Ahead lies...?
The heat is the first thing you notice.
The second is that you're in the middle of thick, scalding steam. Only your protections and the provenance of teleportation magic protects you, vision terrible as steam constantly blows past you.
"Up," Cresiel calls, flying amid the steam and wind.
Cresiel
HP: 767/767 (regeneration 20)
Aura: Protective 20ft (+4 deflection/+4 resistance vs evil)
Bonuses: Attack+4 (+4 sacred), Damage+4 (+4 sacred) AC+4 (+4 sacred), Saves+4 (+4 sacred), Skills+0, Checks+0 weapons count as holy, doesn't stack
Resources: Holy Fury 33/33 (enc) Channel Energy 13/13 Divine Retribution 1/1 Blinding Speed 25/25 Knight's Challenge 15/15
Spells Used:
SLAs Used:
Spells Active: Detect Evil (CL34), Detect Snares and Pits (CL34), Discern Lies (CL34), True Seeing (CL34)
Notes: Adjacent allies gain a shield bonus equal to Cresiel's shield bonus.
Xandra
HP: 567/567
Aura: Menace 20ft (-2 attacks, AC, saves; DC 37)
Resources: Smite Evil 9/9 Lay On Hands 16/16 Servant of the Heavens 1/1 Sudden Empower 1/1 Sudden Enlarge 1/1
Spells Used:
SLAs Used:
Spells Active: True Seeing (CL34)
Notes: Has bardic music in the rare event Moore can't cover something.
Kaja
HP: 631/631
Aura:
Resources: Breath Weapon 1/1 Dervish Dance 12/12 Endless Cuts 3/3 +5 One Attack On FA 1/1 (rnd) Take 10 On One Attack (rnd) 1/1
Spells Used:
SLAs Used:
Spells Active: Energy Immunity (Fire) (CL34), Celestial Valor (CL34), Mass Death Ward (CL34), Life's Grace (CL34), Epic Mage Armor (CL24), Mind Blank (CL17), Afina's Perfect Sight (CL27).
Notes: Goes in and wrecks things. The end.
Jetina
HP: 580/580 (fast healing 5)
Aura: Courage 10ft (+4 morale vs fear), Positive Energy 10ft (1 hit point healing/round)
Resources: Smite Evil 7/7 Smite 6/6 Channel Energy 14/14 Emergency Healing 3/3 True Believer 1/1
Spells Used: Healer: 5 5th level, 1 8th, 5 10th level spells PT: 1 10th level spell
SLAs Used:
Spells Active:
Notes: Divine Vigor is +10ft land movement and +2 temp hp per hit die. Divine Shield is Cha mod to shield bonus to armor class.
Moore will head up indeed.
Afina's Perfect Vision should let us see through the steam without issue, right?
It gives you blindsight 200ft but it doesn't explicitly see through things. You do have all around vision as well, though.
I forget, does true seeing help with stuff like that?
Either way, that's fine, let's go.
It doesn't help with mundane fog or the like.
Up the party flies - out of a great, low, roiling bank of steam. Below you is a sea of steam, hissing and bright. Fire is around you, save for rends where it is not. Water pours in, spilling everywhere, each one wrapped in an armored cloak of steam from the mere act of Water entering Fire. Below you, in the gaps you can see, you see great,  uneven volcanic rocks, surfaces being forged together and split every moment, constant creation from the war before you.
"Well, we can't avoid the steam, but let's see if we can find somewhere where it isn't as bad." Moore says as he continues forward. "We're looking for a house, apparently... but who knows where it is. We'll just have to be on the lookout for notable things."
"I understand this goes down and down," Jetina calls over the winds and the hissing, "Could it be deeply buried?"
"Eyes open, we can work on that after we understand the surface," Kaja calls.
Moore nods. "Let's keep going and keep an eye out, then."
Basically just looking for anything they can spot between the steam, or that looks interesting.
Sure, gimme a Perception check for reference and then a d100.
Take 10 for 92.
[22:18] <Nephrite> roll 1d100
[22:18] <Penuche> Nephrite invokes Penuche's magic: < 34 > [d100=34]
It's like uneven towers of volcanic rock that have half melted into each other, forming a plateau of sorts.One ever building, ever growing as Water and Fire wage war. It goes a great distance in every direction, miles and miles.
As you take all of this in, it is Kaja who calls, "Look!" From the east you see it - several magic carpets and a flying chariot, efreet on most of them and spare space loaded with wrapped bundles of various shapes and sizes.
Are they going away from them?
Coming in your general direction.
"If they really want a fight..." Moore says quietly.
If they're going to come, we're going to spend time buffing! Or at least Moore is going to do some singing.
"If," Cresiel agrees, readying his hammer.
Xandra does the same, "Not here, not now," she says, "They are not hostile, Moore."
