12:57:47 PM
The crit landed. Is Alicia immune to electricity?
She is not! So if she takes damage on every hit she landed here she's also getting +60 (+120 on crits) temp hp too so track which damage she takes on normals and which on crits so I can keep it all straight.
Alicia: 952+120/952
Active spells: Extended nondetection (CL 33, 65hrs), extended repelling shield (CL 33, 50m), keen edge (CL 32, 304m), sensual blessing (CL 32, 16m), vision of the omniscient eye (CL 32, 16m), greater heroism (CL 32, 16m), death ward (CL 32, 16m), extended ray deflection (CL 33, 50m), divine insight (CL 32, 32hrs), foresight (CL 32, 313m), dance of the unicorn (CL 32, 25m), recitation (CL 32, 3m), greater visage of the deity (CL 32, 3m), ghost touch weapon (CL 32, 27m), many moments of prescience (CL 32, 32 hrs)
Defences: AC 83 (touch 30), CMD 132 spell resistance 47, status immunity (dazzled, blinding, polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), energy immunity (fire, cold, negative energy), energy resist 10 (acid), nondetection (DC 48), ray deflection
Stat buffs/penalties: +9 shield AC, 17-20 crit range, +25 competence perception, +10 insight perception, +4 morale skills/saves, +2 insight AC/reflex, +3 luck attack/saves, +15 natural armour, +40 str, -2, dex, +20 con, +2 int, +4 wis, +4 cha, -8 size, +18 morale attack/damage
Perceptions: Darkvision 2 miles, scent, low-light vision, tremorsense/blindsight 2 miles, arcane sight, perception +88
Sorcerer spell slots: 6/15/16/13/6/9/14/6/6/7/6/2/6/2
Duskblade spell slots: 6/22/21/20/6/7
Quick-casts left: 2
Alicia's first strike is dreadfully powerful - cutting deep into the dragon's side. Yet the wyrm grins savagely as it becomes pure electricity, running up Alicia's blade and into her.
Fort.
[18:40] <@Ebiris> roll 1d20+77 mettle and I can't fail on a 1, to streamline any requests for more rolls since that's a lot of attacks
[18:40] <Penuche> Ebiris invokes Penuche's magic: < 93 > [d20=16]
Electricity writhes about Alicia but she endures, unharmed even as it crackles around her, no sign of the dragon, just lightning dancing over Alicia's armored form.
Interrupts your full attack. Anything else this round, Alicia?
I have a swift left but first can I tell where the dragon went with any of my godly perceptions?
[19:00] <@Ebiris> roll 1d20+88 perception
[19:00] <Penuche> Ebiris invokes Penuche's magic: < 107 > [d20=19]
Also if one of the dragon's spells is 'When hit you turn into lightning and get really messed up if X happens' that'd be more useful to know than just a flowery name.
You can tell the dragon transformed into living lightning and is currently trying to fry your body.
Fortunately, you're good at enduring that.
Lightning's Rise seems to be the culprit.
Does the spell description say anything about what living lightning is vulnerable to? If a certain damage type or specific spell will knock the caster out of the state/hurt them?
This isn't the final draft, I probably want to tighten some language, but the basics are all here.
Lightning's Rise
Transmutation
Level: Sor/Wiz 14
Components: V, S, F
Range: Personal
Target: You
Duration: 1 min/level
Spell Resistance: No
This mighty spell allows you to transform your body to living lightning on injury. Whenever you take damage, you may choose to transform as an immediate action. If you do, you become a mass of electricity invulnerable to most forms of harm. You are immune to all damage in this form except as follows. You take normal damage from force attacks such as magic missile and are vulnerable to any attack that deals damage with water, taking double damage from them and suffering a -10 penalty to any saving throws. This form lasts until the beginning of your next turn. In this form you cannot make attacks of opportunity or cast spells, nor can you move. Once you return to your normal form, this spell ends.
If you were damaged by a creature who came in contact with you with their body or a metal object, or if a creature or a creature touching you with a metal object comes in contact with you, you can attempt to flow into them. This deals 50d10 points of electricity damage. Additionally, you can choose to remain as electricity damaging them, dealing the damage each round at the beginning of your turn, so long as you are with them. In this case, this form lasts for one round per three caster levels, until the spell expires normally or until the creature you are within dies. At that point, you appear in your normal form adjacent to the creature or the creature's corpse. While you are within a creature, you can take no other actions than to deal it damage, which happens automatically.
Once within a body, you can only be removed with a dispel magic or similar spell targeted at the creature you are within. This spell may be targeted that way and if successfully dispelled, you take 1d6 points of damage per caster level of the spell used and appear adjacent to the creature in your normal form, the spell ended.
So for my clarification, now that the dragon's chosen to attack me he can't be targeted if anyone else wanted to magic missile him, only dispels will work?
Unless you could somehow introduce force or water throughout your body or something similar. I'd rule that could harm him, and fiat something that doesn't normally deal damage as appropriate.
"Someone will have to dispel him out of me now, I'm unharmed but he can't be easily hurt in this form either," Alicia says as she looms above everyone.
Okay, I'm done.
"Nice trick," Amaryl marvels, "Can we remove him?"
Antenora shakes her head, "Effective on almost anyone else."
Jetina hurries over, "Do you need healing, Alicia?"
Amaryl's up, waiting on a reply there since she can't just arrow Alicia.
"I can do it, give me a moment. That lightning spell, right?"
"No, this isn't enough to hurt me," she tells Jetina. "Rain of desolation would be extremely good, but it would break my own spells as well unfortunately - he's weak to water and force effects as well but my body also provides him a shield."
Alicia: 952+60/952
Quick-casts left: 2
