A new order
Started by Anastasia, July 22, 2019, 11:42:20 PM
I have one! So I'll slap a quickened dimensional lock on the portal.
Alicia: 741/1014 (78 vile)
Active spells: Many moments of prescience (CL 33), extended mind blank (CL 34), extended nondetection (CL 34), sensual blessing (CL 33), epic mage armour (CL 33), recitation (CL 33), many moments of prescience (CL 33), greater heroism (CL 33), repelling shield (CL 33), spell turning (CL 33), dance of the unicorn (CL 33), foresight (CL 33), vision of the omniscient eye (CL 33), extended ray deflection (CL 34), greater visage of the deity (CL 33), extended greater anticipate teleportation (CL 34)
Defences: AC 113, CMD 136, spell resistance 48, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear, dazzled & blinded), nondetection (DC 49), ray deflection, freedom of movement
Stat buffs/penalties: +25 competence perception, doubled crit range, +10 armour AC, +3 luck attack/saves, +9 shield AC, +4 morale attack/saves/skills, +2 insight AC/reflex, +10 insight perception, +15 natural armour, +4 saves vs poison, +40 str, -2 dex, +20 con, +2 int, +4 wis, +4 cha, -8 size, +17 sacred all rolls
Perceptions: Darkvision, tremorsense, blindsight 3 miles, scent, arcane sight, perception +108
Sorcerer spell slots: 6/16/16/14/3/9/13/8/7/7/8/5/4/2/3
Duskblade spell slots: 6/23/21/21/10/7/7
Marie: 495/627 (78 vile)
Active spells: Extended mind blank (CL 33), extended nondetection (CL 33), sensual blessing (CL 33), epic mage armour (CL 33), recitation (CL 33), greater heroism (CL 33), repelling shield (CL 33), extended ray deflection (CL 33), greater arcane sight (CL 33), bibliotheca arcana (CL 33)
Defences: AC 109 (CMD 105), spell resistance 48, energy immunity (electricity), status immunity (petrification, polymorph, form-altering, energy drain, ability drain, ability damage, mind-affecting), nondetection (DC 48), ray deflection, freedom of movement
Stat buffs/penalties: +25 competence perception, +3 luck attack/saves, +9 shield AC, +4 morale attack/saves/skills, +15 insight knowledge, +17  sacred all rolls
Perceptions: Darkvision, tremorsense, blindsight 60, scent, greater arcane sight, perception +94
Sorcerer spell slots: 6/9/10/9/8/8/8/8/7/8/7/4/0/4
CL check required, unsurprisingly.
[18:55] <@Ebiris> roll 1d20+37+17 CL
[18:55] <Penuche> Ebiris invokes Penuche's magic: < 59 > [d20=5]
The portal resists - powerful magic is bolstering it. You'll need more than a dimensional lock to stop it, you believe, even with all of your power.
"Marie, this'll need your teleport block spell!" Alicia calls, and given how titanic she is it's probably heard all over the battlefield.
If anything comes through the portal, Alicia has greater anticipate teleport up which gives 3 rounds warning and tells her what creature type is coming.
Init is Alicia (Supreme Init) > Portal (60) >  Latha = Shadow Hell (43) > Antenora (42) > Portal (40) > Marie (37) > Portal (20) > Portal (0)
The portal shudders and erupts, a spray of shadow-stuff coming out, splattering all over the party like black acid. The portal's tearing by the moment, power rushing through it more and more.
Ref.
[19:34] <@Ebiris> roll 1d20+76 Alicia ref
[19:34] <Penuche> Ebiris invokes Penuche's magic: < 94 > [d20=18]
[19:34] <@Ebiris> roll 1d20+72 Marie ref
[19:34] <Penuche> Ebiris invokes Penuche's magic: < 81 > [d20=9]
> roll 1d20+79 Antenora
<Penuche> Kotono invokes Penuche's magic: < 84 > [d20=5]
> roll 1d20+71 Latha evasion
<Penuche> Kotono invokes Penuche's magic: < 78 > [d20=7]
180 damage.
