Forward
Started by Anastasia, December 27, 2018, 08:15:18 AM
Abruptly, the pull of the gem begins to go downward and to the right, starting to drift in that direction more and more.
Corrrespond.
'Haha! They are LEAVING! I am following!' Tryll says, picking up the pace and making a direct line toward the source.
'Careful,' Miranda says sharply, 'It could be a trap or luring you into a battle on their terms.'
Tryll will be mindful of traps, physical or magical or otherwise!
Perception![blockquote]Rolled 1d20+48 : 15 + 48, total 63[/blockquote]
It's moving more and more away and to the side, faster as you pursue.
Movement speed?
120ft to start, can move faster up to 240 if need be.
You're keeping pace with it or perhaps catching up, you think, adjusting for the moves through solid stone.
Please list all means of perception you have, including supernatural ones and true seeing, if applicable.
Normal vision, Darkvision, True Seeing
You fly on - and come to a hollow. Here is a big, flat floor with nothing on it save for a few small coins, littered about. It's quite a big space, hundreds of feet long and wide. The stone here is a plain brown, unremarkable with the occasional hint of green in it.
A cavern used for a horde? Tryll tracks the ruby again without slowing down.
[blockquote]Rolled 1d20+10 : 7 + 10, total 17[/blockquote]
> roll 1d20+3
<Penuche> Kotono invokes Penuche's magic: < 5 > [d20=2]
You're racing ahead, racing on and on and on and on and on. Then you run smack into it - something blocking your progress through the stone, something solid even to your ethereal state. Likely something hedging out incorporeal creatures.
Tryll activates Detect Psionics!
It's custom work - it blocks explicitly ghostly and incorporeal creatures, but nothing else by itself.
