Meeting the wanderer
Started by Anastasia, January 31, 2019, 05:26:47 PM
"I can, but it'll limit my ability to teleport us out; I'll have one spell for it."
'Let's split up," Ianvasah says, "The enemies here do not seem challenging. Faster than relying on limited summons."
"Hmm... Not a bad choice, but let's make this room our meeting point. And don't disregard the enemies. Us splitting up is a perfect opportunity for Shar, or anyone else, to take a shot at us."
What kind of layout am I looking at here? How many paths or doors or whatever?
The party races into the temple before them. Cold, dead waters swirl within as you pass, into a place of stone and water. Here stone tentacles hang from the ceiling, twitching as they almost reach the ground. Recesses in the walls are decorated with cracked pearls, where verses of what looks to be Aquan and another language are carved. You'd have to take the time to look closer.
Ahead lie no doors, but passages that lead deeper in, like little carved tunnels deeper into this place.
From before.
On a glance, you can see four.
I don't have a map so I'm just making some generic assumptions about layout.
"We'll take the left two, you take the right two. Check the center passages. It's reasonable that they'd hold the prisoners in the center, and not the outer."
Yup. Going as fast as I can while STEALTHY! as Alyssa is known to do.
Stealth and Perception checks, then.
Stealth:
[blockquote]Rolled 1d20+63 : 11 + 63, total 74[/blockquote]
Perception:
[blockquote]Rolled 1d20+44 : 1 + 44, total 45[/blockquote]
You swim down the tunnel with all the stealth you have, moving slow and carefully. This passage goes downwards in a general sense, curving down until it opens up into a chute going straight down about 20ft.
Alyssa motions Delaize to cover her as she moves to check out the chute.
Delaize holds position as you peek down. It goes to a bottom with a little more light, seen within. Bits of seaweed grow on the walls, floating about in the water.
You can descend down if you wish.
Alyssa motions for Delaize to follow as she heads down.