Everyone half but Latha, who takes none.
Whatever it is, it is vile to the core. It hurts deep in your body, the contact revolting. If you were mortal and survived this, you feel you'd be nauseated, worthless for anything. As it is you feel dreadful, withstanding it all.
"Healing?" Latha calls a single word as her shield holds true, parrying it all away from her.
Antenora
HP: 556 (78 vile)/768
Bonuses: Attack+24 (+17 sacred, +4 morale, +3 luck), Damage+17 (+17 sacred) AC+20 (+17 sacred, +3 luck), Saves+24 (+17 sacred, +4 morale, +3 luck), Skills+21 (+17 sacred, +4 morale), Checks+17 (+17 sacred)
Resources: Holy Fury 29/36 (enc) Divine Retribution 1/1 Smite Evil 10/12 Channel Energy 17/17 Lay On Hands 340/448 Remove Disease 9/9 (week), Spiritual Connection 3/3 Blinding Speed 25/25
Spells Used:
SLAs Used:
Spells Active: Recitation (CL33), Greater Heroism (CL33), Death Ward (CL33), Life's Grace (CL33), Neutralize Poison (CL33)
Latha
HP: 557 (78 vile)/660
Aura: Holy Light 30ft (7d6 damage vs evil/round) Protective 20ft (+4 deflection/+4 resistance vs evil)
Bonuses: Attack+24 (+17 sacred, +4 morale, +3 luck), Damage+17 (+17 sacred) AC+34 (+17 sacred, +14 armor, +3 luck), Saves+24 (+17 sacred, +4 morale, +3 luck), Skills+21 (+17 sacred, +4 morale), Checks+17 (+17 sacred)
Resources: Channel Energy 14/14 Sun Devotion 3/4
Spells Used: Radiant Storm
SLAs Used:
Spells Active: Recitation (CL33), Greater Heroism (CL33), Death Ward (CL33), Life's Grace (CL33), Neutralize Poison (CL33), Epic Mage Armor (CL33)
Notes: Level + 7 (39) extra damage per hit vs undead during sun devotion.
"Now would be good!" Marie nods briskly.
"Yes, we can't let ourselves be worn down!" Alicia's thunderous voice is heard back to Latha's question.
Alicia: 651/1014 (78 vile)
Marie: 405/627 (78 vile)
> roll 1d20+80 (+19 ???, +3 ???, +10 ???, +1 ???) touch AC.
<Penuche> Kotono invokes Penuche's magic: < 100 > [d20=20]
> roll 1d20+80 (+19 ???, +3 ???, +10 ???, +1 ???) touch AC. crit?
<Penuche> Kotono invokes Penuche's magic: < 95 > [d20=15]
> roll 20d6
<Penuche> Kotono invokes Penuche's magic: < 76 > [d6=4,2,4,5,6,2,6,1,4,4,6,3,3,4,6,2,6,2,2,4]
> roll 10d6 in case any of you are crit immune right now
<Penuche> Kotono invokes Penuche's magic: < 37 > [d6=2,6,2,3,3,2,6,5,6,2]
76 damage unless you're crit immune, in which case it's 37.
The shadows rage at this, attacking you all over. Pain and suffering for all, Shar's bounty as Latha holds, and as she has a moment, "Restore!" A single command in a softer voice, yet one that carries as...
Mass Heal, +150 HP all. Update HP because Antenora will likely do healing herself while you're waiting on Marie.
Antenora
HP: 617 (78 vile)/768
Spells Used:
SLAs Used:
Latha
HP: 660/660
SLAs Used:
I'm assuming what you said in chat about DvR 1 or greater deities counting as a consecrated presence for vile damage holds true here.
Alicia's nearly healed and Marie's topped off, since both have sensual blessing up to double their heals.
Alicia: 875/1014
Marie: 627/627
Antenora readies herself as...
+100 HP Alicia, divine succor. +100 HP Antenora, divine succor. +139 HP lay on hands for full HP. Go Marie.
