The first peaceful day
"It shows possibilities, or perhaps sideways glances," Saluiel says on considering, "To explain: What could be or what may have been. The Prime Material is often called a prism that has endless refractions, the analogy is similar. Where space becomes frayed, it seems that it shows potentials."
Moore nods. "That makes sense. Do you think there's any link to reality?" He asks. "The me that's there, do you think he can access anything outside, or do you think he can only affect 'his' possibility?"
"No, save for direct harm to any of us," Is the answer you get again, "It seems to be little more than phantasms with teeth."
Moore nods again. "Still, There's a vast amount of possibility there... you could talk to someone who's no longer alive, or get secrets from someone who's your enemy on the outside." Moore says.
"It's not worth it."
Cresiel speaks up here, voice firm. More than firm, determined. "It's not worth it, Moore."
"The visions can be disturbing," Saluiel concurs, "Some see it once and never return, or suffer a sundered mind."
"I think it's worth considering if we get stuck somewhere." Moore counters. "But I understand that relying on something that doesn't truly exist is it's own problem."
A shake of his head, "Anyway... your spells." Moore says, as he produces parchment and writes on them.
Lets give him...
Antimagic Sound
Moore's Quick Gather
Moore's Modified Spell Theft
And the 700 gold in 7 platinum coins.
Platinum coins are 10 gold per, Moore.
The spells are studied for a time, "I'll need full scrolls of them," he says, "But this is acceptable."
"I admit, scribing scrolls isn't something I'm versed in." Moore says. "But it shouldn't be terribly hard to find someone to do it here, of all places."
"Now, you understand and can resist what anathemic knowledge is?" The angel goes on from that.
Moore nods. "It seems that, since I overcame it once that it's been easier to apply the same principals to further episodes."
"Then this will not be hard. If you've come so far, it's not much more than learning new spells," Rising now, going to a window which lets in the pale light of the stars in the night sky, "Though the spells are closer to rituals - it is not something you cast casually."
Moore nods. "That makes sense. It isn't something I expect to use after this."
"Then let's begin. This will take some time, still," He warns, gesturing you over.
