A book and many things to do
Started by Anastasia, July 09, 2019, 11:04:47 PM
Alyssa casts Xorn Movement on herself and sinks into the ground, looking for other levels or rooms.
You try and do so, but you find the ground resists you even with your magic. Something is blocking it, something hard and inflexible.
Alyssa furrows her brows and attempt s to punch through the ground with her TK again.
[blockquote]Rolled 1d20+33 : 3 + 33, total 36[/blockquote]
You crack the ground a little bit, yet nothing else. The near silent sliding of stone follows, the noise coming from all around you.
Alyssa floats into the air and looks around to see what's going on.
The walls are slowly starting to close in on you, from all angles.
Is there anything around I can use try and punch through the walls or wedge them in place?
There is not, at least not lying around the room.
Alyssa chants a spell, firing off beams at all the walls and floor!
Disintegration (Chain, Echoing), CL 33.
I can hit 21 targets, so space that out into appropriate cubes to stop the walls and punch through the floor.
Give me the obligatory attack roll to check for a 1.
[blockquote]Rolled 1d20+34 : 13 + 34, total 47[/blockquote]