Antenora
HP: 768/768
Resources: Holy Fury 27/36 (enc) Divine Retribution 1/1 Smite Evil 10/12 Channel Energy 17/17 Lay On Hands 201/448 Remove Disease 9/9 (week), Spiritual Connection 3/3 Blinding Speed 25/25
Spells Used:
SLAs Used:
Latha
HP: 660/660
SLAs Used:
More missiles go flying all over, less targets now but making what they can hit count!
The spells cast last round get their repeat metamagic triggers.
[20:19] <@Ebiris> roll 1d3+31
[20:19] <Penuche> Ebiris invokes Penuche's magic: < 33 > [d3=2]
[20:19] <Penuche> Ebiris invokes Penuche's magic: < 32 > [d3=1]
130 damage to anything bad within 6800 feet, 4 negative levels if they're alive, and entangled.
As those missiles fire off automatically, Marie casts and hopes this doesn't mess up anyone friendly's summoning of allies, not that summons are much help in this environment.
1650 foot radius of no teleportation, 10th level spell if that matters.
[20:22] <@Ebiris> roll 1d20+33+17 CL check on Jaela's teleport block
[20:22] <Penuche> Ebiris invokes Penuche's magic: < 54 > [d20=4]
Alicia: 1014/1014
Marie: 627/627
Sorcerer spell slots: 6/9/10/9/8/8/8/8/7/8/6/4/0/4
Init is Alicia (Supreme Init) >  Latha = Shadow Hell (43) > Antenora (42) > Marie (37)
To this the portal shudders and closes, winking out of reality. In that moment you know peace, a breath's time to recover yourselves.
It is then you see them, winking into reality over a mile away. Spheres of nothing, a dozen - three dozen - twelve dozen - hundreds. More and more Eyes of Shar are appearing ahead, gathering. At the same time the ground abruptly erupts, great yearning chasms lined with teeth. They rise up, space twisting as they pursue you, looking to pull you into the earth and consume you whole. So many of them, more by the moment, multiplying rapidly.
Yet in the distance you see it. A tower. Some sort of tower, some sort of edifice. It is hazy even to your divine vision, a promise of something as the Song of Shar rallies, growing stronger.
The Song of Shar is getting stronger. You can feel the power pulsing throughout the battlefield now, like a heartbeat. Marie's countersong is struggling against it.
> roll 1d20+30 Eyes of Shar
<Penuche> Kotono invokes Penuche's magic: < 41 > [d20=11]
> roll 1d20+53 The Chasms
<Penuche> Kotono invokes Penuche's magic: < 67 > [d20=14]
> roll 1d20+20 The Tower
<Penuche> Kotono invokes Penuche's magic: < 28 > [d20=8]
Init is Alicia (Supreme Init) > The Chasms (67) > Latha = Shadow Hell (43) > Antenora (42) > Eyes of Shar (41) > Marie (37) > The Tower (28)
Go.
"We need to wait on others catching up," Alicia says as she shrinks down to more manageable size while dodging the ravenous earth.
Still colossal for mechanical effect, just not mega-sized.
She'll need to handle those eyes before they can threaten anyone else, but they're not in range yet so she'll see what she can do with those chasms, detonating a sunburst inside the maw of one while evading another!
Sunburst SLA used here.
[17:03] <@Ebiris> roll 1d20+36+17 Sunburst SR
[17:03] <Penuche> Ebiris invokes Penuche's magic: < 66 > [d20=13]
[17:03] <@Ebiris> roll 25d6 vs undead
[17:03] <Penuche> Ebiris invokes Penuche's magic: < 99 > [d6=1,3,6,1,6,4,6,5,3,1,6,4,4,2,3,5,5,3,6,4,2,4,6,6,3]
[17:03] <@Ebiris> roll 6d6 otherwise
[17:03] <Penuche> Ebiris invokes Penuche's magic: < 19 > [d6=2,6,1,3,6,1]
DC 47 ref half, blinded if save fails.[/i]
Alicia: 1014/1014
Marie: 627/627
